11-28-2013, 08:08 | #32 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2069395 Status: Offline Thanks Meter: 0 | please help me.. i'm facing same problem,every time i try to restore my iPhone 5, itunes show me error 9. - update itunes - DFU mode / Recovery mode - change cable - full charge - try on win xp & win 7 - change PC - change battery - change lightning connector still no results.. please somebody help me... thank's |
04-08-2014, 10:06 | #34 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 742370 Status: Offline Thanks Meter: 14 | i'm Facing Same Problem IPhone 5c Unknown Error 9 While Trying to do Restore With Itune i try in recovery Mode and error 9 i try in DFU Mode Error 9 I change USB Cable Error 9 I Update itune Error 9 i remove full itune and all apple software from PC install Again and after than error 9 i Change PC Error 9 i Try On Window xp & Window 7 and Window 8 Error 9 I open the Phone Remove Battery for 10-15 minutes and put again and try again in DFU Mode so Error 9 now is only 1 thing left change battery and i will soon try that and will tell here result if any1 have any good idea for solve this problem so tell plz plz help me |
06-11-2014, 02:15 | #41 (permalink) |
Freak Poster Join Date: May 2006
Member: 272137 Status: Offline Thanks Meter: 75 | Yes it's a U2 USB controller IC near CPU because of this IC gets a bit hot and disconnected iphone 5 from the iTunes Mostly restore error occurs be course of this cheap IC ,bAttery draining restore error ,dead battery not charging etc .its bit hard to change but U2 is responsible for loads of fault in iPhone 5,5s,5c. |
The Following User Says Thank You to Repair4u For This Useful Post: |
06-11-2014, 11:52 | #42 (permalink) |
Super Moderator Join Date: Dec 1999 Location: In EveryOne's Heart
Member: 824 Status: Offline Thanks Meter: 25,151 | Hi guyz. This is proper guise of your problem i .e (error 9) This error occurs when the device unexpectedly loses its USB connection with iTunes. This can occur if the device is manually disconnected during the restore process. This issue can be resolved by performing USB troubleshooting, using a different USB dock-connector cable, trying another USB port, restoring on another computer, or by eliminating conflicts from third-party security software. Br. Mihut |
06-22-2014, 15:03 | #44 (permalink) | |
Member: 824 Status: Offline Thanks Meter: 25,151 | Quote:
you face error 9 its mean you can change u2 ic. and if you want to proper know about u2. you can search more it from google | |
