07-14-2016, 04:54 | #32 (permalink) |
Junior Member Join Date: Mar 2012
Member: 1730325 Status: Offline Thanks Meter: 1 | Unseen Long screw damage. Tried this on an iPhone 6 but no luck (both IC replacement and jumper), then, somewhere else I saw other "version" of the jump and tried it but still no camera. After several software attempts with a new IC, I ended up with a death phone only detected in DFU and won't even start flashing with iTunes... 1-2 3-4 I jumped 1 ->2 instead of the classic 2->4 Pretty sure saw someone succeeding with this somewhere online After some thorough microscope examination, I noticed long screw damage (not guilty) on the screw hole right below my working area :/ Any ideas on what actually killed the phone? Was it a stupid idea to try to jump the other way? or was this "long screw" damage that mainly killed the phone after software. I'm 99% sure this was also the main cause of the camera failure... My options are: Scratching the board and try to repair the other persons mess Replacing a power IC that might have shorted. I can achieve both repairs myself, but if some other IC replacement is necessary I wouldn't know where to start :C Last edited by psydry; 07-14-2016 at 04:57. Reason: Minor grammar and sense making corrections. |
09-01-2016, 22:05 | #34 (permalink) |
Insane Poster Join Date: Dec 2013 Location: saudi arabiya Age: 31
Member: 2085357 Status: Offline Sonork: 100.1587837 Thanks Meter: 17 | i have iphone 6 it is video recod camera front and back working but camera front and not working photo i am go to softwaer and change all cameras but still same problem please help me..... |
09-21-2016, 21:13 | #36 (permalink) |
Junior Member Join Date: Sep 2008
Member: 852283 Status: Offline Sonork: 343 Thanks Meter: 13 | This is correct way to supply camera with voltage but you lose cam ext signal from cpu also this tiny chip convert pp_vcc main to cam 2.85 v LDO Last edited by lnux; 09-21-2016 at 21:21. |
The Following User Says Thank You to lnux For This Useful Post: |
11-29-2016, 11:05 | #44 (permalink) | |
Insane Poster Join Date: Apr 2012 Location: Germany
Member: 1752885 Status: Offline Thanks Meter: 4 | Quote:
Itīs on the same PCB Side | |
11-29-2016, 12:25 | #45 (permalink) |
Member: 1752885 Status: Offline Thanks Meter: 4 | OK, now i soldered a bridge from Nand 3V Line to Pin A1 U2301. But Camera is starting sometimes and after a few seconds black screen. Frontcamera and Flash is working fine.I changed Big Cam, without any Result |
