Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 08-20-2010, 12:27   #76 (permalink)
Burnt Cobba's Avatar
Member: 11325
Thanks Meter: 266
Originally Posted by sullz94 View Post
okay ill buy a soldering iron but, how do i solder the upper part? theres no metal there and the bottom part isnt made of metal...
mate you have to connect to the solder part of a component. If you are going to do your first ever soldering onto that component i feel its too risky and you ll end up damaging the motherboard more.
its wiser if you just go to a friend and tell him to do it, try restoring and remove that wire after. That is my advice. Now at the end is your choice.
The Following User Says Thank You to Burnt Cobba For This Useful Post:
Old 08-20-2010, 19:01   #77 (permalink)
Member: 1374217
Cool
Originally Posted by Burnt Cobba View Post
try to do this connection shown in red and then retry to restore.
hope this helps and solves your problem
hello, this is solved error 23 iphone 3g? just jumper this two points?
The Following User Says Thank You to romanocesar For This Useful Post:
Old 09-02-2010, 17:10   #78 (permalink)
Member: 609801
Thanks Meter: 8
Hello!
I have a problem with an Iphone 3G. The vibrator wasn't working so i disassembled the phone and tried to reposition the vibrator piece.
Unfortunately, while i was doing this, i managed to short circuit one capacitor from the circled area.
I am not very sure which one, but i used a tweezers and a flame appeared.
Now the phone doesnt power on, not even connected to the wall-charger / USB cable.
Please help, click here for the picture - better understanding.
Many thanks in advance!
The Following User Says Thank You to fulgerul For This Useful Post:
Old 09-03-2010, 12:39   #79 (permalink)
Member: 1286693
Thanks Meter: 3
Hello Everyone:
My new 3gs iphone's camera is stuck upside down
i restored it, i did a full reset but the problem is not solved
photos doesnt rotate
nothing rotates on it
Plz help
The Following User Says Thank You to shujaamin For This Useful Post:
Old 09-08-2010, 00:21   #80 (permalink)
bluejack22002's Avatar
Member: 741453
Thanks Meter: 43
Re
Originally Posted by skebb View Post
Try restoring either in restore mode or in dfü mode.
Tell me, at what point of the restore process it crushes. If it is in the control part of the process it could help to let the battery drain totally and then put it in the charger. Mine come back to life through this.
Hope this helps.
HI friend, the error come when itunes said waiting for iphone (in the begining after preparing the iphone) thanks
The Following User Says Thank You to bluejack22002 For This Useful Post:
Old 09-08-2010, 12:58   #81 (permalink)
Member: 235665
Thanks Meter: 10
iphone 4 speaker
hi to all!!i have a problem with an iphone 4...a speaker problem.when is playing music or someone calls.the sound becames very metalic ,pitched...
sometimes is working fine,sometimes not.i opened the phone.there is no water damages.
the phone seems to be brand new.
i have no clue about it....i would try to change charging flex and audio flex(with side buttons)...
when i press the socket of charging flex ...the sound seems to be ok...
i wonder if is an audio ic or something like that?
please,any ideea?
The Following 2 Users Say Thank You to decodoruM For This Useful Post:
Old 09-13-2010, 14:12   #82 (permalink)
Member: 797796
Sonork: kemasheri
Originally Posted by shujaamin View Post
Hello Everyone:
Plz help
That's ACCELEROMETER problem......I thought....
I have same problem...CALCULATOR....SAFARI...can not show in landscape....
Is Hard/Software problem??
IPHONE 3G 16Gb White...FU ver 3.0..
Thx for all....
The Following User Says Thank You to kemasheri For This Useful Post:
Old 09-13-2010, 16:50   #83 (permalink)
Member: 761694
Thanks Meter: 2
i have iphone 3g shwoing apple log on screen going recovery mode and dfu mode but not connecting with itune in pc.i had change chargingjack flex but still same its hardware isshu.help me out.
thanks
The Following User Says Thank You to legendmani08 For This Useful Post:
Old 09-17-2010, 07:05   #84 (permalink)
Member: 558946
Thanks Meter: 2
I have a small problem. Whenever my iPhone 3G goes to sleep, it will just shut off. Wont come back on. I have to hold home and power for 10 secs to revive it. This problem will not happen if connected to charger/USB.
This had been dropped from height and thus this happened. Any solutions?
The Following 2 Users Say Thank You to nitant For This Useful Post:
Old 09-17-2010, 14:08   #85 (permalink)
Member: 1087964
Thanks Meter: 3
I have a problem with the iPhone touch 3gs, I tried with another touch no result. please help me
The Following User Says Thank You to brodovitch For This Useful Post:
Old 09-17-2010, 14:15   #86 (permalink)
Member: 1087964
Thanks Meter: 3
I have a problem with the iPhone touch 3gs, I tried with another touch no result!!!!! please help me
Old 09-27-2010, 21:45   #87 (permalink)
Member: 6950
Thanks Meter: 4
I had a Working iphone 3g but had to open it up to repair the silent button.
When I opend the iPhone I Immidiately smelled something burning but did not pay attention to it. disambled phone and repaired button. but when I tryed the phone it will not power on. When I plug in the charger and push the power button I see screen turn black but does not power on.
What can be wrong. changed battery and power connector but stil nothing
Regards Nico
Old 09-27-2010, 21:56   #88 (permalink)
Member: 11325
Thanks Meter: 266
Regards Nico
What happens if you connect it to a PC/MAC? Does it get recognized or not?
Had a similar problem. In my case replaced LTC-4088 and it was back to life.
Old 09-28-2010, 08:45   #89 (permalink)
Member: 6950
Thanks Meter: 4
When I connect it to my pc nothing happens. When I press the power button when connected to pc I see the LCD turns black.
Do you have Picture of component you mean to replace?
Regards
Nico
Old 09-28-2010, 09:12   #90 (permalink)
Member: 11325
Thanks Meter: 266
Regards
Nico
The component i am referring to is the one shown in the attachment. Try to follow the directions written. Could be it is not the origin of the fault. Its difficult when unit is not in hand. If it is not it the last thing you would want is that the PCM ic needs to be replaced. Am assuming it is not the case.
I forgot who shared this one up (its not my work). So if he is reading this thread dont jump on me .
Hope this helps
The Following 4 Users Say Thank You to Burnt Cobba For This Useful Post:
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.24967 seconds with 11 queries
