Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 10-14-2014, 14:07   #4981 (permalink)
Crazy Poster
Member: 1358006
Thanks Meter: 7
Originally Posted by gsm_new1 View Post
Hello
Today i buy new iphone 6. that time the version was 8.0 so i was try to update from setting but its gave error in installation.
then try to update via file but its gave error 53.
already change the host file and every thing. but same problem.
already try with 8.0 and 8.02 but same problem. any solution..
bro
Go to An apple store and thay will change without any cost!
Dont Dissassamble it with any reason!
Old 10-14-2014, 14:45   #4982 (permalink)
gsm_new1's Avatar
Member: 1189306
Sonork: 100.1589231
Thanks Meter: 273
@furqan93
hy can u tell me any solution ??
bro
Old 10-15-2014, 11:56   #4983 (permalink)
Member: 1846735
Sonork: 100.1657479
Thanks Meter: 190
Hi,
I have a problem with iPhone 5s. Phone is after the fall and no power lcd. I replaced THREE new full set and nothing. Loaded new ios 8 with Itunes and shows error 14. After many attempts managed to upload firmware on dissasembly full set (it took twice as long but success). Still after that did not work and LCD is DARK
Paths of the threads not broken, are ok. Coil is ok.
Any help?
Old 10-17-2014, 04:00   #4984 (permalink)
Member: 2275577
Iphone 4 won't charge after wire up
Hi, I had a problem with my battery connector, while disconnecting to solve a stack phone during ios 7.1.2 update, I broke 2 pads so I connected 4 wires from battery to pads ( "hot" wires with battery on ).
now phone works, only problem it won't charge or charge very slow .
what could I harm by soldering wires directly from battery to points ?
i can see the charging icon when connect with usb or charger.
also when I connect the charger to the phone ( even if phone is off ) it will cause the phone to turn on ( maybe it is an ios 7.1.2 issue I didn't had this in ios 5 ).
Thanks in advance for an answer.
Old 10-17-2014, 12:01   #4985 (permalink)
Member: 1235892
iphone 4
iphone 4 activation error
iphone could not be activated because known error 0 \0e800004
please help me to activate iphone 4
Old 10-17-2014, 18:27   #4986 (permalink)
Cheater -Don't Deal with him-
Member: 2262340
anyone can help me for error 1 iphone 5s ?
Old 10-18-2014, 17:32   #4987 (permalink)
Member: 1967919
hlo sir,
i have iphone4 after changing iphone 4 lcd it not power on .
when im attach iphone with charger and then charger is off so give me any solution plzz
Old 10-19-2014, 09:57   #4988 (permalink)
Member: 125037
Sonork: 100.1649338
Thanks Meter: 254
Same problem.
Looking for a sw or hw solution.
Cheers
Old 10-19-2014, 10:53   #4989 (permalink)
Member: 2276868
Newbie here, Hi
How do i unlock the sim lock, ive never heard of this carrier
Initial Activation Policy: EMEA Service.
Carrier: EMEA Service
SIM Lock: Locked
Thanks in advance, Miss B
Old 10-19-2014, 15:27   #4990 (permalink)
Member: 1732511
need iphone 4s power ic solution plz help me
Old 10-19-2014, 15:44   #4991 (permalink)
Member: 2013158
Hello, iphone 4 firmware with no errors, but in recovery? PCB without repairs and no water? Using amperage ok. Sorry for my english.
Old 10-19-2014, 20:06   #4992 (permalink)
Member: 1307957
Sonork: hari28c
Thanks Meter: 3
hi iphone 5s no sound i already change ringer pls help
Old 10-19-2014, 20:29   #4993 (permalink)
Member: 2266166
Sonork: nil
Thanks Meter: 4
Please help me.
My iphone 5 discarge very quickly. I already changed battry. also changed compleate original body accept motherboard. when shutdown phone after 2 to 3 hours battry also gettin low. I cheaked motherboard no short. please give me sollution for this problem with picture.
will be very helpul
aryanplus.
Old 10-20-2014, 05:08   #4994 (permalink)
Member: 2274859
Anytime you have leakage in a capacitor, it is damaged and can't be expected to be functioning properly. If it is secreting anything, its acid and very corrosive. Consider also that something else might be causing these capacitors to be failing.
Old 10-20-2014, 05:19   #4995 (permalink)
Member: 2274859
try different cable and charger. If problem not solved then its your charge port
All Blackberry Hardware and Software Solution youssef01 BlackBerry (RIM) 34 11-01-2012 17:31
I need DVD player hardware and software solution site ..::MOBILES::.. GSM Mobile Links 0 04-05-2009 15:49
O2 Hardware and Software solutions Eagle7 Various 2 04-14-2006 12:47
Page generated in 0.27049 seconds with 10 queries
