06-27-2013, 15:36 | #4231 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: Malta Age: 36
Member: 1176031 Status: Offline Thanks Meter: 62 | Quote:
The second pictures there is missing a CPU BUCK coil rated at 1.5uH - 1.45A - 159ohm (could be either found in another 4S or other phones) and the other missing component is a capacitor. The coil is needed to amplify voltage for the CPU core while the capacitor is not needed. For now I would solder the coil and try to power on the phone, as it should at least be able to boot, but not able to get signal as of the missing avago pa. Do not use a lot of heat as the NAND is very near and could easily overheat both the NAND and A5 processor. | |
06-27-2013, 20:48 | #4232 (permalink) |
Junior Member Join Date: Mar 2013 Location: Porto, Portugal
Member: 1898210 Status: Offline Thanks Meter: 0 | hello guys , I have an iphone 4 that doesnt power at all, I was checking for caps around PMIC , but still nothing, PMIC heats too much! any suggestions? |
06-27-2013, 22:07 | #4233 (permalink) | |
Junior Member Join Date: Jun 2013
Member: 1966748 Status: Offline Thanks Meter: 0 | Quote:
I can take it in recovery mode. I try restore but itunes gives 21 error code. If i understand correctly if i solder the coil iphone can be turn on. | |
06-28-2013, 06:55 | #4234 (permalink) | |
In case you have a spare dead iphone 4 board you can take the coil which is used to supply the LED driver. | |
06-28-2013, 06:56 | #4235 (permalink) | |
06-29-2013, 20:56 | #4238 (permalink) |
Member: 1964818 Status: Offline Thanks Meter: 0 | hi guys, i've a little problem with my iphone 4s iOS 6.1.3, when i try to install an application via itunes every thing is ok but in last stage when copying the application to the phone and make synchronization its fails i don't know why ? must i have a jailbroken iphone to do that ? another hardware problem with my friend's iphone he has a 3gs 8gb he made a mistake and he had a bricked baseband, is there a solution to change the toshiba chipset by another one ? Thanks |
07-03-2013, 09:37 | #4241 (permalink) | |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
