10-14-2014, 14:07 | #4981 (permalink) | |
Crazy Poster Join Date: Aug 2010
Member: 1358006 Status: Offline Thanks Meter: 7 | Quote:
Dont Dissassamble it with any reason! | |
10-15-2014, 11:56 | #4983 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Poland
Member: 1846735 Status: Offline Sonork: 100.1657479 Thanks Meter: 190 | Hi, I have a problem with iPhone 5s. Phone is after the fall and no power lcd. I replaced THREE new full set and nothing. Loaded new ios 8 with Itunes and shows error 14. After many attempts managed to upload firmware on dissasembly full set (it took twice as long but success). Still after that did not work and LCD is DARK Paths of the threads not broken, are ok. Coil is ok. Any help? |
10-17-2014, 04:00 | #4984 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2275577 Status: Offline Thanks Meter: 0 | Iphone 4 won't charge after wire up Hi, I had a problem with my battery connector, while disconnecting to solve a stack phone during ios 7.1.2 update, I broke 2 pads so I connected 4 wires from battery to pads ( "hot" wires with battery on ). now phone works, only problem it won't charge or charge very slow . what could I harm by soldering wires directly from battery to points ? i can see the charging icon when connect with usb or charger. also when I connect the charger to the phone ( even if phone is off ) it will cause the phone to turn on ( maybe it is an ios 7.1.2 issue I didn't had this in ios 5 ). Thanks in advance for an answer. |
10-19-2014, 10:53 | #4989 (permalink) |
Member: 2276868 Status: Offline Thanks Meter: 0 | Newbie here, Hi How do i unlock the sim lock, ive never heard of this carrier Initial Activation Policy: EMEA Service. Carrier: EMEA Service SIM Lock: Locked Thanks in advance, Miss B |
10-19-2014, 20:29 | #4993 (permalink) |
Junior Member Join Date: Sep 2014 Location: Dhgaka
Member: 2266166 Status: Offline Sonork: nil Thanks Meter: 4 | Please help me. My iphone 5 discarge very quickly. I already changed battry. also changed compleate original body accept motherboard. when shutdown phone after 2 to 3 hours battry also gettin low. I cheaked motherboard no short. please give me sollution for this problem with picture. will be very helpul aryanplus. |
10-20-2014, 05:08 | #4994 (permalink) |
Member: 2274859 Status: Offline Thanks Meter: 1 | Anytime you have leakage in a capacitor, it is damaged and can't be expected to be functioning properly. If it is secreting anything, its acid and very corrosive. Consider also that something else might be causing these capacitors to be failing. |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
