07-15-2013, 18:44 | #4277 (permalink) |
Junior Member Join Date: Jul 2013 Location: My comfy workshop Age: 40
Member: 1978791 Status: Offline Thanks Meter: 1 | Hi there First of all Thank You in advance for any help, your knowledge guys is very much appreciated !!! I have an iPhone 4 I believe to be the very first one. I just got it to the stage of setting it up for the first use but I am having problems with activation. It's running on a 6.1.3 (just updated). The problem is that ICCID is UNKNOWN. The IMEI is present. It doesn't recognise SIM CARD. It was like that even on 6.0.1 Also, when it gets to Wi-Fi activation stage it doesn't pick a Wi-Fi which is just meter away and with no issues, so not sure if Wi-Fi works. Any suggestion?? Thank you once again |
07-15-2013, 21:47 | #4279 (permalink) |
Junior Member Join Date: Jul 2010
Member: 1348798 Status: Offline Thanks Meter: 0 | Hi After changing display on a iphone 4s has stopped charging, i tried almost everything. Restored the phone, changed batteri & bottem contact. When it is charching you see only power symbol instead of the battery charing symbol. And when the iphone is off and you see charg symbol but it wont start upp the iphone becasuse it is drained of batteri. Any solution to this problem? Regards |
07-15-2013, 23:25 | #4280 (permalink) | |
Member: 1978791 Status: Offline Thanks Meter: 1 | Happened to me Quote:
It happened to me and it was as simple as just taking the battery cover and pressing down the camera connector down as it was loose, but I know examples where it was more serious as reballing an IC or something, don't take my word for it Try the connector first m8 | |
The Following User Says Thank You to electronatic For This Useful Post: |
07-16-2013, 00:03 | #4281 (permalink) | |
Member: 1978791 Status: Offline Thanks Meter: 1 | Quote:
Does the memory or a chip must be flashed ???? I've heard that but in case where also IMEI was unknown and wifi as well. That one just shows ICCID UNKNOWN on its own?! I took the logic board to pieces to check for burned out ic's but nothing there, all clear ?! Thank You | |
07-16-2013, 00:16 | #4282 (permalink) | |
Member: 1978791 Status: Offline Thanks Meter: 1 | Update Quote:
...and checked the sim card slot/connector, no damage outside it or inside where the contacts are. Cheers | |
07-16-2013, 07:45 | #4283 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Gela
Member: 293758 Status: Offline Thanks Meter: 39 | I have iphone 4s later water damage network is always searching and if put out sim not see on the display (NO sim) but always searchig. How can solved this? Thanks. |
07-16-2013, 13:42 | #4284 (permalink) |
Member: 1980052 Status: Offline Thanks Meter: 0 | I have iphone 3gs couple of days i am suffering from the restore problem . so many time i did restore but every time day show me -1 error ..please tell me how can fix this error |
07-17-2013, 22:20 | #4285 (permalink) |
No Life Poster Join Date: Oct 2005 Location: white house 2
Member: 194936 Status: Offline Sonork: 100.1616223 Thanks Meter: 484 | hi i have iphone 4 problem after disconnect usb cable off i have changed bettery but still same if insert usb cable on and stuck apple logo and restart after disconnect cable going sleep its hardware issue but how fix |
07-19-2013, 09:44 | #4287 (permalink) |
Freak Poster Join Date: Feb 2009
Member: 967784 Status: Offline Thanks Meter: 77 | UK O2 Tesco Unlock Done iphone 4S But No Network iOS version: 6.1.3 Phone On Searching.........Then No Service show continue any body help what this porblem..........sultion please............. |
07-20-2013, 02:52 | #4288 (permalink) |
Insane Poster Join Date: Jul 2013
Member: 1978553 Status: Offline Thanks Meter: 1 | i got everything fix now but now the lcd want set back flush. the top left corner and around the volume buttons want push down. reckon the after market power cable is to thick. any one had this problem. help please |
07-20-2013, 12:26 | #4289 (permalink) |
Insane Poster Join Date: Jan 2007 Location: Nepal
Member: 436683 Status: Offline Thanks Meter: 15 | Iphone 4 no graphix I have iphone 4........everything works perfectly......backlight, touchpad working but no graphix (black screen with lights) in display.....can anyone pls give me the solution.....jumper ???? any ic replacement ???? anything ????? |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
