01-15-2009, 14:44 | #61 (permalink) | |
Freak Poster Join Date: Apr 2004 Location: secunderabad Age: 55
Member: 63691 Status: Offline Thanks Meter: 114 | Quote:
this is hardware problem.and liquid damage.open the iphone and clean the top connectors,it will be ok. I repaired 2 iphones with the same problem | |
01-15-2009, 17:48 | #62 (permalink) |
Freak Poster Join Date: Sep 2000 Location: Hungary Age: 46
Member: 2208 Status: Offline Thanks Meter: 1 | hello i have a 2g iphone, it says no sim. it was broken inside the sim opening tool. a part of them was in the phone. i remove it, but same problem. thx wbr dollyb |
01-16-2009, 13:43 | #63 (permalink) |
Junior Member Join Date: Oct 2007
Member: 607977 Status: Offline Thanks Meter: 0 | i phone 3g spk problem hi every body im regular visitor of ur site its superb & ultimate give me some sugession how to rectifi it spk strip is gone i need new strip kindly do the needful |
01-17-2009, 15:24 | #64 (permalink) |
Registered User Join Date: Sep 2002 Location: No Man's Land
Member: 15858 Status: Offline Thanks Meter: 10 | Iphone 2G phone mode Touchscreen Problem. Hi, Everythig is working well problem is only in phone mode (and sms ) when tried to touch sms it returns to main menu same problem when i tried touch numbers 123... ( to make call ) it returns to main menu. In other case the touchscreen works well even numbers. br |
The Following User Says Thank You to 8051 For This Useful Post: |
01-22-2009, 13:11 | #69 (permalink) |
Junior Member Join Date: Dec 2008
Member: 924643 Status: Offline Thanks Meter: 1 | Iphone 3G Water damage! Hi I have a Iphone 3G Water damage, problem is LCD only white screen....component damage LCD is OK I need schematic! Please Help me!! |
The Following User Says Thank You to jonny walker For This Useful Post: |
01-26-2009, 00:53 | #71 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Dubai
Member: 908655 Status: Offline Thanks Meter: 393 | Hello, I have an iPhone 3G Factory Unlocked. Phone works fine, I can get network, recieve calls and sms. The earphone does not work when a call comes. Loud Speaker works with iPod and other applications. Only problem when a call comes, the earphone does not work, when i keep it on loud speaker it does not work. If I attach a headphone still it does not work. I dont think there is any problem with the earphone, speaker and headphones. It only comes when a call comes are goes. How do I solve this, someone told me its the boards fault. can you tell me what exactly is wrong with the board and do can I overcome this. Regards DM |
01-26-2009, 11:26 | #72 (permalink) | |
Junior Member Join Date: Dec 2008 Location: Prishtina
Member: 925517 Status: Offline Sonork: Keni Thanks Meter: 3 | Quote:
Ive opened Iphone 3G 8GB and could not se any liquid damage. My problem is that when i start the iphone 3G is always searching for network, there is no Immei,Iccid,Modem firmware.If i leave Iphone3G in to the cold place then it shows network (stops searching) it shows Immei, Iccid and modem firmware and i can make calls, but when i leave the Iphone3G in to a warm room then it goes in to searching for network and there is no immei,iccid, modem firmware. Also when i connect to a computer then Iphone3G is restarting every 4 minutes. Is wery wierd. And the golden question is: "Is someone out there that has a solution for this kind of the problem or Does someone had any problem of this kind". P.S. I've tried to restore to different firmwares 2.0-2.2 and always is the same problem. | |
01-27-2009, 04:52 | #73 (permalink) |
Freak Poster Join Date: Dec 2003 Location: India Age: 46
Member: 47921 Status: Offline Thanks Meter: 2 | my 3g iphone is water damaged and i cleaned it but the touch screen does not work. i tried the screen on a diffrent phone and it works and the other display does not work on the water damage phone either. any suggestions. also the other problem is camera does not work. i tried the dfu restore and also tried another camera but still does not work. any help is greatly appreciated. |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
