to make jumpers that are filters not coils make yellow like in photo. |
all is okkkkkkkkkkk |
Next time search carefully,but if you not find then you ask.;) |
What are the purpose of quartz cryatals? And were do they exist? Do you have a photo of them? |
By wites13 at 2011-10-22 Quartz is like heart beat it generate frequency. |
hi every one on this thread i tried to restore my iphone 3g 8gb with iTune. it gave me error 1015.i changed pc,and tried with changing cable.but still giving me same error . i bought 2nd hand perfect working condition. i just wanted to restore it....i think may be it is jailbroken .that's why i m getting this error can anybody help me thanks in advance. |
phone must boot normally. |
1 Attachment(s) hi mr Wites need help pls my problem is 3gs baterry drain is very very fast and very slow charging i make this picture but same problem http://forum.gsmhosting.com/vbb/atta...1&d=1322654753 |
I have a iPhone 3GS 16Gb Black, Its the blue motherboard edition, I purchased two iPhones, 1 3G and another 3GS both 8Gb for parts for this one. I replaced the backing and the screen with the one off the 3G as I was planing on selling the 3GS after I had repaired it. Connected everything and went to turn it on. And i got nothing, so I then googled if the 3G LCD was the same as the 3GS, To find out that it was NOT. So I rushed and disconnected the LCD and digitizer, Grabbed the old LCD and Digitizer, hooked it up, Only to find that it turned on, but the backlight flickered then went out. So i left it for a few days, Came back and the battery was dead. I put it on charge and the "Red Battery" came up in full brightness. So i figured it fixed its self. I was wrong, After it had booted the backlight went out again. After a week of debating what to do, I figured for the hell of it i would restore it. Restored and still just the flicker when turning on or pressing the "standby" button. So I made my way to the settings and turned down the brightness and locked the phone then went to unlock it. backlight WORKS. So i went to turn it up, it makes it to a little under halfway then it dies. The screen is still working just no backlight unless I turn it down and lock and unlock it again. Any suggestions? I have tested the coil with ohms and it has continuity. |
I have a iPhone 3GS 8GB, Its the 3GS that was released after the 4 as a 8Gb model. It has the Green Circuit board. The issue I am having with it is that it will not detect any simcards, I "Stupidly" updated it to 5.0.1 after i bought it due to it being stuck at "Connect To Itunes" screen. After the update it went to the setup on the phone. It will not react at all if i remove or insert a sim card, When it first boots up to the "setup" screen it says searching, This is weather a sim is inserted or not, Then it goes to no service after a min. Due to this I am also unable to get past IOS's setup to use the phone. Any suggestions would be appreciated. |
help pl mr Wites.................. |
Does it need to have 3 outputs for battery connections, positive, negative and gnd? Or positive and negative is enough? How much voltage and current range is needed for such task? the one I found has 0-30V and 0-5A Thanks |
