![]() | #1741 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2009 Location: Malta Age: 36
Member: 1176031 Status: Offline Thanks Meter: 62 | Quote:
Now that the PMIC is removed I took a look at the solder pads and I think I just damaged permanently the board, I have another image (refer to attachment 2) what do you think? Shall I try to put new PMIC or it is too damaged the board? | |
![]() | #1742 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,595 | Quote:
![]() | #1743 (permalink) | |
And can you advise which tracks I need exactly to fill? And with what material? I never repaired tracks before | |
![]() | #1744 (permalink) | |
make 100% connection,same make to PMIC prints. I think your PMIC is good,because an ic can't burn after phone dropped. | |
![]() | #1745 (permalink) | |
So do I just buy a new PMIC? I don't want to resolder the one I just desoldered because of the high heat given to remove it (400C). So you mean that the phone won't be working after I replace PMIC since it wasn't burned? So what could be the problem then? Why was there the crack in glue is it normal? | |
![]() | #1746 (permalink) | |
I m afraid that other ic's can have crack in glue look carefully. | |
![]() | #1747 (permalink) | |
I will check other cracks but didnt see any yesterday. Thanks | |
![]() | #1750 (permalink) |
Junior Member Join Date: Jan 2008
Member: 671972 Status: Offline Thanks Meter: 0 | iphone 2g power problem sir plz help me i have a iphone 2g,it is dead when i charged it.it did not show the charging It will only power up for a few seconds when it is plugged up after a few seconds it will dead.then i on it again it show apple icon for few seconds and shatdown again.advance thanks |
![]() | #1752 (permalink) | |
![]() | #1754 (permalink) |
Member: 1176031 Status: Offline Thanks Meter: 62 | Hey wites thanks for the tip...I bought 2 PMIC today from china guess it will take around 2-3 weeks to arrive or else I will try to remove one from a dead board. So 360C 4-5mins full air is safe no risk of burning PMIC to desolder and solder a PMIC on a new board |
![]() | #1755 (permalink) | |
Today i needed to reball same PMIC and 1 important print removed from it. ![]() If you unsolder that PMIC and all prints are good reball it and solder back practice a little. | |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
