![]() | #2311 (permalink) |
Junior Member Join Date: Jul 2010
Member: 1349127 Status: Offline Thanks Meter: 0 | iphone 3gs 5.0.1 please help me with this problem how can i unlock iphone 3GS version 5.0.1 or how to downgrade it to 4.1. kindly help me with this My Email- [email protected] |
![]() | #2312 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2009 Location: Malta Age: 36
Member: 1176031 Status: Offline Thanks Meter: 62 | Quote:
ultrasn0w will not work on 5.0.1 even if you had flashed the ipad baseband or have the 5.13 baseband for the simple reason of incompatible unlock strings. | |
![]() | #2313 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,595 | Quote:
But possible problem is at Vbat solder pad of that burn cap, you will need to scratch that region carefully to remove shorting. I think when you screw the board somehow it press the cap in board and it short. I will draw what part to remove and post. There will be easier if i could upload attachments but it give error. | |
![]() | #2314 (permalink) | |
![]() What browser do you use? And what exactly is the error when you try to upload? | |
![]() | #2317 (permalink) | |
cap vbat pad is gnd. ![]() By wites13 at 2011-12-18 sorry for photo. | |
![]() | #2318 (permalink) | |
![]() | #2321 (permalink) | |
![]() Take a look at attachment 1 | |
![]() | #2322 (permalink) | |
in photo so there will be no solder pads of that burn cap. I will show you how i remove on a 3g board it have same cap with pads. | |
![]() | #2323 (permalink) | |
What I am also confused about is why did it short after I charged the battery with a dc power supply? I have charged battery red to + and black to - (V set to 3.7 and I set to 1A). Can it be possible I tried to charge the battery in reverse polarity? But this would heat up/explode the battery no? | |
![]() | #2324 (permalink) | |
Bro only solder pads remove of that cap don't cut what i mark,i will show you what i did,it's a bit risky work. | |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
