Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 12-20-2011, 13:55   #2356 (permalink)
Wites OM Tesla's Avatar
Member: 1017374
Thanks Meter: 2,595
Originally Posted by poitelodico View Post
The phone hasn't water signs... may be is dropped but it seems no missing and/or no cracked parts inside.
I'm using with original charger and original USB cable.
I don't know if the last owner connected it to a china charger. Sorry
Chk voltages with battery charged after you press power on without lcd be careful to not short some coil to gnd.
Old 12-20-2011, 14:59   #2357 (permalink)
Crazy Poster
Member: 1445884
Just 2 (silly) questions:
1) How can I know if the battery is charged (or is charging) if I can't switch on the device and without any life sign?
2) How can I remove/desolder the metal frame from the PCB (I already removed the shield plates) without damages? any suggestions?
Old 12-20-2011, 15:04   #2358 (permalink)
Member: 1176031
Thanks Meter: 62
Answers:
1) Check battery with multimeter see if it's got around 3.9V
2) desolder them using a solder iron
Old 12-20-2011, 15:27   #2359 (permalink)
Member: 1017374
Thanks Meter: 2,595
Chk with multimeter if battery charged.
You don't need to remove metallic frames.
Old 12-20-2011, 16:02   #2360 (permalink)
Crazy Poster
Member: 1445884
I can't reach all test points if frames are present...
don't you think so?
Old 12-20-2011, 16:47   #2361 (permalink)
Member: 1017374
Thanks Meter: 2,595
don't you think so?
Ok then remove them be careful.
Old 12-20-2011, 18:59   #2362 (permalink)
Member: 1176031
Thanks Meter: 62
This is right.
By wites13 at 2011-12-20
Exactly these point checked and show continuity. So no problem here.
Pressed NVRam and took photo but still restarts.
Replaced with a good known battery and still restarts.
Restoring to custom firmware 3.1.3 at the moment where the apple power management was older. I will report later
Old 12-20-2011, 20:47   #2363 (permalink)
Member: 1017374
Thanks Meter: 2,595
Check this line if good.
By wites13 at 2011-10-27
Old 12-20-2011, 22:14   #2364 (permalink)
Member: 1176031
Thanks Meter: 62
Is that the Battery SWI line? (after checking the schema)
Old 12-20-2011, 23:19   #2365 (permalink)
Crazy Poster
Member: 1445884
I did the battery check and seems to be full charged (about 3.7 V).
I pressed power on and checked voltages (without lcd):
Vddsd1 = Vddsd2 = Vddsd3 = 0.7 V
but I must admit a trouble...
At first they where all at about 3.7 V but one of the probe, while I was doing the Vddsd1 measuring, has moved and touched the small part at the top of Vddsd1 (a glued condenser?) and all voltages fell to 0.7
The space is minimal and it's easy to move in a close part without any needs (I haven't removed the metal frame...)
What can I do now?
Old 12-20-2011, 23:39   #2366 (permalink)
Member: 1017374
Thanks Meter: 2,595
What can I do now?
Oh bro this not good you short some component check with battery if something not heating.
Old 12-20-2011, 23:40   #2367 (permalink)
Member: 1017374
Thanks Meter: 2,595
Thumbs up To limespirit.
Yes that is battery SWI line check if not broke.
Old 12-20-2011, 23:58   #2368 (permalink)
Crazy Poster
Member: 1445884
Nothing heating...
I checked by your method (lips)
Old 12-21-2011, 00:01   #2369 (permalink)
Member: 1017374
Thanks Meter: 2,595
Nothing heating...
Ok check green fuse for beep shorting with multimeter,if not beep that mean it burn inside you will need to jump it with wire.
To locate fuse look in upper photos.
Old 12-21-2011, 00:06   #2370 (permalink)
Crazy Poster
Member: 1445884
if you mean the batt fuse near the vibra motor, it beeps then I think is still good.
All Blackberry Hardware and Software Solution youssef01 BlackBerry (RIM) 34 11-01-2012 17:31
I need DVD player hardware and software solution site ..::MOBILES::.. GSM Mobile Links 0 04-05-2009 15:49
O2 Hardware and Software solutions Eagle7 Various 2 04-14-2006 12:47
Page generated in 0.23470 seconds with 10 queries
