![]() | #2581 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,595 | Quote:
![]() | #2582 (permalink) |
Crazy Poster ![]() ![]() ![]() Join Date: Dec 2009
Member: 1190812 Status: Offline Thanks Meter: 17 | iphone 4 on short hi...i have an iphone 4 on short...where i have to take a look at first? i have clean the board and there'arent any trace of water damage or broken component or burn... |
![]() | #2584 (permalink) |
Junior Member ![]() Join Date: Dec 2011
Member: 1704816 Status: Offline Thanks Meter: 1 | hello guys have a 3gs here having a slight problem with it.maybe someone can help me, it was water damaged.i have it powering on now..although dosnt seem to turn on via power button( tried it in another 3gs chasis same thing ) does turn on when connected to usb...so i wanted to update fw, it gets all the way through on phone goes to reboot then gives me error 29..now ive read this is battery related..but i have tried an 0435 in it..and get same error..i dont have the original battery for it..and do not know what the original battery was..have tried 2 diff batterirs in it..same error 29,also backlight is gone this woudnt affect an update would it? |
![]() | #2585 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: india Age: 55
Member: 125424 Status: Offline Thanks Meter: 21 | hi pls. help my ipod touch 4g water damage display is ok but display light not working, i tried with new display but same, pls. give any display light jumper ways i,ll greatful for help thx |
![]() | #2586 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2011 Location: Lithuania Age: 35
Member: 1593210 Status: Offline Thanks Meter: 1 | Hello guys, Hello Wites, Hello Limespirit, ![]() Today I got iPhone 3GS with no Touch function after it was dropped. It might sound easily, yes i tried most easiest way's new digitizer won't help. I'm confused, did not know where else need to look, for this problem, So' i;m asking you my friends, |
![]() | #2588 (permalink) | |
![]() | #2591 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2009 Location: Malta Age: 36
Member: 1176031 Status: Offline Thanks Meter: 62 | Hi Wites, I think I've got an easy question for you, but I'm confused what to remove first... So I've got this 3GS board which is getting really really hot when charging and also draining the battery while charging. So I opened it up and checked L9_AP charge coil and it was beeping then I checked the charge coil against the GND and it was shorting. I checked also the D1 diode (next to this charge coil) and it was also shorting. The question is which one do you think is bad, diode or charge coil? |
![]() | #2593 (permalink) | |
![]() | #2594 (permalink) | |
Member: 1176031 Status: Offline Thanks Meter: 62 | Quote:
I made a simple drawing to get a clear picture of what's the problem. Also I tried to unsolder both diode and coil but I can't is it hard to do so? Seems hard to reach solder melting point ![]() | |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
