02-04-2012, 14:29 | #2837 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,595 | Quote:
Also check with multimeter this filters if beep. | |
02-04-2012, 17:01 | #2838 (permalink) |
Crazy Poster Join Date: Nov 2010
Member: 1448091 Status: Offline Thanks Meter: 9 | i got an iphone 4 with waterdamage. cleaned with alcohol, replaced battery (3 times) and the usb connector. now its working fine except the battery drain. from 100% to 0% in about 10 hours. battery drains even when the phone is powered off and the charging needs longer than usual for 100%. the phone gets a little hotter than usual. i think the logicboard is short but i don't know where. can u help me there? thanks |
02-05-2012, 12:48 | #2840 (permalink) | |
If phone water damaged try this http://forum.gsmhosting.com/vbb/f631...ml#post8110607 | |
The Following User Says Thank You to Wites OM Tesla For This Useful Post: |
02-05-2012, 19:12 | #2841 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Birmingham U.K
Member: 251421 Status: Offline Sonork: 100.1609329 Thanks Meter: 439 | in your this picture can u explain mentioned part above. is this just one jumper or there are several jumpers. i cant see anything at the right where those component are. thanks in advance for your help. |
02-05-2012, 19:44 | #2842 (permalink) | |
If 2 black filters are missing make connection with wire in place of them. | |
02-06-2012, 12:50 | #2845 (permalink) | |
1.Resistor missing. 2.Removed pad goes directly to CPU no other pad to jump with wire. First you need find in board under removed pad coper dot to do this scratch the location to find it using an stereo microscope and solder that dot with flux. Then you will need resistor that have 66.5K and solder it to remain pad and to coper dot in board. Hope you understand and succeed in this hard work. | |
02-06-2012, 12:54 | #2846 (permalink) | |
Freak Poster Join Date: May 2008
Member: 769590 Status: Offline Thanks Meter: 16 | Quote:
When I find the track I'll post. | |
02-06-2012, 14:44 | #2847 (permalink) |
Insane Poster Join Date: Dec 2011
Member: 1702235 Status: Offline Thanks Meter: 5 | Wites, i have iphone 4 water damaged, it was regognized by itunes, but not charging i tryed several batteryes and few charging ports so the problem is in the mainboard. I tryed your second solution jumpers for battery charging (i found it in different post). So made jumpers from charging flex conector pins to the place u showed coz there was no shortcuts going. Now with jumpers its not regognised by pc (malfunction). Any ideas why it went so? or it might be the problem of 1 of those 2 ic? P.S. I checked my jumper very well they are not touching nothing else. P.P.S. I tryed your universall ic reball on nokia power ic and it went fine so big big thnx Regards, coldbox |
02-06-2012, 15:45 | #2848 (permalink) | |
02-06-2012, 17:00 | #2849 (permalink) |
Member: 1702235 Status: Offline Thanks Meter: 5 | Ok, i will remove, but then what can be the problem? It's even showing charging sign and fully reacts to charger (turns on then plugged in). Just battery goes down instead of going up. And mainboard does not heating up as well... there was corrosion in power ic area... Any ideas what can be wrong? Reagards, coldbox |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
