08-14-2013, 22:54 | #4336 (permalink) |
Registered User Join Date: Feb 2013
Member: 1886176 Status: Offline Sonork: 100.1662440 Thanks Meter: 4 | this happened with me second time first ipod was completely dead and now this turned on after replacing screen but when i put the metal part back screen went white i did power and home button solution as normal but ipod gone dead and its just doning this twice it came to white screen and when i try to button combination it does't come back to life. i connect it to computer but its not responding and i connect it with charger but nothing. some time board felt hot from the top side. did some one get any solution for this??????? Thanks in advance. |
08-15-2013, 07:16 | #4337 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: tbilisi, georgia Age: 33
Member: 1679251 Status: Offline Thanks Meter: 385 | Quote:
08-15-2013, 12:49 | #4339 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1958349 Status: Offline Thanks Meter: 7 | iphone 4g sim card and call problem hi sir, i have a problem in iphone 4g. its home key was'nt working properly. i replaced it, and after i assembled the phone, now when i insert or eject sim card the phone does'nt respond,and by reboot the sim is then recognised but when i make a call it do not connect any call, and also do not end the call. and if i make a call to this phone in doesnt respond. and while the other phone is ringing bell. thankyou.. |
08-15-2013, 13:14 | #4340 (permalink) | |
Member: 1886176 Status: Offline Sonork: 100.1662440 Thanks Meter: 4 | Quote:
08-15-2013, 14:13 | #4342 (permalink) |
Freak Poster Join Date: Jun 2005 Location: Slovenia Age: 43
Member: 155186 Status: Offline Sonork: 100.1590978 Thanks Meter: 39 | Hi, i have problem with 4S: if i measure continious on battery connector it is zero! That is mean i have one IC or capacitor dead. If i connect to charger it repeatedly shows apple logo. Can you please give me some advice, how to solve my problem. Thank you and have a nice day! |
08-16-2013, 11:49 | #4343 (permalink) |
Junior Member Join Date: Aug 2013
Member: 2003151 Status: Offline Thanks Meter: 0 | Hi! Could someone please help me. I got an iphone 3gs. I changed it's battery because of the puffy issue. I've replaced the battery and put everything back. But my iphone didn't turned on. I, then examined the board and observed that it was bent. I've clasped it with my hand to sort of unbend it and it worked. My problem now is that my iphone is taking very long for it to charge. Not only that, it has also killed the battery. I've replaced the battery 3x in a week. SOMEBODY PLEASE HELP ME. |
08-20-2013, 07:07 | #4344 (permalink) |
Junior Member Join Date: Dec 2012
Member: 1848748 Status: Offline Thanks Meter: 0 | Hello guys... I have a iphone 4 it has a problem no sound at all from speaker + headphone + mic and even the front camera is stuck at shutter animation and onething i can play music with bluetooth speaker I tried to change the audio flex cable but didnt work.. Please help |
08-20-2013, 19:21 | #4345 (permalink) |
Member: 1999993 Status: Offline Thanks Meter: 0 | Hello to everyone here. I have a problem with my iphone 3gs. Before 3 days it was working fine, but now won't turn on. I decided to open, and i found that the battery was damaged. So i decided to change the battery, but when i put a new battery and install the motherboard, the motherboard overheat enough to burn your hand. I have tried with 3 different batteries but same thing. I want to specify that the overheating zone is under the 5 and 6 connector, around the gps module. Please i want to know if this problem is repairable, if yes any instruction for that? Please tell me what to do. Thank you in advance |
08-21-2013, 09:55 | #4346 (permalink) |
Freak Poster Join Date: Jan 2011 Location: Serbia
Member: 1494989 Status: Offline Thanks Meter: 2 | iPhone 4s I have problem in iPhone 4s He works as the battery is removed. When press power button iphone start apple logo and after 5 seconds black screen, and auto power on and black screen, and auto power on and black screen, and auto power on and black screen ..........100 times Batery Ways is OK, I replace Battery but not solved. Any Solution? |
08-21-2013, 13:41 | #4347 (permalink) |
Junior Member Join Date: Jul 2011
Member: 1615921 Status: Offline Thanks Meter: 0 | I phone 4 totally dead, seems like a water damage, changed LCD and reassembled, still not working, with no indication of life. I will provide more details if I know what those details would be. |
08-23-2013, 15:02 | #4349 (permalink) | |
Member: 155186 Status: Offline Sonork: 100.1590978 Thanks Meter: 39 | Quote:
08-23-2013, 18:37 | #4350 (permalink) | |
Member: 1848748 Status: Offline Thanks Meter: 0 | Quote:
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
