11-07-2012, 14:35 | #3646 (permalink) |
Junior Member Join Date: Jun 2011
Member: 1607267 Status: Offline Thanks Meter: 6 | I've torn the iPhone down and took a look at everything pretty carefully and it seems perfect inside. Doesn't smell like burnt out parts or any visible damage anywhere. All the liquid damage indicators are pure white inside and outside in all the usual areas. The phone has a couple of dings in the bumpers but other than that it would be perfect. Like new out of the box perfect. The battery works and has some charge on it, tried even swapping out with a fully charged battery from another phone and nothing. Made sure all the connectors were firmly seated and all screws are accounted for and absolutely nothing is missing on the inside. Connected it to the computer with a bunch of different USB cables and it never charges or recognizes the device. There are no sounds, vibrations, nothing. Like it literally decided to just heel over and die without any warning. The only time I've ever seen a completely dead phone was because of water damage but then I've seem them resurrected before too. I replace screens for iPhones at my workplace so I know that this device is in pretty good condition and has no signs of what could've caused this abrupt non-working device. Sadly it's a recent replacement from Apple only a couple of months ago but it was out of warranty so the original owner paid the $150 replacement fee. I've tried everything I could think of including the hard reset, yanking the battery and leaving it out for a while and nothing works. It's completely lifeless. The backlight on the screen doesn't even turn on. What could be the issue? Can't seem to find anything on Google about this. |
11-07-2012, 22:17 | #3649 (permalink) |
Major Poster Join Date: Sep 2012 Age: 33
Member: 1811379 Status: Offline Thanks Meter: 4 | I have a problem... Hi everybody ... I do not know , How to update Iphone 3G , help me please ! PD: Everything I do at the end I get an error: 1015, 1060, 1061 Best Regards... |
11-09-2012, 19:52 | #3651 (permalink) |
Freak Poster Join Date: Feb 2011 Location: Northern Ireland
Member: 1514899 Status: Offline Thanks Meter: 49 | Hi, I have Iphone 4G which has No Service. Phone is locked with O2 UK. I try with O2 sim card and it says: Searching and then No Service. Everything inside the phone looks fine and phone was working before I changed the Digitizer. What could that be? |
11-13-2012, 15:44 | #3656 (permalink) |
Insane Poster Join Date: Jul 2005 Location: SCOTLAND
Member: 164780 Status: Offline Thanks Meter: 16 | Hi ihave changed the charging block and the home key on an iphone4 ios6.01 now it just hangs when i try calling out and wont end call, also when i try to call the iphone from another phone it rings on my phone but not the iphone, dose any one no of solution please. Thanks |
11-16-2012, 06:51 | #3657 (permalink) |
Freak Poster Join Date: May 2012
Member: 1756704 Status: Offline Thanks Meter: 14 | any solution How To Remove A Passcode Off an iPhone 5 any software to wipe my phone clean back to factory settings can not DFU Mode iphone 5 no recovery mode. When I restore&update via itunes (Window 7). It show error I try to exit from recovery mode by RecBoot, Tinyumbrella-6.00.01 and iReb. It not work and still recovery loop permantly. Would you suggest me about this issue. thank you |
11-16-2012, 15:59 | #3659 (permalink) |
Freak Poster Join Date: Jun 2010
Member: 1318873 Status: Offline Thanks Meter: 18 | my iphone is on but not respond charging . if i use empty battery it will charge until power on after power on battery percntage shos 4 percent and not respond charging. i changed small charging ic & that 2 coil still same any one can help me please |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
