09-27-2011, 05:50 | #1381 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2009 Location: Spain Europe
Member: 1102864 Status: Offline Sonork: 100.1681662 Thanks Meter: 854 | |
09-27-2011, 05:51 | #1382 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1629681 Status: Offline Thanks Meter: 0 | iphone 3g volume down not working First time poster. iPhone 3g water damaged. Volume up works, volume down not working. Changed flex cable still the same. DFU restore no help. I removed shields and cleaned MB with alcohol and tooth brush which got the vibration motor working. But still volume down not working. I need help. Thanks |
09-27-2011, 09:31 | #1383 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,595 | Quote:
By wites13 at 2011-09-27 | |
The Following User Says Thank You to Wites OM Tesla For This Useful Post: |
09-27-2011, 16:26 | #1386 (permalink) |
Junior Member Join Date: Sep 2011
Member: 1660407 Status: Offline Thanks Meter: 0 | My iPhone 3GS 32GB firmware 4.2.1 JB Modem Firmware is 05.16.02 I usually used my phone as testing parts sometime. Everything work fine except GPS Poor reception when using Tom Tom or Google Maps. I did test the new Wifi connector BUT still no luck to get the GPS working. Is there any chance that my iPhone missing some fuse/tracks then made my iPhone GPS not working pls? Any help would be appreciated. |
09-27-2011, 16:32 | #1387 (permalink) | |
Wifi signal is good? | |
09-27-2011, 16:45 | #1388 (permalink) | |
Member: 1660407 Status: Offline Thanks Meter: 0 | Quote:
Wifi Sigal is excellent. I also check all fuse next to wifi connector or sim card reader where all fine except the black fuse under the dock connector number 4. would that be the problems? It is because I did read your all photo show around dock connector that like only functional charging and sync. Hope you can help me You are very very PRO!! | |
09-27-2011, 16:48 | #1389 (permalink) | |
09-27-2011, 17:02 | #1391 (permalink) | |
Only show location at the first when use the apps. After showup correct location then keep poor reception. ONLY updated correct location sometime in Google maps. KEEP poor reception using TOMTOM BUt would show up correct location at startup. any idea? | |
09-27-2011, 17:28 | #1394 (permalink) | |
antenna connector. By wites13 at 2011-09-27 But this also might be an firmware or BB issue. | |
09-27-2011, 17:31 | #1395 (permalink) | |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
