Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 10-29-2010, 15:27   #1 (permalink)
Member: 1430325
Thanks Meter: 4
death machine T-01A(TG01)
Sorry, my English is poor ,This is translated by Google
I use the EPS file to unlock,can not boot after。
And later with the resurrection
Operations are as follows:
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.15, JTAG Manager Version: 1.19
Selected Resurrector: [Toshiba TG01]
Connecting to the dead body...OK
Detected dead body ID: 0x202400E1 - CORRECT!
Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at MAX]
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip ID: 0x00EC/0x55BC (512MB)
Unlocking the Phone...OK
Unlock complete!
Flashing the dead body...OK
Resurrection complete!
Now dead, can not boot normally
Connect pin A to pin B on phone and hold the power button, my T-01A dont start, no screen, no enter download mode ,no nothing.
Connect pin A to pin B on phone and hold the Reset button is the same.
Old 10-29-2010, 17:10   #2 (permalink)
Member: 322618
Thanks Meter: 5
To flash TG01 You need the following :
- TG Downloader
- TG USB Drivers
- TG Tool and TSW file or already decrypted bin file http://rapidshare.com/files/421984854/tg01.rar
Install TG Downloader and TG USB Drivers first, and reboot the PC.
Connect pin A to pin B on phone and hold the power button. Phone will enter download mode, Windows will find new device, and install drivers.
Start the TG Downloader with admin rights, and open the *.bin file. TG Downloader will report error with version, You need to press YES.
Now You need to select Toshiba DL port in port settings and after confimation, press “Download mode”.
Phone will be booted, and You can press “Download” now.
Now simply wait for download process to be finished.
Credits for this solution go to xda-developers portal!
The Following User Says Thank You to why_no For This Useful Post:
Old 10-30-2010, 04:32   #3 (permalink)
Member: 1430325
Thanks Meter: 4
- TG Downloader
- TG USB Drivers
Connect pin A to pin B on phone and hold the power button. Connect pin A to pin B on phone and hold the Reset button.
windows and no new device, that no response
Old 11-01-2010, 08:51   #4 (permalink)
dexter_mn's Avatar
Member: 311316
Thanks Meter: 41
TOSHIBA TG01 not powering on
hi supporter
after unlocked tg01 powering well but lock code changed
i trying hard reset but phone not ON
flashed,
again unlocked just show splash screen
again unlocked and flashed just blink green led
how to flash Toshiba_TG01_Unlocked_Full_backup.bin this file?
and which model select at factory downloader?
help me?
Old 11-01-2010, 11:55   #5 (permalink)
Member: 132968
Sonork: 100.1619307
Thanks Meter: 12
ok , i see
but y can flash it by usb cable flashing .please try again
Old 11-01-2010, 12:09   #6 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,276
http://forum.gsmhosting.com/vbb/f634...nuals-1051474/
Check full backup link, and also instructions how to restore full backup.
Old 11-03-2010, 10:26   #7 (permalink)
Member: 1430325
Thanks Meter: 4
I have a full backup before unlocking the 528M BIN file, I restore the backup, but my phone still can not boot, can not flash, no response
Old 11-03-2010, 10:39   #8 (permalink)
legija's Avatar
Member: 256342
Sonork: None
You need to check again how to set up settings for restoring full backup !
Old 11-03-2010, 10:53   #9 (permalink)
Member: 1430325
Thanks Meter: 4
- Switch to "DCC Read/Write" TAB
- Select "Access ROM1 Address Space"
- Check "Auto Fullflash size"
- In "main" field open desired backup file
- Check "Image Files use Used"
- Check "Flash files - are full Images"
- Click "Write Flash"
I'm sure the operation is correct
Old 11-03-2010, 10:55   #10 (permalink)
Member: 1430325
Thanks Meter: 4
It took 1 hours to play 100% write
Old 11-03-2010, 11:01   #11 (permalink)
Member: 1430325
Thanks Meter: 4
I heard T-01A board to pull a line to be used when the TG01.
But I do not know how to get there RIFF whether to support the T-01A.
If I write the official BIN file is feasible, but the BIN file was 248M
Headache
Old 11-03-2010, 12:47   #12 (permalink)
Member: 1430325
Thanks Meter: 4
Can you give me a T-01A's backup? Not the TG01's. Thank you!
Old 11-04-2010, 12:16   #13 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Hi,
Yes i have full Japanese version backup, so please contact me via PM for details.
Old 11-06-2010, 05:17   #14 (permalink)
Member: 1430325
Thanks Meter: 4
Hi,
I am waiting for your message
Old 11-20-2010, 19:08   #15 (permalink)
Member: 228559
Thanks Meter: 3
I am trying to write your full backup bat RIFF give me error:
ERROR: Image file size wrong. Main and Spare not correlate in size.
ver 1.19
P.S. dear mr. legia, I need full backup from Japanese T-01A too, pls give me...
The Following User Says Thank You to MudriC For This Useful Post:
Does Nk_calc working on AMD machine? goetze Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 11 03-01-2002 00:13
No more death Nokia phones!!!!!!!! Cyberdog Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-27-2002 23:24
Death 3210 (v???) iboboy Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 01-25-2002 20:56
Motorola T2288 DEath :(( Please help pali Motorola Old Legacy (EMMI) 3 01-07-2002 22:51
3310 v4.02 death nomestrano Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-30-2001 09:02
Page generated in 0.22879 seconds with 9 queries
