Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 09-13-2011, 22:48   #1 (permalink)
Member: 1065216
Thanks Meter: 91
Samsung t499 bricked/dead
hello, do you have any idea about this model
pinouts etc
samsung t499 ----bad phone
dies easily
Old 10-08-2011, 20:24   #2 (permalink)
Member: 1065216
Thanks Meter: 91
PLEASE ADD THIS MODEL TO unbrick, DOES NOT HAVE JTAG PINOUTS ON PCB, BUT maybe uart OR SOMETHING>?????
Old 11-22-2011, 17:03   #3 (permalink)
Member: 273013
Thanks Meter: 47
how to read full dump T499 Tmobile?
Dear legija
I used tab belong:
- Switch to "DCC Read/Write" TAB
- Select "Access ROM1 Address Space"
- Check "Auto Fullflash size"
- Click "Read Memory"
- When reading is finished, click "Save"
but
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.28, JTAG Manager Version: 1.37
Selected Resurrector: [MSM7227 L41 D08 OneNAND]
Connecting to the dead body...OK
Detected dead body ID: 0x203C00E1 - CORRECT!
Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at MAX]
Settings Code: 0x0000010010000000000000000027
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB)
WARNING: Resuming interrupted read from 0x0000218000, yet to read - 0x001FDE8000...
Reading FLASH1 address space from 0x0000218000 to 0x001FFFFFFF
Failed to receive answer to READ command.
Chosse samsung S5570 fail
Selected Resurrector: [Samsung S5570]
Detected dead body ID: 0x203C00E1 - WRONG!!!
ERROR: Current ID does not belong to the Samsung S5570 family.
Thx all!
Old 11-23-2011, 09:58   #4 (permalink)
Member: 273013
Thanks Meter: 47
T499 Dart dump fullflash to phone good
T499 readfullflash.rar
write to phone die but not ok
Pls help me!
Old 12-01-2011, 16:52   #5 (permalink)
Registered User
Member: 275731
Thanks Meter: 6
samsung t589 pin out for riff box
Old 12-01-2011, 19:16   #6 (permalink)
Member: 1065216
Thanks Meter: 91
did u revive samsung t499, need full firmware
Old 12-10-2011, 18:25   #7 (permalink)
Member: 1560521
Sonork: junioramaya2005
Thanks Meter: 9
samsung t499
please rocker team add the samsung t499
Old 12-15-2011, 02:34   #8 (permalink)
Member: 208759
Thanks Meter: 6
T499 dead, help me please.
Hello Rocker team!
I use Z3 read code and dead.
After, i dump fullflash from phone full ok (choose Qualcomm, MSM7227 L41) and reflash with dead phone but not work. Please add T499 now.
Thank you very much.
Old 02-06-2012, 16:40   #9 (permalink)
Member: 1002355
I am in the same situation, please Help
Old 02-06-2012, 20:36   #10 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,276
Hi,
This model JTAG port is under back sticker. It is standard Samsung 9pin JTAG port pinout.
Since it's based on MSM7227 CPU, You can use S5570 DLL for Read/Write access.
There is also full flash image available in Riff Data Exchange Plugin.
Old 02-10-2012, 22:21   #11 (permalink)
Member: 1002355
Ok thanks. I will try it, I will post results
Old 02-18-2012, 18:44   #12 (permalink)
cellcentersps's Avatar
Member: 1651353
Thanks Meter: 92
samsung t499 repair boot with riff
hello I have a samsung t499 and I repair it with riff but the model does not appear in the list of support.
but with the update of the s5570L riff out and let me know if will be liable to repair it with this model because it has the same jtag and have much in common..
Old 02-19-2012, 00:23   #13 (permalink)
Member: 1651353
Thanks Meter: 92
holla alguien que me ayude .
Old 02-21-2012, 23:33   #14 (permalink)
Member: 624768
Thanks Meter: 2
someone could do something with the t499 I have 2 dead one killed him and the other the z3x NsPro .... anyone know anything???????
Old 02-22-2012, 03:00   #15 (permalink)
GuilleC_PMA's Avatar
Member: 86124
Sonork: 100.1604943
Thanks Meter: 111
Riff not support this phone use another tool
NHE_8 wont work with NHEK5689.dll v3 steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-23-1999 15:48
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.20496 seconds with 10 queries
