01-18-2017, 16:54 | #2191 (permalink) |
Junior Member Join Date: Jan 2017 Location: India
Member: 2671768 Status: Offline Sonork: 100.1676645 Thanks Meter: 6 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.41 (RIFFBOX1), JTAG Manager Version: 1.63 Selected Resurrector: [Samsung N7000 V1.0.4860.58267] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 14.68GB Flashing the dead body...OK Resurrection complete! |
The Following User Says Thank You to style2345 For This Useful Post: |
12-24-2017, 11:59 | #2193 (permalink) |
Freak Poster Join Date: Apr 2011 Location: Armenia Yerevan
Member: 1559514 Status: Offline Thanks Meter: 49 | Samsung P5100 isp resturaction ehith jtag port is OK Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.49 (RIFFBOX1), JTAG Manager Version: 1.74 Connecting to the SD/eMMC Card...OK Set I/O Voltage reads as 1.79V, SD_CLK Frequency is 2 MHz Detected eMMC Chip, ID: 0x15/0x00 (MBG4GC), User Area Partition = 0x000747C00000 Bytes (29.12 GB) No Resurrection Data is available for the eMMC Chip with Capacity = 29.12 GB WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14.68 GB Flashing the dead body...OK Resurrection complete! |
The Following User Says Thank You to Varazdat For This Useful Post: |
01-06-2018, 04:02 | #2194 (permalink) |
Freak Poster Join Date: Nov 2005 Location: UK
Member: 196365 Status: Offline Thanks Meter: 35 | ZTE MF622 Repair done, please note, after repair device is turning on, but IMEI and all NVM area damaged, so always after repair need NVM backup/repair from another device. Thanks RIFF BOX Team for MF622 dll Code: [So 06-01-2018 01:40:25] [START OPERATION_ID = RESURRECT] [So 06-01-2018 01:40:36] Open serial port...OK [So 06-01-2018 01:40:36] Connecting to the RIFF Box...OK [So 06-01-2018 01:40:36] Firmware Version: 1.41 (RIFFBOX1), JTAG Manager Version: 1.63 [So 06-01-2018 01:40:36] Selected Resurrector: [USB Modem MF622 V1.00] [So 06-01-2018 01:40:36] [So 06-01-2018 01:40:36] Connecting to the dead body...OK [So 06-01-2018 01:40:36] Detected dead body ID: 0x200C00E1 - CORRECT! [So 06-01-2018 01:40:36] Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK [So 06-01-2018 01:40:36] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [So 06-01-2018 01:40:36] [So 06-01-2018 01:40:36] Resurrection sequence started. [So 06-01-2018 01:40:36] Establish communication with the phone...OK [So 06-01-2018 01:40:36] Uploading resurrector data into memory...OK [So 06-01-2018 01:40:36] Starting communication with resurrector...OK [So 06-01-2018 01:40:36] [So 06-01-2018 01:40:36] Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0078 (128MB) [So 06-01-2018 01:40:36] Flashing the dead body...OK [So 06-01-2018 01:40:36] Resurrection complete! [So 06-01-2018 01:40:36] [FINISH OPERATION_ID = RESURRECT] |
The Following User Says Thank You to mahcin For This Useful Post: |
04-03-2018, 23:45 | #2195 (permalink) |
Freak Poster Join Date: Oct 2007 Location: colombia
Member: 603138 Status: Offline Thanks Meter: 100 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.49 (RIFFBOX1), JTAG Manager Version: 1.77 Selected Resurrector: [HTC OneS (PJ4020000) V1.0.4926.47132] Connecting to the dead body...OK Detected dead body ID: 0x4F1F0F0F - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (K3U00M, 0x0003A3E00000 Bytes = 14.56 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (K3U00M, 0x000000200000 Bytes = 2.00 MB) Flashing the dead body...OK Resurrection complete! |
The Following User Says Thank You to jeilyscell For This Useful Post: |
06-29-2019, 14:36 | #2198 (permalink) |
No Life Poster Join Date: Aug 2014
Member: 2233266 Status: Offline Thanks Meter: 252 | samsung 7562 riff done Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.49 (RIFFBOX2), JTAG Manager Version: 1.71 Selected Package: [Samsung S7562 Total Repair V1.00 by <legija>] Connecting to the dead body...OK Detected dead body ID: 0x106230E1 Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (A00SJJ, 0x0000E9000000 Bytes = 3.64 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (A00SJJ, 0x000000100000 Bytes = 1.00 MB) Flashing the dead body...OK Package execution complete! |
The Following User Says Thank You to Yahia_Sb For This Useful Post: |
