12-31-2012, 17:50 | #1471 (permalink) |
No Life Poster Join Date: Jan 2005 Location: at work
Member: 112112 Status: Offline Sonork: 100.1621373 Thanks Meter: 238 | S5830i repair boot ok whit riff Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung S5830i V1.0.4476.13359] Connecting to the dead body...OK Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 3.00V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 8 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Selected Resurrection Data for the NAND Chip with Page size = 4KB Flashing the dead body...OK Resurrection complete! |
01-03-2013, 17:57 | #1472 (permalink) |
Freak Poster Join Date: Jan 2007 Location: DUBAI/UAE
Member: 430770 Status: Offline Sonork: 100.1611576 Thanks Meter: 238 | Samsung S5830i Stuck @ Samsung Done With Riff Samsung S5830i Stuck @ Samsung Done With Riff (Writting Full Dump). Full dump u can find it @ Riff Tracker Operation Logs: =========== Code: Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 2.99V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x27010000000000000000000020000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Resuming write FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF on 0x00000A640000 Completed in 00:21:15.422 (Average Transfer Rate: 423.92 kB/s) Regards, Tamer SiLver |
The Following User Says Thank You to MR/TAMER_SiLver For This Useful Post: |
01-04-2013, 19:38 | #1473 (permalink) |
Cheater -Don't Deal with him- Join Date: Mar 2006 Location: ACCRA GHANA Age: 39
Member: 244250 Status: Offline Sonork: 100.160773 Thanks Meter: 196 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I897 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x1BA00477 - CORRECT! Set I/O Voltage reads as 2.80V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Flashing the dead body...OK Resurrection complete! |
01-04-2013, 19:38 | #1474 (permalink) |
01-04-2013, 22:11 | #1475 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC OneS (PJ4020000) V1.0.4730.49418] Connecting to the dead body...OK Detected dead body ID: 0x204210E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (K3U00M, 0x0003A3E00000 Bytes = 14.56 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (K3U00M, 0x000000200000 Bytes = 2.00 MB) Flashing the dead body...OK Resurrection complete! |
01-06-2013, 21:32 | #1477 (permalink) |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung S6802 V1.0.4690.61628] Connecting to the dead body...OK Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0000/0x0015 (SJS00M, 0x0000E9000000 Bytes = 3.64 GB) Detected an Initialized FLASH2 Chip, ID: 0x0000/0x0015 (SJS00M, 0x000000100000 Bytes = 1.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 3,64GB Flashing the dead body...OK Resurrection complete! |
01-09-2013, 22:09 | #1479 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC ChaCha (PH0611000) V1.0.4745.47461] Connecting to the dead body...OK Detected dead body ID: 0x503C10E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 3 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00AD/0x55BC (512MB) Selected Resurrection Data for the NAND Chip with Page size = 2KB Flashing the dead body...OK Resurrection complete! |
01-09-2013, 22:09 | #1480 (permalink) |
01-11-2013, 11:03 | #1481 (permalink) |
No Life Poster Join Date: Mar 2005 Age: 44
Member: 129486 Status: Offline Thanks Meter: 66 | Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9100 V1.0.4724.60074] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.78V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 14.68GB Flashing the dead body...OK Resurrection complete! |
01-12-2013, 06:18 | #1482 (permalink) |
No Life Poster Join Date: May 2011 Location: india
Member: 1583254 Status: Offline Sonork: 100.1602320 Thanks Meter: 4,792 | Samsung b229 Done Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.47 Selected Target: [QSC1100, 1.80V, TAP0] Connecting to the QSC1100 target...OK Detected dead body ID: 0x122CE0E1 - IGNORED! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 8 MHz] Resetting and Halting target...OK R0 = 0x00019EB1 R6 = 0x00000001 R12 = 0x00028695 R1 = 0x00001C15 R7 = 0x80034000 R13 = 0x081114F0 R2 = 0x00001C15 R8 = 0x00000000 R14 = 0x00026DC9 R3 = 0x80002000 R9 = 0x00000000 R15 = 0x00199A72 R4 = 0x00000024 R10 = 0x0810FD34 CPSR = 0x20000033 R5 = 0x0806CE14 R11 = 0x00000000 Connecting to the NOR Memory based at 0x00000000...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x227A (8MB) Flashing directly the NOR Memory based at 0x00000000...OK Completed in 00:04:06.703 (Average Transfer Rate: 33.21 kB/s) |
01-12-2013, 12:41 | #1484 (permalink) |
Member deceased !! Join Date: Jan 2008 Location: DreamSunlock Canada,TH,CN,BD Age: 36
Member: 670820 Status: Offline Sonork: 100.1583728 Thanks Meter: 1,348 | Htc nexus repair done.. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC Nexus V1.00] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00AD/0x55BC (512MB) Flashing the dead body...OK Resurrection complete! |
01-13-2013, 13:14 | #1485 (permalink) |
Freak Poster Join Date: Oct 2001 Location: Earth
Member: 6884 Status: Offline Sonork: 100.1621477 Thanks Meter: 105 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9001 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x27B360E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0000 (M8G2FA, 0x0001CD000000 Bytes = 7.20 GB) Flashing the dead body...OK Resurrection complete! |
