same problem with trophy ( SPARK ) ???????????? |
same error on last manager :( Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.16, JTAG Manager Version: 1.29 Selected Resurrector: [Samsung Galaxy Tab] Connecting to the dead body...OK Detected dead body ID: 0x1BA00477 - CORRECT! Set I/O Voltage reads as 2.78V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: Wrong DCC data checksum. my p1000 still dead ... riffbox can not recovery p1000 !(recovery boot , but after flash - phone dead again , i try different firmwares, castoms ...) |
Galaxy tab P1000N,how can be repaired with riff??? |
GAlaxy tab P1000N flash file need........................plz Help |
after jatg n run new firmware by odin but still hang at samsung |
same problem to me................................... Hlp...........................plz |
How do I choose dump |
Any solution please , mibile boot damaged , galaxy tab wont power at all Connecting to the dead body...OK Detected dead body ID: 0x1BA00477 - CORRECT! Set I/O Voltage reads as 2.80V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: Wrong DCC data checksum. Connecting to the dead body...OK Detected dead body ID: 0x1BA00477 - CORRECT! Set I/O Voltage reads as 2.80V, TCK Frequency is 100 kHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: Wrong DCC data checksum. |
Please member replay this thread ! |
Please anyone give some advise to fix it Thanks |
i have the same plzzzzzzzzzzzzzzzzzzzz help |
hi guys ... do i have to connect the battry to mother board befor pressing Ressurection buttons Thanks |
help i install an arabic firmware in my p1000, now it won't connect to pc, just the download mode, :( what do i need to do? |
