Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 09-24-2012, 05:39   #46 (permalink)
Member: 1772418
Thanks Meter: 7
Originally Posted by legija View Post
1% is not same as in topic.
You'll have to replace eMMC !
How? I am using a T862 Rework station. If you could please give a hint on how you've done it, currently i am using 270 degrees C.
Old 09-24-2012, 11:47   #47 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,276
It's quite simple:
1. Remove not working part and clean the PCB
2. Place working part and apply flux
3. Apply heat over it while protecting surrounding components by metal shields
As for temp. settings, You should try to get some datasheets for specific component to see what range is allowed.
The Following User Says Thank You to legija For This Useful Post:
Old 09-25-2012, 13:49   #48 (permalink)
musmankhurshi's Avatar
Member: 166223
Sonork: 100.1587956
Thanks Meter: 36
really nice of u riff box
riff box always best for jtag
i repair with this method 100% ok i9100
i9100/n70000 Programming Error at 0x000000000000 Solution!
good for all
m usman k
Old 09-30-2012, 17:01   #49 (permalink)
Member: 1584592
Thanks Meter: 2
Connecting to the dead body...OK
Detected dead body ID: 0x4BA00477 - CORRECT!
Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000035
ERROR: Selected FLASH Chip was not initialized by the DCC Loader.
Old 09-30-2012, 17:03   #50 (permalink)
Member: 1584592
Thanks Meter: 2
please help me all of grate friends quickly
Old 10-03-2012, 01:05   #51 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
This is eMMC Chip fault(if you sure about connection)
For 99.9% You need replace it
But Maybe fix by heating or maybe reball can help....
Old 10-04-2012, 17:50   #52 (permalink)
melgsm's Avatar
Member: 629039
Sonork: 100.112945
Thanks Meter: 847
i have this problem i do all step and phone still dead boot
phone damage after flash with i9100g 100% software problem
Old 10-04-2012, 17:51   #53 (permalink)
melgsm's Avatar
Member: 629039
Sonork: 100.112945
Thanks Meter: 847
i make this method with another i9100 and work fine but this is another phone not work on it all steps gone ok no problem and after this same still dead
Old 10-09-2012, 12:23   #54 (permalink)
Member: 318250
i change already tab 16gb emmc oso some,wtf
Old 10-19-2012, 02:53   #55 (permalink)
Member: 1827277
Sonork: 2300506
I9100 M250S I use the method you tried or not
Old 10-21-2012, 00:32   #56 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
Can you explain ,What is exactly problem?
Also,Which model you have ?
Old 10-24-2012, 17:48   #57 (permalink)
Member: 333519
Sonork: 100.1620327
Thanks Meter: 16
works perfect
thanks solution is 1000 per cent real
Old 10-28-2012, 21:37   #58 (permalink)
Member: 389862
Sonork: guy_askali
Thanks Meter: 54
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.34, JTAG Manager Version: 1.45
Selected Resurrector: [Samsung i9100 V1.0.4582.4854]
Restarting target (nRST Low then High)...OK
Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz
Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VIS00M, 0x0003AB400000 Bytes = 14.68 GB)
Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VIS00M, 0x000000080000 Bytes = 0.50 MB)
Flashing the dead body...
ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK
ERROR: Stopped due to multiple communication errors. Terminating at 0x000000000000
Resurrection 100% ok not complete i try to write boot bin
its also can't write
how to fix this problem
Old 10-29-2012, 06:14   #59 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
@ guy_askali
Please uncheck "DCC Loader USB Interface"
Check Power Connection(Battery or Power Supply) + USB Cable And TRY AGAIN
If Not Work:
Change Data Length to
0x0000 0000 4000.
Then write all 4 Step
Or,Please Contact Me Via Sonork
The Following User Says Thank You to BABAK NURI For This Useful Post:
Old 10-29-2012, 11:36   #60 (permalink)
Member: 389862
Sonork: guy_askali
Thanks Meter: 54
Originally Posted by BABAK NURI View Post
@ guy_askali
If Not Work:
0x0000 0000 4000.
Thank you for ur information
i change data length to
0x0000 0000 4000
than i write all 4 step its Completed
but phone not power up friend same condition
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-10-2014 12:35
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! spterminator Main Sales Section 2 08-13-1999 05:55
Upload / Download eeprom program for 51xx/61xx Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-07-1999 14:03
Page generated in 0.20614 seconds with 10 queries
