12-03-2012, 13:48 | #76 (permalink) |
Junior Member Join Date: Nov 2004 Age: 41
Member: 90381 Status: Offline Thanks Meter: 5 | Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. after replace eMMC & I have not this driver ( sec s5pc210 test b/d ) |
12-05-2012, 03:21 | #77 (permalink) |
Junior Member Join Date: Dec 2012
Member: 1848587 Status: Offline Thanks Meter: 0 | Just needed to ask the absolute pros one final question.. Wouldn't this new plugin from last week allow you guys to somehow fix many of the phones sticking a 1% due to the fact that it is non physical in nature but in fact just marked bad blocks ? ?? Please don't overlook the following information I am simply a novice guy asking if I can fix my phone with the right pro out there ? RIFF JTAG – eMMC Partition Table FullFlash Image Files Processing Plugin (eMMCDiskPartitions.dll) v2.00 « RIFF Box – JTAG Revolution RIFF JTAG Box FAQ - How to use QUALCOMM/Exynos eMMC EFI/PIT/MBR/EBR Partitioning plugin |
12-05-2012, 03:31 | #80 (permalink) |
Member: 1848587 Status: Offline Thanks Meter: 0 | Ohh and since : RIFF JTAG Box FAQ - How to use QUALCOMM/Exynos eMMC EFI/PIT/MBR/EBR Partitioning plugin Explains that we could in theory JTAG a .PIT : lets just say the EMMC is physically damaged, while on the XDA forum somewhere someone made a .PIT for the i9100 which would readjust the image size to exclude the failing part of the EMMC from any partition layout. In my case the format failed early the 1% programming error and initially the phones data partition was at fault. So with a different .PIT through an image file via JTAG plugin this would be fixed no ? |
12-10-2012, 11:20 | #81 (permalink) |
Freak Poster Join Date: Oct 2001 Location: Moscow, Russia Age: 47
Member: 6653 Status: Offline Sonork: 100.1597550 Thanks Meter: 26 | I won't understand that it for a problem. It can be restored programmatically or flash replacement is required ? Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung N7000 V1.0.4715.8614] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 14,68GB Flashing the dead body... WARNING: Programming Error (0x25) at 0x000000000000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000004000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000008000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000000C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000010000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000014000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000018000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000001C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000020000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000024000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000028000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000002C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000030000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000034000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000038000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000003C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001800000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001804000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001808000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000180C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001810000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001814000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001818000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000181C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001820000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001824000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001828000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000182C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001830000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001834000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001838000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000183C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001840000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001844000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001848000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000184C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001850000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001854000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001858000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000185C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001860000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001864000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001868000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000186C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001870000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001874000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001878000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000187C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001880000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001884000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001888000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000188C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001890000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001894000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001898000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000189C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018A0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018A4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018A8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018AC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018B0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018B4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018B8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018BC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018C0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018C4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018C8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018CC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018D0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018D4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018D8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018DC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018E0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018E4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018E8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018EC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018F0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018F4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018F8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018FC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001900000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001904000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001908000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000190C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001910000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001914000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001918000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000191C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001920000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001924000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001928000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000192C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001930000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001934000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001938000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000193C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A00000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A04000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A08000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A0C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A10000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A14000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A18000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A1C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A20000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A24000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A28000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A2C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A30000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A34000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A38000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A3C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A40000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A44000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A48000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A4C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A50000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A54000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A58000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A5C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A60000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A64000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A68000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A6C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A70000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A74000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A78000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A7C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A80000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A84000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A88000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A8C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A90000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A94000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A98000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A9C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AA0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AA4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AA8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AAC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AB0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AB4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AB8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001ABC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AC0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AC4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AC8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001ACC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AD0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AD4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AD8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001ADC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AE0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AE4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AE8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AEC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AF0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AF4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AF8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AFC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B00000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B04000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B08000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B0C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B10000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B14000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B18000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B1C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B20000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B24000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B28000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B2C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B30000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B34000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B38000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B3C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C00000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C04000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C08000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C0C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C10000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C14000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C18000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C1C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C20000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C24000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C28000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C2C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C30000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C34000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C38000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C3C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C40000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C44000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C48000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C4C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C50000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C54000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C58000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C5C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C60000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C64000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C68000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C6C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C70000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C74000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C78000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C7C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C80000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C84000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C88000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C8C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C90000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C94000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C98000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C9C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CA0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CA4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CA8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CAC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CB0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CB4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CB8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CBC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023C0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023C4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023C8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023CC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023D0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023D4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023D8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023DC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023E0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023E4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023E8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023EC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023F0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023F4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023F8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023FC000 is handled as Cut Excess. ERROR: DCC Loader has reported Error Code = 0x3A (0x000000). Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x000000000001 |
12-11-2012, 11:49 | #83 (permalink) |
Insane Poster Join Date: Jan 2005 Age: 48
Member: 106154 Status: Offline Thanks Meter: 7 | N7000 not working ! Need full flash ! erase all flash !!! Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung N7000 V1.0.4715.8614] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.78V, TCK Frequency is 8 MHz Settings Code: 0x04010B00000000008000000000008000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Erasing FLASH1 memory from 0x000000000000 to 0x0003AB3FFFFF...OK Completed in 00:08:13.171 (Average Transfer Rate: 31203.52 kB/s) Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Erasing FLASH2 memory from 0x000000000000 to 0x00000007FFFF...OK Completed in 00:00:00.031 (Average Transfer Rate: 16516.13 kB/s) write boot7000.bin in 4 step ! Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.78V, TCK Frequency is 8 MHz Settings Code: 0x22020B00000000000000000000008000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Writting FLASH2 memory from 0x000000000000 to 0x000000007FFF Completed in 00:00:04.422 (Average Transfer Rate: 7.24 kB/s) Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Writting FLASH2 memory from 0x000000008000 to 0x00000000FFFF Completed in 00:00:04.469 (Average Transfer Rate: 7.16 kB/s) Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Writting FLASH2 memory from 0x000000010000 to 0x000000017FFF Completed in 00:00:04.344 (Average Transfer Rate: 7.37 kB/s) Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Writting FLASH2 memory from 0x000000018000 to 0x00000001FFFF Completed in 00:00:04.343 (Average Transfer Rate: 7.37 kB/s) RESURRECTION !!! Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung N7000 V1.0.4715.8614] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 14,68GB Flashing the dead body... WARNING: Programming Error (0x25) at 0x000000000000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000004000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000008000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000000C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000010000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000014000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000018000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000001C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000020000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000024000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000028000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000002C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000030000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000034000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000038000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000003C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001800000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001804000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001808000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000180C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001810000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001814000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001818000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000181C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001820000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001824000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001828000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000182C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001830000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001834000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001838000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000183C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001840000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001844000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001848000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000184C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001850000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001854000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001858000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000185C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001860000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001864000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001868000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000186C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001870000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001874000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001878000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000187C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001880000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001884000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001888000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000188C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001890000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001894000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001898000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000189C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018A0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018A4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018A8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018AC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018B0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018B4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018B8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018BC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018C0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018C4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018C8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018CC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018D0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018D4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018D8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018DC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018E0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018E4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018E8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018EC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018F0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018F4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018F8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018FC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001900000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001904000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001908000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000190C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001910000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001914000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001918000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000191C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001920000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001924000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001928000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000192C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001930000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001934000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001938000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000193C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A00000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A04000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A08000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A0C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A10000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A14000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A18000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A1C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A20000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A24000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A28000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A2C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A30000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A34000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A38000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A3C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A40000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A44000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A48000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A4C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A50000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A54000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A58000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A5C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A60000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A64000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A68000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A6C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A70000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A74000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A78000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A7C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A80000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A84000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A88000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A8C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A90000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A94000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A98000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A9C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AA0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AA4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AA8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AAC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AB0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AB4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AB8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001ABC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AC0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AC4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AC8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001ACC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AD0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AD4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AD8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001ADC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AE0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AE4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AE8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AEC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AF0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AF4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AF8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AFC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B00000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B04000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B08000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B0C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B10000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B14000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B18000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B1C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B20000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B24000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B28000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B2C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B30000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B34000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B38000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B3C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C00000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C04000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C08000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C0C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C10000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C14000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C18000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C1C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C20000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C24000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C28000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C2C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C30000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C34000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C38000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C3C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C40000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C44000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C48000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C4C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C50000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C54000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C58000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C5C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C60000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C64000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C68000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C6C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C70000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C74000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C78000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C7C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C80000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C84000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C88000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C8C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C90000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C94000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C98000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C9C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CA0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CA4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CA8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CAC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CB0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CB4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CB8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CBC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023C0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023C4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023C8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023CC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023D0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023D4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023D8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023DC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023E0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023E4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023E8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023EC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023F0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023F4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023F8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023FC000 is handled as Cut Excess. ERROR: DCC Loader has reported Error Code = 0x3A (0x000000). Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x000000000001 |
12-11-2012, 13:06 | #84 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | n7000 not working i hve same problem after customer update nw u cant repair it canr be flash chip how can it damaged with auto update WARNING: Programming Error (0x25) at 0x000000000000 is handled as Cut Excess. ERROR: DCC Loader has reported Error Code = 0x3E (0x007FFF <> 0x010000) |
12-29-2012, 09:37 | #87 (permalink) |
Junior Member Join Date: Apr 2008 Location: Zajecar,Serbia
Member: 748153 Status: Offline Thanks Meter: 1 | Hi to all,I have problem with n7000 when try Resurrection come this error,no DL-mode no power on,device manger show SEC S5PC210 Test B/D,any help is welcome. Thanx in advance Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung N7000 V1.0.4715.8614] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (000000, 0x000200000000 Bytes = 8.00 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (000000, 0x000000100000 Bytes = 1.00 MB) No Resurrection Data is available for the eMMC Chip with Capacity = 8.00GB WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14.68GB Flashing the dead body...OK WARNING: Programming Error (0x25) at 0x000000000000 is handled as Cut Excess. - - - WARNING: Programming Error (0x25) at 0x00000001C000 is handled as Cut Excess. Resurrection complete! Last edited by BABAK NURI; 12-31-2012 at 22:08. |
12-31-2012, 22:12 | #88 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi nikolanik87 You Did Try Replace eMMC and Used New eMMC With 8GB Size??? if no,,,This is exactly your problem: eMMC fault Quote:
But if This phone is 8GB as factory.....Please Connect phone to RIFF-Box,Then Contact Me Via Sonork I Need Check Your Phone Via RmoteHelper....Maybe we need edit latest DLL and Add resurrection data for 8GB eMMC... Thanks | |
01-05-2013, 19:45 | #89 (permalink) |
No Life Poster Join Date: Nov 2008 Location: saudi arabia
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | sir plz help,today i got a i9100,the phone was ok,i write only pit file ,and become dead can not go to download mode,so,i jtag it by riif,but result,is that..the given boot bin files write succesfullt,,but still can not go to download mod,,plz any idea |
01-05-2013, 19:52 | #90 (permalink) |
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [Samsung i9100 V1.0.4582.4854] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.80V, TCK Frequency is 8 MHz Settings Code: 0x22020B00000000001000000000008000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VIS00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VIS00M, 0x000000080000 Bytes = 0.50 MB) Writting FLASH2 memory from 0x000000001000 to 0x000000008FFF Completed in 00:00:09.875 (Average Transfer Rate: 3.24 kB/s) thats story |
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! | spterminator | Main Sales Section | 2 | 08-13-1999 05:55 |
Upload / Download eeprom program for 51xx/61xx | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-07-1999 14:03 |
