11-07-2012, 02:40 | #61 (permalink) |
Freak Poster Join Date: Jan 2005 Location: Look for me I'm not here ... n Age: 51
Member: 103786 Status: Offline Thanks Meter: 81 | Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - IGNORED! Set I/O Voltage reads as 2.80V, TCK Frequency is 4 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000048 ERROR: Selected FLASH Chip was not initialized by the DCC Loader. ??,,,, |
11-07-2012, 11:53 | #62 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
This is clear case of damaged eMMC Chip You need replace by new one | |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
11-12-2012, 16:20 | #64 (permalink) |
Freak Poster Join Date: Jun 2005 Location: Romania Age: 38
Member: 151737 Status: Offline Sonork: 100.1595988 Thanks Meter: 91 | everything is ok, good joob, phone bootloader write ok. After flash with odin is 100% done. Thanks. Last edited by BABAK NURI; 11-18-2012 at 11:21. Reason: no need quote first post |
The Following User Says Thank You to XHouser For This Useful Post: |
11-14-2012, 18:40 | #65 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Saudi Arabia
Member: 476075 Status: Offline Sonork: na Thanks Meter: 40 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.45 Selected Resurrector: [Samsung i9100 V1.0.4582.4854] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VIS00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VIS00M, 0x000000080000 Bytes = 0.50 MB) Flashing the dead body... WARNING: Programming Error (0x25) at 0x000000000000 is handled as Cut Excess. ERROR: DCC Loader has reported Error Code = 0x3E (0x007FFF <> 0x010000) any body help what problem is this. best regards. |
11-14-2012, 18:41 | #66 (permalink) |
11-18-2012, 14:28 | #69 (permalink) |
Member: 476075 Status: Offline Sonork: na Thanks Meter: 40 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.45 Selected Resurrector: [Samsung i9100 V1.0.4582.4854] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VIS00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VIS00M, 0x000000080000 Bytes = 0.50 MB) Flashing the dead body... ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Stopped due to multiple communication errors. Terminating at 0x000000000000 any help regarding this. best regards. |
11-19-2012, 23:59 | #70 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi tayyab007 You can repair your phone by method in first post Just try write boot.bin into Rom2 with "DCC Read/Write" page Or Contact me via sonork... |
11-23-2012, 12:16 | #71 (permalink) |
Freak Poster Join Date: Apr 2011 Location: Spain Barcelona
Member: 1558861 Status: Offline Sonork: aftabmiraj15 Thanks Meter: 4 | WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000048 ERROR: Selected FLASH Chip was not initialized by the DCC Loader. |
11-25-2012, 05:54 | #72 (permalink) | |
Why not search before posting...? This is clear case of dmaged eMMC Chip for 99/9%... 0.01% ,Check Soldered Wires | |
12-01-2012, 03:17 | #74 (permalink) | |
I Think Not,But You can test.. i did before,but never have 16GB,But 8or4GB not work,but 4or8 work on i9100g but can't make correct partition,so phone never have imei and baseband,also mass storage,,,of course i was repair mass storage,but efs problem still here --- just do it and report | |
12-01-2012, 15:42 | #75 (permalink) | |
Junior Member Join Date: Apr 2011
Member: 1554403 Status: Offline Thanks Meter: 0 | Quote:
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! | spterminator | Main Sales Section | 2 | 08-13-1999 05:55 |
Upload / Download eeprom program for 51xx/61xx | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-07-1999 14:03 |
