09-24-2012, 11:47 | #47 (permalink) | |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Quote:
1. Remove not working part and clean the PCB 2. Place working part and apply flux 3. Apply heat over it while protecting surrounding components by metal shields As for temp. settings, You should try to get some datasheets for specific component to see what range is allowed. | |
The Following User Says Thank You to legija For This Useful Post: |
09-25-2012, 13:49 | #48 (permalink) |
Freak Poster Join Date: Jul 2005 Location: pakistan Age: 45
Member: 166223 Status: Offline Sonork: 100.1587956 Thanks Meter: 36 | really nice of u riff box riff box always best for jtag i repair with this method 100% ok i9100 i9100/n70000 Programming Error at 0x000000000000 Solution! good for all m usman k Last edited by BABAK NURI; 10-03-2012 at 01:03. Reason: remove phone number |
09-30-2012, 17:01 | #49 (permalink) |
Junior Member Join Date: May 2011 Location: now a days i work in Saudi Ara
Member: 1584592 Status: Offline Thanks Meter: 2 | Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000035 ERROR: Selected FLASH Chip was not initialized by the DCC Loader. |
10-03-2012, 01:05 | #51 (permalink) | ||
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
This is eMMC Chip fault(if you sure about connection) For 99.9% You need replace it But Maybe fix by heating or maybe reball can help.... Quote:
10-04-2012, 17:51 | #53 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Egypt Age: 35
Member: 629039 Status: Offline Sonork: 100.112945 Thanks Meter: 847 | i make this method with another i9100 and work fine but this is another phone not work on it all steps gone ok no problem and after this same still dead |
10-28-2012, 21:37 | #58 (permalink) |
No Life Poster Join Date: Nov 2006 Location: maldives
Member: 389862 Status: Offline Sonork: guy_askali Thanks Meter: 54 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.45 Selected Resurrector: [Samsung i9100 V1.0.4582.4854] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VIS00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VIS00M, 0x000000080000 Bytes = 0.50 MB) Flashing the dead body... ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Stopped due to multiple communication errors. Terminating at 0x000000000000 Resurrection 100% ok not complete i try to write boot bin its also can't write how to fix this problem |
10-29-2012, 06:14 | #59 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | @ guy_askali Please uncheck "DCC Loader USB Interface" Check Power Connection(Battery or Power Supply) + USB Cable And TRY AGAIN If Not Work: Change Data Length to 0x0000 0000 4000. Then write all 4 Step Or,Please Contact Me Via Sonork --------------- |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
10-29-2012, 11:36 | #60 (permalink) | |
Member: 389862 Status: Offline Sonork: guy_askali Thanks Meter: 54 | Quote:
i change data length to 0x0000 0000 4000 than i write all 4 step its Completed but phone not power up friend same condition | |
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! | spterminator | Main Sales Section | 2 | 08-13-1999 05:55 |
Upload / Download eeprom program for 51xx/61xx | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-07-1999 14:03 |
