Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 05-15-2019, 07:38   #616 (permalink)
Member: 1043909
Thanks Meter: 60,926
Originally Posted by dennis_revan View Post
Dongle can't be found:
Card with specified AID is not found
Hello,
- Connect dongle/box to PC
- Run CardID software - https://www.infinity-box.com/support/?r=7
- Select Card-Reader
- Click to "Read" button
DO NOT send screenshot/video but copy/paste text from software window !
Old 05-23-2019, 17:33   #617 (permalink)
Gokuu2007's Avatar
Member: 712887
Sonork: gokuu2011
Thanks Meter: 349
please hep me thanks
Card-Reader: FT SCR2000 0
ATR: 3B7D95000080318065B0831148C883009000
Card Manager: A000000018434D00
SerialNumber: 0007976F
ROM:
Integrated Circuit Fabricator: 4250
Integrated Circuit Type: 3272
OS:
Identifier: 1291
Release Date: 6181
Release Level: 0700
EEPROM:
Fabrication Date: 3158
Serial Number: 0007976F
Batch Identifier: 2028
Module Fabricator: 1292
Module Packaging Date: 3268
IC Card Manufacturer: 2003
IC Em******* Date: 3268
Pre Personalizer: 2004
Pre Personalization Date: 3268
Pre Personalization Equipment Identifier: 00000044
Personalizer: 0000
Personalization Date: 0000
Personalization Equipment Identifier: 00000000
m_iopCard.Serial: 0007976F20281292
GP Version: 2.1.1
SCP Version: 1, Option: 5
Old 06-01-2019, 12:53   #618 (permalink)
Member: 2825476
sir i have copied the liecense but still dongal is not working
again ask me about liecense .
Old 06-06-2019, 12:33   #619 (permalink)
Member: 1043909
ROM:
OS:
Identifier: 1291
Release Date: 6181
Release Level: 0700
EEPROM:
Personalizer: 0000
GP Version: 2.1.1
Hi,
What is the problem with your dongle ?
Old 06-06-2019, 12:34   #620 (permalink)
Member: 1043909
Please double checknthat you have copied file well.
Do not change file name or file extension otherwise software can not find the file.
result ?
Old 06-08-2019, 06:16   #621 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 680
Nokia 130 flashing done
Open VPLfile : RM-1035_059W2D7_14.00.11.vpl
Description : RM-1035 059W2D7 IJ 14.00.11
DeviceType : RM-1035
ProductCode : 059W2D7
SoftwareVer : 14.00.11
PPM LangPack :
[1] : Urdu (Islamic Republic of Pakistan)
[2] : English (United Kingdom)
Load Ok!
Operation : Write FirmWare [ v1.16 ]
Setting : UserData erase : True
Setting : LangPack Only : False
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM Port (COM23)
MODE : NOKIA USB SERIAL
PORT : 23
BROM : Init BROM
BROM init passed!
CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000
BROM : SECCFG : 0x00000007
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : 35E18568D33EBA0EF42DC87EFB4CE5A5
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : CRYSTAL.14.00.11.p1
BOOT : SWR : 14.00.11
AGENT : Look for suitable BootChain in DA ...
AGENT : DEFAULT AUTO
AGENT : Found MT6260
AGENT : CRYSTAL.14.00.11.p1
BOOT : Sending 1st DA ...
BOOT : DA sent
BOOT : Transfer control to DA ...
DA : Sync Passed!
DA : Authentification pass!
DA : Agent : v03.02 on BBID : 0x8B
NOR: 00EF : 0040 : 0016 : 0000
NOR: [WINBOND] W25Q32BV
NOR:
TSIZE : 0x00400000 [ 4.00 MB ]
PSIZE : 0x00400000 [ 4.00 MB ]
STYPE : 0x00000000
FLOTP : DA_NOR_OTP_EXIST
STATUS : OK
BSTYLE : SF_FLASH_BOOT
Boot done!
VPL SoftwareVersion : 14.00.11 [RM-1035]
DEV SoftwareVersion : 14.00.11
SWInfo compare result : SAME
Load FlashSet :
MROM : RM-1035_CRYSTAL_ROM_eMP_14.00.11
LANG : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11
CUST : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11
JUMP : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11
VIVA : RM-1035_CRYSTAL_VIVA_eMP_14.00.11
Prepare FlashSet :
DCR : RM-1035_CRYSTAL_ROM_eMP_14.00.11
DCR : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11
DCR : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11
DCR : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11
DCR : RM-1035_CRYSTAL_VIVA_eMP_14.00.11
Prepare Target
SDS : OK : 0x003F4000 : 0x0000C000
FFS Format Ok!
CBR : 0x0000001A:0x00000001:0x00000000:0x00000000:0x0000 0010:0x00000002:0x00000000
Erase Target Flash
Erase done!
Write Target Flash
Write : RM-1035_CRYSTAL_ROM_eMP_14.00.11
Write : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11
Write : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11
Write : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11
Write : RM-1035_CRYSTAL_VIVA_eMP_14.00.11
Write done, waiting target response ...
Write flash done!
Verify Target FlashContent
Verify : RM-1035_CRYSTAL_ROM_eMP_14.00.11
Verify : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11
Verify : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11
Verify : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11
Verify : RM-1035_CRYSTAL_VIVA_eMP_14.00.11
Done!
Elapsed: 00:01:11
Reconnect Power/Cable!
The Following User Says Thank You to Luckey1 For This Useful Post:
Old 07-18-2019, 13:21   #622 (permalink)
Member: 540856
Thanks Meter: 14
Card serial: AFAB6310
Card type: BEST Dongle
Card password: *****
Link to my account: http://user.infinity-box.com
Login: 02AFAB6310
Connecting to server...
Error with message : HTTP/1.1 500 Access denied `02AFAB6310` Auth
what should i do now ?
Old 07-19-2019, 19:37   #623 (permalink)
Member: 130995
Thanks Meter: 35,227
Login: 02AFAB6310
Hello,
Please update [BEST] configuration file with your IOS Username/Password.
You should use the same user/pass you are using for web account login.
Instruction - https://www.infinity-box.com/support/?r=20&a=47
Old 07-25-2019, 10:16   #624 (permalink)
Member: 2394549
i had given the wrong email address to activate ,pliz help
Old 07-25-2019, 13:07   #625 (permalink)
Member: 1043909
Disable your PC Antivirus/Firewall or give enough access for BEST.exe !
- Close [BEST] software
- Install [BEST] software version 2.29 or higher !
- Go to c:/InfinityBox/BEST folder
- Delete License_best_xxxxxxxx.ask file
- Delete License_best_xxxxxxxx.dat file
- Run [BEST] software
- Enter your GOOD WORKING e-mail address and you will get new licence file via e-mail
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 07-29-2019, 08:54   #626 (permalink)
Member: 2336072
Sonork: 100.1662984
Thanks Meter: 23
Hello team
im forget best user name email
here my box sn 9d486267
pleas reset it
tnx in advance
Old 08-13-2019, 06:19   #627 (permalink)
GOK-TEPE's Avatar
Member: 119517
Thanks Meter: 119
disable Firewall unistall antivirus .Reinstall system. use workng Three mail adress can't solved problem.Create file *.dat file but 0 kb.Click create buton software freezin and not responding.change card reader same problem
Serial No (S/N): C5528B66
Firmware version: 0122.02
Pls help
[email protected] [email protected] [email protected]
Old 08-16-2019, 07:44   #628 (permalink)
Member: 1043909
Originally Posted by nightans View Post
Hello team
pleas reset it
tnx in advance
Hello,
How to get Username - https://www.infinity-box.com/support/?r=22
To reset password click here - https://www.infinity-box.com/support/?r=16&help=1
What is the result ?
Old 08-16-2019, 07:47   #629 (permalink)
Member: 1043909
Pls help
If software freez this means your PC can not connect to BEST server, it means Internet problem or firewall/antivirus problem.
Old 08-28-2019, 11:56   #630 (permalink)
Member: 2314884
Thanks Meter: 8
hi
ROM:
OS:
Identifier: 1291
Release Date: 6181
Release Level: 0700
EEPROM:
Fabrication Date: 3173
Serial Number: 0100965F
Batch Identifier: 2088
Module Packaging Date: 3269
IC Em******* Date: 3269
Pre Personalization Date: 3269
Personalizer: 0000
m_iopCard.Serial: 0100965F20881292
GP Version: 2.1.1
Page generated in 0.28246 seconds with 9 queries
