05-15-2019, 07:38 | #616 (permalink) | |
- Connect dongle/box to PC - Run CardID software - https://www.infinity-box.com/support/?r=7 - Select Card-Reader - Click to "Read" button DO NOT send screenshot/video but copy/paste text from software window ! | |
05-23-2019, 17:33 | #617 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 712887 Status: Offline Sonork: gokuu2011 Thanks Meter: 349 | please hep me thanks Card-Reader: FT SCR2000 0 ATR: 3B7D95000080318065B0831148C883009000 Card Manager: A000000018434D00 SerialNumber: 0007976F ROM: Integrated Circuit Fabricator: 4250 Integrated Circuit Type: 3272 OS: Identifier: 1291 Release Date: 6181 Release Level: 0700 EEPROM: Fabrication Date: 3158 Serial Number: 0007976F Batch Identifier: 2028 Module Fabricator: 1292 Module Packaging Date: 3268 IC Card Manufacturer: 2003 IC Em******* Date: 3268 Pre Personalizer: 2004 Pre Personalization Date: 3268 Pre Personalization Equipment Identifier: 00000044 Personalizer: 0000 Personalization Date: 0000 Personalization Equipment Identifier: 00000000 m_iopCard.Serial: 0007976F20281292 GP Version: 2.1.1 SCP Version: 1, Option: 5 |
06-06-2019, 12:33 | #619 (permalink) | |
What is the problem with your dongle ? | |
06-08-2019, 06:16 | #621 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 130 flashing done Open VPLfile : RM-1035_059W2D7_14.00.11.vpl Description : RM-1035 059W2D7 IJ 14.00.11 DeviceType : RM-1035 ProductCode : 059W2D7 SoftwareVer : 14.00.11 PPM LangPack : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.16 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM23) MODE : NOKIA USB SERIAL PORT : 23 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 35E18568D33EBA0EF42DC87EFB4CE5A5 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : CRYSTAL.14.00.11.p1 BOOT : SWR : 14.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : CRYSTAL.14.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0040 : 0016 : 0000 NOR: [WINBOND] W25Q32BV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 14.00.11 [RM-1035] DEV SoftwareVersion : 14.00.11 SWInfo compare result : SAME Load FlashSet : MROM : RM-1035_CRYSTAL_ROM_eMP_14.00.11 LANG : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11 CUST : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11 JUMP : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11 VIVA : RM-1035_CRYSTAL_VIVA_eMP_14.00.11 Prepare FlashSet : DCR : RM-1035_CRYSTAL_ROM_eMP_14.00.11 DCR : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11 DCR : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11 DCR : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11 DCR : RM-1035_CRYSTAL_VIVA_eMP_14.00.11 Prepare Target SDS : OK : 0x003F4000 : 0x0000C000 FFS Format Ok! CBR : 0x0000001A:0x00000001:0x00000000:0x00000000:0x0000 0010:0x00000002:0x00000000 Erase Target Flash Erase done! Write Target Flash Write : RM-1035_CRYSTAL_ROM_eMP_14.00.11 Write : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11 Write : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11 Write : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11 Write : RM-1035_CRYSTAL_VIVA_eMP_14.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1035_CRYSTAL_ROM_eMP_14.00.11 Verify : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11 Verify : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11 Verify : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11 Verify : RM-1035_CRYSTAL_VIVA_eMP_14.00.11 Done! Elapsed: 00:01:11 Reconnect Power/Cable! |
The Following User Says Thank You to Luckey1 For This Useful Post: |
07-18-2019, 13:21 | #622 (permalink) |
Insane Poster Join Date: Jul 2007
Member: 540856 Status: Offline Thanks Meter: 14 | Card serial: AFAB6310 Card type: BEST Dongle Card password: ***** Link to my account: http://user.infinity-box.com Login: 02AFAB6310 Connecting to server... Error with message : HTTP/1.1 500 Access denied `02AFAB6310` Auth what should i do now ? |
07-19-2019, 19:37 | #623 (permalink) | |
Please update [BEST] configuration file with your IOS Username/Password. You should use the same user/pass you are using for web account login. Instruction - https://www.infinity-box.com/support/?r=20&a=47 | |
07-25-2019, 13:07 | #625 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Disable your PC Antivirus/Firewall or give enough access for BEST.exe ! - Close [BEST] software - Install [BEST] software version 2.29 or higher ! - Go to c:/InfinityBox/BEST folder - Delete License_best_xxxxxxxx.ask file - Delete License_best_xxxxxxxx.dat file - Run [BEST] software - Enter your GOOD WORKING e-mail address and you will get new licence file via e-mail |
08-13-2019, 06:19 | #627 (permalink) |
Freak Poster Join Date: Feb 2005 Location: turkmenistan Age: 46
Member: 119517 Status: Offline Thanks Meter: 119 | disable Firewall unistall antivirus .Reinstall system. use workng Three mail adress can't solved problem.Create file *.dat file but 0 kb.Click create buton software freezin and not responding.change card reader same problem Serial No (S/N): C5528B66 Firmware version: 0122.02 Pls help [email protected] [email protected] [email protected] Last edited by GOK-TEPE; 08-13-2019 at 06:26. |
08-16-2019, 07:44 | #628 (permalink) | |
How to get Username - https://www.infinity-box.com/support/?r=22 To reset password click here - https://www.infinity-box.com/support/?r=16&help=1 What is the result ? | |
08-16-2019, 07:47 | #629 (permalink) | |
Disable your PC Antivirus/Firewall or give enough access for BEST.exe ! - Close [BEST] software - Install [BEST] software version 2.29 or higher ! - Go to c:/InfinityBox/BEST folder - Delete License_best_xxxxxxxx.ask file - Delete License_best_xxxxxxxx.dat file - Run [BEST] software - Enter your GOOD WORKING e-mail address and you will get new licence file via e-mail | |
08-28-2019, 11:56 | #630 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2314884 Status: Offline Thanks Meter: 8 | hi ROM: Integrated Circuit Fabricator: 4250 Integrated Circuit Type: 3272 OS: Identifier: 1291 Release Date: 6181 Release Level: 0700 EEPROM: Fabrication Date: 3173 Serial Number: 0100965F Batch Identifier: 2088 Module Fabricator: 1292 Module Packaging Date: 3269 IC Card Manufacturer: 2003 IC Em******* Date: 3269 Pre Personalizer: 2004 Pre Personalization Date: 3269 Pre Personalization Equipment Identifier: 00000044 Personalizer: 0000 Personalization Date: 0000 Personalization Equipment Identifier: 00000000 m_iopCard.Serial: 0100965F20881292 GP Version: 2.1.1 SCP Version: 1, Option: 5 |
