02-04-2018, 12:52 | #376 (permalink) |
Freak Poster Join Date: Aug 2015 Location: Choubara(Layyah Pakistan..)
Member: 2451856 Status: Offline Thanks Meter: 247 | Nokia 206 Rm872 write flash done by infinty best. Connect phone on selected interface... Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm872__04.52.mcusw PPM : rm872__04.52.ppm_m2 CNT : rm872__04.52.image_m2_059Q4J7 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 3572*********** IMEI 2 : 3572*********** PCcode : 059S8L3 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357298050333946_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm872__04.52.mcusw Image : rm872__04.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:02:26 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:29 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xFA4D ===Flashing [PPM]=== File : rm872__04.52.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:23 Write , Start : 0x41A80000 , Len : 0x003C68F0 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xC9E6 ===Flashing [CNT]=== File : rm872__04.52.image_m2_059Q4J7 Image : package_m2_059Q4J7.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:05:05 Write , Start : 0x42100000 , Len : 0x01040000 Flashing , wait ... Region flash done, time : 00:00:26 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip CRC check passed , 0x719B Flashing done! Total flash time : 00:09:13 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 04.52 30-06-13 RM-872 (c) Nokia IMEI: 3572************* PPM version : V 04.52 30-06-13 RM-872 (c) Nokia M2 Product code: 059S8L3 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:10:32 Connect phone on selected interface... |
The Following User Says Thank You to sanwal malik For This Useful Post: |
02-04-2018, 13:32 | #377 (permalink) |
Member: 2451856 Status: Offline Thanks Meter: 247 | Nokia 225 Rm1011 sec code remove done by format with infinty best. Nokia 225 Rm1011 sec code remove done by format with infinty best. Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 90 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : EE5D35C8EEC3E51C8664750038E6A6B6 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 Executing FFS FORMAT now... FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:34 Connect phone on selected interface... |
02-04-2018, 14:22 | #378 (permalink) |
No Life Poster Join Date: Apr 2014 Location: tripoli,libya Age: 36
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | nokia x2 rm-1013 hang on logo solved by flashing Code: Handshake Ok Init[0] : 0x01000000 Init[1] : 0x30000000 Sending Loader ... Init Loader ... FireHose Initialized Device Init Ok Target VER : 1 Target CPU : 8x10 Target FLN : eMMC Target CNF : 1000/C000/1000 Target DBG : logbuf@0xF8021118 fh@0xF801DF80 Files in Chain : 67 Flashing now Flashing : rm1013_2.1.0.12_user_NON-HLOS.bin ProgInit : start 16384, num 75203 ProgDone : Finished sector address 91587 Flash Ok Flashing : rm1013_2.1.0.12_user_sbl1.mbn ProgInit : start 147456, num 492 ProgDone : Finished sector address 147948 Flash Ok Flashing : rm1013_2.1.0.12_user_sbl1.mbn ProgInit : start 148480, num 492 ProgDone : Finished sector address 148972 Flash Ok Flashing : rm1013_2.1.0.12_user_sdi.mbn ProgInit : start 149504, num 45 ProgDone : Finished sector address 149549 Flash Ok Flashing : rm1013_2.1.0.12_user_emmc_appsboot.mbn ProgInit : start 180224, num 938 ProgDone : Finished sector address 181162 Flash Ok Flashing : rm1013_2.1.0.12_user_emmc_appsboot.mbn ProgInit : start 181248, num 938 ProgDone : Finished sector address 182186 Flash Ok Flashing : rm1013_2.1.0.12_user_rpm.mbn ProgInit : start 182272, num 296 ProgDone : Finished sector address 182568 Flash Ok Flashing : rm1013_2.1.0.12_user_rpm.mbn ProgInit : start 183272, num 296 ProgDone : Finished sector address 183568 Flash Ok Flashing : rm1013_2.1.0.12_user_boot.img ProgInit : start 196608, num 14549 ProgDone : Finished sector address 211157 Flash Ok Flashing : rm1013_2.1.0.12_user_tz.mbn ProgInit : start 229376, num 663 ProgDone : Finished sector address 230039 Flash Ok Flashing : rm1013_2.1.0.12_user_tz.mbn ProgInit : start 230376, num 663 ProgDone : Finished sector address 231039 Flash Ok Flashing : rm1013_2.1.0.12_user_system_1.img ProgInit : start 344064, num 262160 ProgDone : Finished sector address 606224 Flash Ok Flashing : rm1013_2.1.0.12_user_system_2.img ProgInit : start 606600, num 16 ProgDone : Finished sector address 606616 Flash Ok Flashing : rm1013_2.1.0.12_user_system_3.img ProgInit : start 610352, num 257992 ProgDone : Finished sector address 868344 Flash Ok Flashing : rm1013_2.1.0.12_user_system_4.img ProgInit : start 868352, num 16 ProgDone : Finished sector address 868368 Flash Ok Flashing : rm1013_2.1.0.12_user_system_5.img ProgInit : start 872104, num 258384 ProgDone : Finished sector address 1130488 Flash Ok Flashing : rm1013_2.1.0.12_user_system_6.img ProgInit : start 1130496, num 16 ProgDone : Finished sector address 1130512 Flash Ok Flashing : rm1013_2.1.0.12_user_system_7.img ProgInit : start 1130888, num 16 ProgDone : Finished sector address 1130904 Flash Ok Flashing : rm1013_2.1.0.12_user_system_8.img ProgInit : start 1134640, num 95712 ProgDone : Finished sector address 1230352 Flash Ok Flashing : rm1013_2.1.0.12_user_system_9.img ProgInit : start 1392640, num 16 ProgDone : Finished sector address 1392656 Flash Ok Flashing : rm1013_2.1.0.12_user_system_10.img ProgInit : start 1654784, num 16 ProgDone : Finished sector address 1654800 Flash Ok Flashing : rm1013_2.1.0.12_user_system_11.img ProgInit : start 1655176, num 16 ProgDone : Finished sector address 1655192 Flash Ok Flashing : rm1013_2.1.0.12_user_cache_1.img ProgInit : start 1777664, num 11376 ProgDone : Finished sector address 1789040 Flash Ok Flashing : rm1013_2.1.0.12_user_recovery.img ProgInit : start 1974272, num 15529 ProgDone : Finished sector address 1989801 Flash Ok Flashing : rm1013_2.1.0.12_user_misc_erase.img ProgInit : start 1998848, num 1 ProgDone : Finished sector address 1998849 Flash Ok Flashing : rm1013_2.1.0.12_059V790_001.custom_1.img ProgInit : start 2015232, num 262136 ProgDone : Finished sector address 2277368 Flash Ok Flashing : rm1013_2.1.0.12_059V790_001.custom_2.img ProgInit : start 2277376, num 16 ProgDone : Finished sector address 2277392 Flash Ok Flashing : rm1013_2.1.0.12_059V790_001.custom_3.img ProgInit : start 2277640, num 16 ProgDone : Finished sector address 2277656 Flash Ok Flashing : rm1013_2.1.0.12_059V790_001.custom_4.img ProgInit : start 2280856, num 258656 ProgDone : Finished sector address 2539512 Flash Ok Flashing : rm1013_2.1.0.12_059V790_001.custom_5.img ProgInit : start 2539520, num 16 ProgDone : Finished sector address 2539536 Flash Ok Flashing : rm1013_2.1.0.12_059V790_001.custom_6.img ProgInit : start 2542736, num 212792 ProgDone : Finished sector address 2755528 Flash Ok Flashing : rm1013_2.1.0.12_059V790_001.custom_7.img ProgInit : start 2801664, num 16 ProgDone : Finished sector address 2801680 Flash Ok Flashing : rm1013_2.1.0.12_059V790_001.custom_8.img ProgInit : start 2801928, num 16 ProgDone : Finished sector address 2801944 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_1.img ProgInit : start 2834432, num 80272 ProgDone : Finished sector address 2914704 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_2.img ProgInit : start 3096576, num 16 ProgDone : Finished sector address 3096592 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_3.img ProgInit : start 3097800, num 16 ProgDone : Finished sector address 3097816 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_4.img ProgInit : start 3358720, num 16 ProgDone : Finished sector address 3358736 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_5.img ProgInit : start 3620864, num 16 ProgDone : Finished sector address 3620880 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_6.img ProgInit : start 3622088, num 16 ProgDone : Finished sector address 3622104 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_7.img ProgInit : start 3883008, num 16 ProgDone : Finished sector address 3883024 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_8.img ProgInit : start 4145152, num 16 ProgDone : Finished sector address 4145168 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_9.img ProgInit : start 4146376, num 16 ProgDone : Finished sector address 4146392 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_10.img ProgInit : start 4407296, num 16 ProgDone : Finished sector address 4407312 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_11.img ProgInit : start 4669440, num 16 ProgDone : Finished sector address 4669456 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_12.img ProgInit : start 4670664, num 16 ProgDone : Finished sector address 4670680 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_13.img ProgInit : start 4931584, num 16 ProgDone : Finished sector address 4931600 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_14.img ProgInit : start 5193728, num 16 ProgDone : Finished sector address 5193744 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_15.img ProgInit : start 5194952, num 16 ProgDone : Finished sector address 5194968 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_16.img ProgInit : start 5455872, num 16 ProgDone : Finished sector address 5455888 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_17.img ProgInit : start 5718016, num 16 ProgDone : Finished sector address 5718032 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_18.img ProgInit : start 5980160, num 16 ProgDone : Finished sector address 5980176 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_19.img ProgInit : start 6242304, num 16 ProgDone : Finished sector address 6242320 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_20.img ProgInit : start 6504448, num 16 ProgDone : Finished sector address 6504464 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_21.img ProgInit : start 6766592, num 16 ProgDone : Finished sector address 6766608 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_22.img ProgInit : start 7028736, num 16 ProgDone : Finished sector address 7028752 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_23.img ProgInit : start 7290880, num 16 ProgDone : Finished sector address 7290896 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_24.img ProgInit : start 7553024, num 16 ProgDone : Finished sector address 7553040 Flash Ok Chain finished, All files flashed! Rebooting phone now Flashing done! Total flash time : 00:04:17 |
The Following User Says Thank You to helpo For This Useful Post: |
02-05-2018, 16:54 | #379 (permalink) |
Member: 2451856 Status: Offline Thanks Meter: 247 | Nokia 2700c Rm561 write flash done by infinty best... Nokia 2700c Rm561 write flash done by infinty best... Connect phone on selected interface... Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm561__09.98.mcusw PPM : rm561__09.98.ppm_mh CNT : rm561__09.98.image_mh_blac Flashing phone now... [Gen] Rules accepted for : RAP3x Generation Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1C700208686B6350BB0F32DF875CC9CF26CDA2B1 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:00 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ===Flashing [MCU]=== Erase : Processing rm561__09.98.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:34 Write : Processing rm561__09.98.mcusw Total 1256 [1256/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:59 MCU Write done ===Flashing [PPM]=== Erase : Processing rm561__09.98.ppm_mh Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:04 Write : Processing rm561__09.98.ppm_mh Total 399 [399/0/0] blocks to write, writing... TIME : Write time : 00:00:19 PPM Write done ===Flashing [CNT]=== Erase : Processing rm561__09.98.image_mh_blac Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:06:33 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm561__09.98.image_mh_blac Total 504 [504/0/0] blocks to write, writing... TIME : Write time : 00:00:28 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:12:01 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 2700 classic Software Info: V 09.98 06-09-10 RM-561 (c) Nokia IMEI: 3569************ PPM version : V 09.98 06-09-10 RM-561 (c) Nokia MH Product code: 0579325 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Check and Upload User Certificates ... Total - 0 certs Uploading User Certificates... Uploaded 26 certs! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:13:09 Connect phone on selected interface... |
02-06-2018, 08:26 | #380 (permalink) |
Member: 2451856 Status: Offline Thanks Meter: 247 | Nokia 230 security code remove done by infinty best... Nokia 230 security code remove done by great infinty best... Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 95 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 9619481CD8F76A98C3843EDC0C7CEEC4 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DOHA.10.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Doha.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 Executing FFS FORMAT now... FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:30 Connect phone on selected interface... |
02-06-2018, 12:24 | #381 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 206 write flash file Done :) Code: Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading MMC password... password not set :( Reading Phone Info.... Connected phone - 206 Software ver : V 04.52 30-06-13 RM-872 (c) Nokia IMEI 1 : 355726067091000 IMEI 2 : 355726067091018 XappVer : 000008F2 PPM : V 04.52 30-06-13 RM-872 (c) Nokia M2 CNT : Content: m2_059Q4J7 V 04.52 17-04-14 RM-872 (c) Nokia Product SN : 6F4E331BH Product code : 059Q4J7 Base Prd.code: 059P6H2 Module code : 0205283 Long Prod.SN : 0 Hardware info======= HWID : 1601 Battery: 4990 mV CMT BT: 19b5-22012 LCDVer: TPO Lock info =========== IMEI : 355726067091000 IMEI spNet : 3A 55 27 06 76 90 01 00 IMEI svNet : 33 55 27 06 76 90 01 10 F1 Sl Conf : 001-01-00000000000 Sl Prof : 800000000004000-B Sl Aux : 000B0000 Hw Sig : E19991018B4C9AC9 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Error collect lock info, try again CRT308 Backup Created CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL30 (20 digit) phone detected... User Code : 78521 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm872__04.52.image_m2_059V0F5 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok CMLA Key read ... Ok Reboot.... -> If Phone start charge - just reinsert battery fast Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 355726067091000 IMEI 2 : 355726067091018 PCcode : 059Q4J7 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : F:\1+Flashing Software\1+Infinity Box\BEST\Backup\Cert\355726067091000_XG213.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [CNT]=== File : rm872__04.52.image_m2_059V0F5 Image : package_m2_059V0F5.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:01:10 Write , Start : 0x42100000 , Len : 0x01040000 Flashing , wait ... Region flash done, time : 00:00:23 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0xA340 Flashing done! Total flash time : 00:01:35 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 04.52 30-06-13 RM-872 (c) Nokia IMEI: 355726067091000 PPM version : V 04.52 30-06-13 RM-872 (c) Nokia M2 Product code: 059Q4J7 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:02:31 Connect phone on selected interface... |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
02-07-2018, 07:07 | #382 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia X2-05 Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm772__08.60.mcusw PPM : rm772__08.60.ppm_m_a CNT : rm772__08.60.image_m_a_059H126 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 357406042782696 PCcode : 059H155 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357406042782696_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm772__08.60.mcusw Image : rm772__08.60.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x018C0000 Erasing, wait ... Erase done, time : 00:00:46 Write , Start : 0x40280000 , Len : 0x01840000 Flashing , wait ... Region flash done, time : 00:00:35 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x0746 ===Flashing [PPM]=== File : rm772__08.60.ppm_m_a Image : package_m_a.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41B40000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:09 Write , Start : 0x41B40000 , Len : 0x0046A330 Flashing , wait ... Region flash done, time : 00:00:05 CRC check passed , 0xA701 ===Flashing [CNT]=== File : rm772__08.60.image_m_a_059H126 Image : package_m_a_059H126.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42240000 , Len : 0x01BE0000 Erasing, wait ... Erase done, time : 00:00:58 Write , Start : 0x42240000 , Len : 0x00D00000 Flashing , wait ... Region flash done, time : 00:00:18 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x23F4 Flashing done! Total flash time : 00:03:00 Reboot phone now... Reading Phone Info.... Connected phone - X2-05 Software Info: V 08.60 21-12-11 RM-772 (c) Nokia IMEI: 357406042782696 PPM version : V 08.60 21-12-11 RM-772 (c) Nokia M_A Product code: 059H155 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 42 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:03:55 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following User Says Thank You to Luckey1 For This Useful Post: |
02-07-2018, 15:34 | #383 (permalink) |
No Life Poster Join Date: Jul 2009 Location: CHENNAI
Member: 1079392 Status: Offline Thanks Meter: 444 | Lumia 640 lte (rm-1073)network unlock done (at&t) WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Need SDAuth to finish ... Started Connecting to SX4 server... Connected SX4 enter .. SDAuth Ok! SX4 Disconnected Unlock Done! Wait for phone reboot ... Reboot Ok! Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to mmurugan1978 For This Useful Post: |
02-08-2018, 08:15 | #384 (permalink) |
Member: 2451856 Status: Offline Thanks Meter: 247 | Nokia 108 Rm944 hang on logo done by flashing with infinty best... Nokia 108 Rm944 hang on logo done by flashing with great infinty best... Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-944_ROM_eMP_20.06.11 VIVA : RM-944_VIVA_eMP_20.06.11 LANG : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 CUST : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 JMPT : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 90 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : A405F2E0D44806A438D28D850C707145 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Bree.20.06.11.p4 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_20.06.11 SecureDecrypt : RM-944_VIVA_eMP_20.06.11 SecureDecrypt : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 SecureDecrypt : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 SecureDecrypt : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 OVRLP : 000069B900000001 PHPID : Bree.20.06.11.p4 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-944_ROM_eMP_20.06.11 Write : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 Write : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 Write : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 Write : RM-944_VIVA_eMP_20.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-944_ROM_eMP_20.06.11 [VERIFY] DONE : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 [VERIFY] DONE : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 [VERIFY] DONE : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 [VERIFY] DONE : RM-944_VIVA_eMP_20.06.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:00:56 Reboot phone Ok Connect phone on selected interface... |
02-09-2018, 14:54 | #385 (permalink) |
No Life Poster Join Date: Jul 2014 Location: EARTH
Member: 2221849 Status: Offline Sonork: offline Thanks Meter: 279 | Nokia e5 rm-632 on off solved by flash NOKIA E5 RM-732 ON OFF SOLVED BY INFINTY BEST LOGS Code: Card found: S/N : A80D6572 , v0136 Registered to: master Connect phone on selected interface... Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm632_102.002_prd.core.fpsx PPM : rm632_102.002_25.01_MEA_A_prd.rofs2.fpsx PPM2 : rm632_102.002_C00.01_DEFAULT_prd.rofs3.fpsx CNT : rm632_102.002_U010.000_prd.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 1FD0010341DC03443F32354A22AB1AE4CC19A023 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00500020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 358631046305884 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358631046305884_CRT.rpl === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm632_102.002_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:03 Write : Processing rm632_102.002_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 433 blocks TIME : Write time : 00:00:19 MCU Write done ADL: Request programm status NAND status : 00000007 / 00000007 / 00000000 ===Flashing [PPM]=== Erase : Processing rm632_102.002_25.01_MEA_A_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm632_102.002_25.01_MEA_A_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 221 blocks TIME : Write time : 00:00:09 PPM Write done ADL: Request programm status NAND status : 00000007 / 00000007 / 00000000 ===Flashing [PPM2]=== Erase : Processing rm632_102.002_C00.01_DEFAULT_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm632_102.002_C00.01_DEFAULT_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 35 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000007 / 00000007 / 00000000 ===Flashing [CNT]=== Erase : Processing rm632_102.002_U010.000_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:03 Write : Processing rm632_102.002_U010.000_prd.uda.fpsx Total writen 97 blocks TIME : Write time : 00:00:06 CNT Write done ADL: Request programm status NAND status : 00000007 / 00000007 / 00000000 ADL: Close_Session Content: 000300000000070000000700000000 ADL: Reboot Flashing done! Total flash time : 00:00:44 Reboot phone now... Reading Phone Info.... Connected phone - Nokia E5-00 Software Info: V ICPR82_11w16.3.14 16-11-12 RM-632 (c) Nokia IMEI: 358631046305884 Ape Version: 102.002 Product code: 059H862 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Resetting LifeTimer Reset Done! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Phone disconected! Connect phone on selected interface... Elapsed: 00:02:45 Connect phone on selected interface... |
The Following User Says Thank You to Safyan sufi For This Useful Post: |
02-10-2018, 12:40 | #386 (permalink) |
Freak Poster Join Date: Nov 2010 Location: SOUTH AFRICA
Member: 1449328 Status: Offline Thanks Meter: 77 | Nokia 2 rm-1007 done Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 0B32630B ID_BLOCK_I : 009600E1 ID_BLOCK_L : A1AD487E6AE6DC6D4CF95A72C4FB3ED4 ID_BLOCK_L : B27EE96B9182AEE9035E6C872236DFE8 Use BEST Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Brand : Nokia ProdName : Dynamo_00WW ProdModel : Nokia 2 Device : E1M Manufact. : HMD Global NickName : Nokia 2 Dev Build : Dynamo_00WW-user 7.1.1 NMF26F 00WW_0_55B release-keys Dev CPU : MSM8909 Dev SKU : 600WW SKU Vendor: NOKIA SKU Locale: Worldwide SKU Carier: FIH Generic FRP State : ON ( ACTIVE ) Done! Elapsed: 00:00:16 Operation : Reset Settings [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 0B32630B ID_BLOCK_I : 009600E1 ID_BLOCK_L : A1AD487E6AE6DC6D4CF95A72C4FB3ED4 ID_BLOCK_L : B27EE96B9182AEE9035E6C872236DFE8 Use BEST Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:14 |
The Following 2 Users Say Thank You to pktel For This Useful Post: |
02-12-2018, 16:54 | #387 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 520 write factory firmware Done :) Code: Core : v2.29 , WP10x FlashEngine : v3.2 FFU : RM914_3058.50000.1425.0001_RETAIL_im_mea3_380_01_446538_prd_signed.ffu Checking FFU file, wait... FFU Revision ID : 2.0 FFU Model ID : Nokia.MSM8227.P6036 FFU RootKeyHash : F771E62AF89994064F77CD3BC16829503BDF9A3D FFU Languages : Albanian , Arabic , Azerbaijan(Latin) , Belorusian , Bulgarian , Catalan , Croatian , Czech , Danish (Denmark) , Dutch (Netherlands) , English (UK) , English , Estonian , Filipino (Philippines) , Finnish , French , German , Greek , Hwbre (Israel) , Hindi (India) , Hungarian , Indonesian , Italian , Japanese , Kazakh , Korean , Latvian , Lithuanian , Macedonian , Malay (Malaysia) , Norwegian (Bokmal , Norway) , Persian (Iran) , Polish , Portuguese(Brazil) , Portuguese(Portugal) , Romanian , Russian , sr-latn-rs , Chinese , Slovak , Slovenian , Spanish(Mexico) , Spanish , Swedish , Thai , Chinese(Taiwan) , Turkish , Ukrainian , Uzbekistan(Latin) , Vietnamese , FFU ChipSectors : 15155200 FFU Header : 0x000E0000 FFU Payload : 0x60040000 FFU FastVerify : Ok Waiting for phone... Dead mode is selected , no phone in normal mode found 1. Press and hold "Volume Down" 2. Insert USB cable 3. Hold button until phone will be detected Device catched in BOOT mode! Boot Mode confirmed! Setting Preloder Collect Info... Setting Application Setting Secure Collect Info... === Nokia Flash App info : Protocol Version : 1.15 Protocol Implementation : 1.28 === Phone Initial info : Phone RMxxx ID : RM-914 Phone Model ID : Nokia.MSM8227.P6036.1.2 Phone Model PC : 059S4H0 Phone IMEI : 357287058540214 === eMMC info : eMMC Vendor : Samsung eMMC CID : 0015 eMMC Size : 7456 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : F771E62AF89994064F77CD3BC16829503BDF9A3D === Other info : SD present : False Full Check skipped , will be checked by ImageSignature Battery Level : 65% RPMB Provision Status Code : 0x0101 Device RAM size : 512 MiB Device not have ATRP Backup to RAM Ok! FFU : RM914_3058.50000.1425.0001_RETAIL_im_mea3_380_01_446538_prd_signed.ffu Flashing FFU Sending FFU Header CertData Header sent , accepted :) Perform Data Partition Erase Erase done Sending FFU Payload Data... Finishing flashing Flashing done! Green Light :) Image Sent, processing PostFlash FinalConfig : abnormal status, error code : 0xFFFF0000 Make Factory Set : Ok Restore RAMBkp : Ok Update NVI from Image Ok , NVI will be updated on first boot! PostFlash Finished Total flash time : 00:03:09 Rebooting Connect phone on selected interface... Code: Phone found! WP10/WP8x Lumia Phone detected Read info... Ok === Main info === NCSD Version : 3.7 Sw Version : 3058.50000.1425.0001 IMEI : 357287058540214 ProductCode : 059S4H0 ProductSN : CUH059670 Module Code : 0205435 === HW info === Public ID : C9AE75F905DF6C5097AC1A4F366EBC072246FE90 HW Version : 1501 BT Addr. : 2CCC15E75724 Wlan Mac : 2CCC15E83B08 Battery Level : 72 % === Branding and security info === Operator : 000-PK SimLock : Unlocked SimLock : 2440700000000 Country : Finland Operator : NOKIA (Open) Branding : RM-914_im_mea3_380 Sec. Mode : Restricted Done! |
02-19-2018, 15:05 | #388 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 130 reset user code done :) Code: Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 25 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : A06980BB0AC175F007FA8E06B9461B80 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
02-19-2018, 15:06 | #389 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 225 write factory firmware Done :) Code: Phone found! MTKx Nokia Phone detected Read info... Ok Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1011_ROM_eMP_30.06.11 VIVA : RM-1011_VIVA_eMP_30.06.11 LANG : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001 CUST : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001 JMPT : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001 - > MODE : FullFlash Software Info: 21.00.11 00-00-00 RM-1011 IMEI: 356468060848982 PPM version : ER Product code: 059V5S7 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 35 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : E103366C977B14CBDF6E3D409EA312A9 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.21.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 SecureDecrypt : RM-1011_ROM_eMP_30.06.11 SecureDecrypt : RM-1011_VIVA_eMP_30.06.11 SecureDecrypt : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001 SecureDecrypt : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001 SecureDecrypt : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001 OVRLP : 000069B900000001 PHPID : PEARL.21.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1011_ROM_eMP_30.06.11 Write : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001 Write : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001 Write : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001 Write : RM-1011_VIVA_eMP_30.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1011_ROM_eMP_30.06.11 [VERIFY] DONE : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001 [VERIFY] DONE : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001 [VERIFY] DONE : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001 [VERIFY] DONE : RM-1011_VIVA_eMP_30.06.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:03:29 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds Wait, when phone will be ready ... Reading Phone Info.... Software Info: 30.06.11 00-00-00 RM-1011 IMEI: 356468060848982 Ape Version: NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM version : IJ Product code: 059V5S7 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... |
02-20-2018, 12:30 | #390 (permalink) |
Member: 2451856 Status: Offline Thanks Meter: 247 | Nokia 105 Rm1133 security code remove done with infinity best... Nokia 105 Dual sim Rm1133 security code remove done with infinity best... Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 3 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 8FFA84A00AD3526C958A4BF42C29BD0F BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : LAGOS61D.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Lagos.fg DA_VERIFY : 00 DA_JUMP : 00100000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000 Executing FFS FORMAT now... FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:26 Connect phone on selected interface... |
