04-23-2018, 09:59 | #436 (permalink) |
Freak Poster Join Date: Aug 2015 Location: Choubara(Layyah Pakistan..)
Member: 2451856 Status: Offline Thanks Meter: 247 | Nokia 150 Rm1190 security code remove done with infinty best... Nokia 150 Rm1190 security code remove done with infinty best... Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 3 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : E2B862B07F475E38D02BB05F5E6AA161 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DUBAI61D.11.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Dubai.fg DA_VERIFY : 00 DA_JUMP : 00100000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A0000-0x003F7FFF , LEN : 0x00058000 Executing FFS FORMAT now... FAT_RANGE : 0x003A0000-0x003F7FFF , LEN : 0x00058000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:22 Connect phone on selected interface... |
The Following User Says Thank You to sanwal malik For This Useful Post: |
04-26-2018, 06:47 | #437 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | Nokia 222 lock code remove done Hi Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 36 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 1B4E267FEEFB77B43CC192AA27ED4110 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
The Following User Says Thank You to profkefah For This Useful Post: |
04-28-2018, 16:46 | #438 (permalink) |
Freak Poster Join Date: Nov 2008 Age: 37
Member: 906256 Status: Offline Thanks Meter: 40 | nokia 6 remove frp ok Infinity-Box BEST Nokia [HMD] Module [NK2] v1.03 Operation : Reset Settings [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 430 [MSM8937] ID_BLOCK_S : 03A64FE5 ID_BLOCK_I : 0004F0E1 ID_BLOCK_L : DBC73204009CBA376693342CA28154BE ID_BLOCK_L : 260A7DFFE516D29D8FC218F35EAA4B64 Use BEST Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! When you will see ANDROID on screen make next steps : 1. Press and Hold both 'Vol_UP' and 'Power_On' keys 2. Hold them until device will reboot and show again ANDROID logo 3. Release 'Power_On' button, wait when color circle appear on screen! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
The Following User Says Thank You to artoor32 For This Useful Post: |
05-02-2018, 06:42 | #439 (permalink) |
Freak Poster Join Date: Jul 2013 Location: In your heart.
Member: 1973579 Status: Offline Thanks Meter: 30 | RM-914 dead recover done :) Connect phone on selected interface... Core : v2.29 , WP10x FlashEngine : v3.2 FFU : RM914_3058.50000.1425.0001_RETAIL_im_mea3_380_01_4 46538_prd_signed.ffu Checking FFU file, wait... FFU Revision ID : 2.0 FFU Model ID : Nokia.MSM8227.P6036 FFU RootKeyHash : F771E62AF89994064F77CD3BC16829503BDF9A3D FFU Languages : Albanian , Arabic , Azerbaijan(Latin) , Belorusian , Bulgarian , Catalan , Croatian , Czech , Danish (Denmark) , Dutch (Netherlands) , English (UK) , English , Estonian , Filipino (Philippines) , Finnish , French , German , Greek , Hwbre (Israel) , Hindi (India) , Hungarian , Indonesian , Italian , Japanese , Kazakh , Korean , Latvian , Lithuanian , Macedonian , Malay (Malaysia) , Norwegian (Bokmal , Norway) , Persian (Iran) , Polish , Portuguese(Brazil) , Portuguese(Portugal) , Romanian , Russian , sr-latn-rs , Chinese , Slovak , Slovenian , Spanish(Mexico) , Spanish , Swedish , Thai , Chinese(Taiwan) , Turkish , Ukrainian , Uzbekistan(Latin) , Vietnamese , FFU ChipSectors : 15155200 FFU Header : 0x000E0000 FFU Payload : 0x60040000 FFU FastVerify : Ok Waiting for phone... Dead mode is selected , no phone in normal mode found 1. Press and hold "Volume Down" 2. Insert USB cable 3. Hold button until phone will be detected Device catched in BOOT mode! Connect phone on selected interface... Connect phone on selected interface... Core : v2.29 , WP10x FlashEngine : v3.2 FFU : RM914_3058.50000.1425.0001_RETAIL_im_mea3_380_01_4 46538_prd_signed.ffu Checking FFU file, wait... FFU Revision ID : 2.0 FFU Model ID : Nokia.MSM8227.P6036 FFU RootKeyHash : F771E62AF89994064F77CD3BC16829503BDF9A3D FFU Languages : Albanian , Arabic , Azerbaijan(Latin) , Belorusian , Bulgarian , Catalan , Croatian , Czech , Danish (Denmark) , Dutch (Netherlands) , English (UK) , English , Estonian , Filipino (Philippines) , Finnish , French , German , Greek , Hwbre (Israel) , Hindi (India) , Hungarian , Indonesian , Italian , Japanese , Kazakh , Korean , Latvian , Lithuanian , Macedonian , Malay (Malaysia) , Norwegian (Bokmal , Norway) , Persian (Iran) , Polish , Portuguese(Brazil) , Portuguese(Portugal) , Romanian , Russian , sr-latn-rs , Chinese , Slovak , Slovenian , Spanish(Mexico) , Spanish , Swedish , Thai , Chinese(Taiwan) , Turkish , Ukrainian , Uzbekistan(Latin) , Vietnamese , FFU ChipSectors : 15155200 FFU Header : 0x000E0000 FFU Payload : 0x60040000 FFU FastVerify : Ok Waiting for phone... Dead mode is selected , no phone in normal mode found 1. Press and hold "Volume Down" 2. Insert USB cable 3. Hold button until phone will be detected Device catched in BOOT mode! Collect Info... === Nokia Flash App info : Protocol Version : 1.15 Protocol Implementation : 1.28 === Phone Initial info : Phone Model ID : Nokia.MSM8227.P6036.1.2 === eMMC info : eMMC Vendor : Hynix eMMC CID : 0090 eMMC Size : 7400 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : F771E62AF89994064F77CD3BC16829503BDF9A3D === Other info : SD present : False Full Check skipped , will be checked by ImageSignature Battery Level : 53% RPMB Provision Status Code : 0x0101 Device RAM size : 512 MiB Device not have ATRP Backup to RAM Ok! FFU : RM914_3058.50000.1425.0001_RETAIL_im_mea3_380_01_4 46538_prd_signed.ffu Flashing FFU Sending FFU Header CertData Header sent , accepted Perform Data Partition Erase Error : 06 : Data Partition Not Found! Seems as damaged Will Fix partitions by flash whole image Sending FFU Header CertData Header sent , accepted Skip Data Partition Erase Sending FFU Payload Data... Finishing flashing Flashing done! Green Light Image Sent, processing PostFlash FinalConfig : abnormal status, error code : 0xFF7F0000 Make Factory Set : Ok Restore RAMBkp : Ok Update NVI from Image Ok , NVI will be updated on first boot! PostFlash Finished Total flash time : 00:04:16 Rebooting Connect phone on selected interface... |
The Following 2 Users Say Thank You to bombinson For This Useful Post: |
05-10-2018, 08:35 | #440 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | NOKIA 5 TA-1053 DEAD FLASH RECOVER Done SUCCESSFULLY FLASH AND DEAD RECOVER LIFE BACK(NOKIA 5 TA-1053)USB THANKS INFINITY-BOX TEAM |
The Following User Says Thank You to gracy_elec For This Useful Post: |
05-13-2018, 19:03 | #442 (permalink) |
No Life Poster Join Date: Jun 2006 Location: UK
Member: 294200 Status: Offline Sonork: 100.1586184 Thanks Meter: 658 | Nokia 105 ta-1010 security code reset done with infinity NOKIA 105 TA-1010 SECURITY CODE RESET DONE WITH INFINITY Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 144 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 3BFD627524C7164D92D9C5D3DF30BE1D BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! ZUBAIR |
The Following User Says Thank You to zubairok For This Useful Post: |
05-15-2018, 13:04 | #443 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 130 (rm-1035) Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_11.00.11 VIVA : RM-1035_VIVA_eMP_11.00.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 23 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 0BBBFCB1CADD9E85A9F2BC5944BC4769 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_11.00.11 SecureDecrypt : RM-1035_VIVA_eMP_11.00.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_11.00.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_VIVA_eMP_11.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_11.00.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_VIVA_eMP_11.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:04 Reboot phone Ok |
The Following User Says Thank You to Luckey1 For This Useful Post: |
05-15-2018, 13:05 | #444 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 206 Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm872__04.52.mcusw PPM : rm872__04.52.ppm_m2 CNT : rm872__04.52.image_m2_059Q4J7 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 356324052097767 IMEI 2 : 356324052097775 PCcode : 059Q4J7 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\356324052097767_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm872__04.52.mcusw Image : rm872__04.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:04 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:01:55 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:31 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xFA4D ===Flashing [PPM]=== File : rm872__04.52.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:18 Write , Start : 0x41A80000 , Len : 0x003C68F0 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xC9E6 ===Flashing [CNT]=== File : rm872__04.52.image_m2_059Q4J7 Image : package_m2_059Q4J7.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:04:06 Write , Start : 0x42100000 , Len : 0x01040000 Flashing , wait ... Region flash done, time : 00:00:25 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:07 No write data, skip CRC check passed , 0x5521 Flashing done! Total flash time : 00:07:37 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 04.52 30-06-13 RM-872 (c) Nokia IMEI: 356324052097767 PPM version : V 04.52 30-06-13 RM-872 (c) Nokia M2 Product code: 059Q4J7 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:09:29 |
05-15-2018, 13:08 | #445 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 130 Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 38 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 5326503F4600B673DDD65C5F9B56FF55 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
05-15-2018, 13:10 | #446 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 230 format done Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 23 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 90E656955BE2E4E96CA98E0DAD6C91BE BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DOHA.13.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Doha.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 Executing FFS FORMAT now... FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:40 |
05-15-2018, 13:13 | #447 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 230 Flashing done Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1172_ROM_eMP_10.01.11 VIVA : RM-1172_VIVA_eMP_10.01.11 LANG : RM-1172_LANG_PACK_ROM_IC_eMP_10.01.11_001 CUST : RM-1172_CUSTPACK_ROM_IC_MEA_KW_eMP_10.01.11_001 JMPT : RM-1172_JUMP_TABLE_IC_MEA_KW_eMP_10.01.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 7 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 05E6CA4EDE8FE0E0A91D9DD108189BBB BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DOHA.10.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Doha.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 SecureDecrypt : RM-1172_ROM_eMP_10.01.11 SecureDecrypt : RM-1172_VIVA_eMP_10.01.11 SecureDecrypt : RM-1172_LANG_PACK_ROM_IC_eMP_10.01.11_001 SecureDecrypt : RM-1172_CUSTPACK_ROM_IC_MEA_KW_eMP_10.01.11_001 SecureDecrypt : RM-1172_JUMP_TABLE_IC_MEA_KW_eMP_10.01.11_001 OVRLP : 000069B900000001 PHPID : DOHA.10.01.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1172_ROM_eMP_10.01.11 Write : RM-1172_LANG_PACK_ROM_IC_eMP_10.01.11_001 Write : RM-1172_CUSTPACK_ROM_IC_MEA_KW_eMP_10.01.11_001 Write : RM-1172_JUMP_TABLE_IC_MEA_KW_eMP_10.01.11_001 Write : RM-1172_VIVA_eMP_10.01.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1172_ROM_eMP_10.01.11 [VERIFY] DONE : RM-1172_LANG_PACK_ROM_IC_eMP_10.01.11_001 [VERIFY] DONE : RM-1172_CUSTPACK_ROM_IC_MEA_KW_eMP_10.01.11_001 [VERIFY] DONE : RM-1172_JUMP_TABLE_IC_MEA_KW_eMP_10.01.11_001 [VERIFY] DONE : RM-1172_VIVA_eMP_10.01.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:03:19 Reboot phone Ok |
05-17-2018, 13:56 | #448 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia Asha 230 flashing done Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm986_14.0.6.mcusw.fls PPM : rm986_14.0.6_059V2Q3_m1.rofs.fls CNT : rm986_14.0.6_059V2Q3_m1.image.fls Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x16 IF xCPUID : XGOLD 221 [XMM2210 QIMING] IF uCHIPID : 194200021C030101CA8A1809820869F8F2811600FFFF IF Resp Data : 194200021C030101 Wait for user action : Insert battery Sending EBL Loader ... EBL Loader Ok EBL Loader ready Sending EBL ... EBL sent Ok EBL : 1_1336.500_MKEYSKEY QIMING EEP config Ok FLASHID : 52F00000 , [ NOR ] Boot conf set, Target Ready Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 359983051814204 IMEI 2 : 359983051814212 Phone Product Code : 059V2Q3 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\359983051814204_XG 221_CRT.rpl ===Flashing [MCU]=== Processing file : rm986_14.0.6.mcusw.fls Region count : 2 00 : [ PSI ] : rm986_14.0.6.mcusw.fls.fls 01 : [ Code ] : rm986_14.0.6.mcusw.fls.fls Parse done , flashing now Flash : 00 : rm986_14.0.6.mcusw.fls.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x40000000 , Len : 0x00020000 Erase done Region Start : 0x40000000 , Data Len : 0x00020000 Region Load done Wait for phone write all data ... Write done rm986_14.0.6.mcusw.fls.fls image flash done Flash : 01 : rm986_14.0.6.mcusw.fls.fls Sending Sec-Pack SecInfo Area : 0x0001 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x40040000 , Len : 0x00020000 Erase done Erase area 0x01 , Start 0x40060000 , Len : 0x00160000 Erase done Erase area 0x02 , Start 0x40340000 , Len : 0x023C0000 Erase done Erase area 0x03 , Start 0x47E00000 , Len : 0x00040000 Erase done Region Start : 0x40040000 , Data Len : 0x00020000 Region Load done Wait for phone write all data ... Write done Region Start : 0x40060000 , Data Len : 0x00160000 Region Load done Wait for phone write all data ... Write done Region Start : 0x40340000 , Data Len : 0x01E69954 Region Load done Wait for phone write all data ... Write done rm986_14.0.6.mcusw.fls.fls image flash done ===Flashing [PPM]=== Processing file : rm986_14.0.6_059V2Q3_m1.rofs.fls Region count : 1 00 : [ Cust ] : rofs_ebl_psi.fls Parse done , flashing now Flash : 00 : rofs_ebl_psi.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x42880000 , Len : 0x00F80000 Erase done Region Start : 0x42880000 , Data Len : 0x005EBE5C Region Load done Wait for phone write all data ... Write done rofs_ebl_psi.fls image flash done ===Flashing [CNT]=== Processing file : rm986_14.0.6_059V2Q3_m1.image.fls Region count : 1 00 : [ Cust ] : rm986_14.0.6_059V2Q3_m1.image.fls.image.fls Parse done , flashing now Flash : 00 : rm986_14.0.6_059V2Q3_m1.image.fls.image.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x43800000 , Len : 0x04600000 Erase done Erase area 0x01 , Start 0x47E40000 , Len : 0x000E0000 Erase done Region Start : 0x43800000 , Data Len : 0x02A60000 Region Load done Wait for phone write all data ... Write done rm986_14.0.6_059V2Q3_m1.image.fls.image.fls image flash done Flashing done! Total flash time : 00:02:07 Reboot phone now... Reading Phone Info.... Connected phone - 230 Software Info: V 14.0.6 10-07-14 RM-986 (c) Nokia IMEI: 359983051814204 PPM version : fad8cc0caecb31d1dae24dfac82405b7f6ee7a45 Product code: 059V2Q3 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 59 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:03:03 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
05-19-2018, 14:00 | #449 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 225 write firmware Done :) Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1011_ROM_eMP_30.06.11 VIVA : RM-1011_VIVA_eMP_30.06.11 LANG : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001 CUST : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001 JMPT : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 8 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : DA35A656ACD1BB3ED6A593DD4920CE63 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.20.10.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 SecureDecrypt : RM-1011_ROM_eMP_30.06.11 SecureDecrypt : RM-1011_VIVA_eMP_30.06.11 SecureDecrypt : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001 SecureDecrypt : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001 SecureDecrypt : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001 OVRLP : 000069B900000001 PHPID : PEARL.20.10.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1011_ROM_eMP_30.06.11 Write : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001 Write : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001 Write : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001 Write : RM-1011_VIVA_eMP_30.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1011_ROM_eMP_30.06.11 [VERIFY] DONE : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001 [VERIFY] DONE : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001 [VERIFY] DONE : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001 [VERIFY] DONE : RM-1011_VIVA_eMP_30.06.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:03:18 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds Wait, when phone will be ready ... Reading Phone Info.... Software Info: 30.06.11 00-00-00 RM-1011 IMEI: 357148062012063 Ape Version: NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM version : IJ Product code: 059V5V2 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
05-19-2018, 18:14 | #450 (permalink) |
Member: 294200 Status: Offline Sonork: 100.1586184 Thanks Meter: 658 | Hawk from ee unlock with infinity cm2mtk Operation : SP Unlock [ v2.00 r2 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM62) MODE : PRELOADER PORT PORT : 62 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO20.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100514531334D420DEEEC68DF6453 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE13MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 48406BEB74A119964DF130625D170C8F DA : USB : HIGH-SPEED Boot done! ID0 : Lock : Locked! | MNC : 768 | CNT : 3 | CODE : 12345678 ID1 : Lock : Not Locked! ID2 : Lock : Not Locked! ID3 : Lock : Not Locked! ID4 : Lock : Not Locked! ID5 : Lock : Not Locked! ID6 : Lock : Not Locked! Direct unlock done! Done! Elapsed: 00:00:16 ZUBAIR |
