Dragon Box Chinese Phone Tool |
09-11-2012, 08:15 | #1861 (permalink) |
No Life Poster Join Date: Nov 2007 Location: karachi pakistan
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Action=IMEI FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=11 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA04 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=353056248039617 IMEI=353056413716163 Rebulid IMEI1=353056173387311 Rebulid IMEI2=353056057346135 |
09-11-2012, 08:15 | #1862 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=IMEI FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=11 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA04 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=358688000000158 IMEI=358688000000158 Rebulid IMEI1=353056173387311 Rebulid IMEI2=353056057346135 |
09-11-2012, 08:16 | #1863 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=Format FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C8006000170000 NOR_Size=8MB NOR_Name=Unknown Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=11 TXD=16 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CE00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C8006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: 6252_C85E_ALX_GT11_MBO-GBEST_ML_A_V05 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00760000, size=0x000A0000 All Done |
09-11-2012, 08:16 | #1864 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C8006000170000 NOR_Size=8MB NOR_Name=Unknown Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=11 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CE00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C8006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: 6252_C85E_ALX_GT11_MBO-GBEST_ML_A_V05 |
09-11-2012, 08:17 | #1865 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=WriteFlash FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00800000 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\MBO M25 (6252) Project ID 6252_C85E_ALX_GT11_MBO-GBEST_ML_A_V03 Comport=COM2 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C8006000170000 NOR_Size=8MB NOR_Name=Unknown Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=11 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CE00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C8006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: 6252_C85E_ALX_GT11_MBO-GBEST_ML_A_V05 Changing baudrate to 921600... Done. Analysis the file, Some file may need a long time... The file has not been encrypted. Downloading Flash file... Pre format progress ... Done, downloading... All Done. |
09-11-2012, 08:17 | #1867 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=Format FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00800000 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\MBO M25 (6252) Project ID 6252_C85E_ALX_GT11_MBO-GBEST_ML_A_V03 Comport=COM2 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C8006000170000 NOR_Size=8MB NOR_Name=Unknown Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=11 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CE00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C8006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: 6252_C85E_ALX_GT11_MBO-GBEST_ML_A_V03 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00760000, size=0x000A0000 All Done |
09-11-2012, 08:17 | #1868 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=WriteFlash FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00800000 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\MBO M25 (6252) Project ID 6252_C85E_ALX_GT11_MBO-GBEST_ML_A_V03 Comport=COM2 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00EF006000170000 NOR_Size=8MB NOR_Name=SF_FM25Q32 NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=11 TXD=16 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CE00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: M10AW1108 Changing baudrate to 921600... Done. Analysis the file, Some file may need a long time... The file has not been encrypted. Downloading Flash file... Pre format progress ... Done, downloading... All Done. |
09-11-2012, 08:18 | #1869 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C8006000170000 NOR_Size=8MB NOR_Name=Unknown Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=11 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CC01 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C8006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: D5211_Z9_29_JAVA_S01 |
09-11-2012, 08:18 | #1870 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadFlash FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\D5211_Z9_29_JAVA_S01 Comport=COM2 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C8006000170000 NOR_Size=8MB NOR_Name=Unknown Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=11 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CC01 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C8006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: D5211_Z9_29_JAVA_S01 Changing baudrate to 921600... Done. Reading full Flash... CRC error: CRC=0841, CheckSum16=6B96 |
09-11-2012, 08:19 | #1871 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadFlash FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\D5211_Z9_29_JAVA_S01 Comport=COM2 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C8006000170000 NOR_Size=8MB NOR_Name=Unknown Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=11 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CC01 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C8006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: D5211_Z9_29_JAVA_S01 Changing baudrate to 921600... Done. Reading full Flash... Saved file to: C:\Documents and Settings\SAEED\Desktop\D5211_Z9_29_JAVA_S01 All Done. |
09-11-2012, 08:19 | #1872 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=Format FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\D5211_Z9_29_JAVA_S01 Comport=COM2 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C8006000170000 NOR_Size=8MB NOR_Name=Unknown Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=11 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CC01 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C8006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: D5211_Z9_29_JAVA_S01 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00768000, size=0x00098000 All Done |
09-11-2012, 08:19 | #1873 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=IMEI FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\D5211_Z9_29_JAVA_S01 Comport=COM2 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=11 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CC01 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=358688000000158 IMEI=358688000000158 Rebulid IMEI1=353056036794368 Rebulid IMEI2=353056077909084 |
09-11-2012, 08:20 | #1874 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=IMEI FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\D5211_Z9_29_JAVA_S01 Comport=COM2 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=358688670009100 IMEI=358688670009100 Rebulid IMEI1=353056036794368 Rebulid IMEI2=353056077909084 |
09-11-2012, 08:20 | #1875 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00EF004000150000 NOR_Size=2MB NOR_Name=Unknown Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=1 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF004000150000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: D5211D_NHX_A200_8_S03 |
