07-18-2017, 12:27 | #826 (permalink) |
No Life Poster Join Date: Dec 2013 Location: Uzbekistan/Tashkent
Member: 2082192 Status: Offline Sonork: not Thanks Meter: 1,119 | SM-T211 Boot repair via eMMC via Factory Repair Done! Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 Bus speed : 10 Connecting... Device : Samsung eMMC M8G1WA Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 1501004D3847315741006DE797A5A021 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : M8G1WA Product revision : 0.0 Product serial number : (hex) 6DE797A5 Manufacturing date : 10/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFE18E404029 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 2544640 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 212992 Number of sectors : 2945024 Device Manufacturer : samsung Device Platform : mrvl Build ID : JZO54K Display Build ID : JZO54K.T211XXAML1 Release ID : 4.1.2 Device Model : SM-T211 Device Name : lt023gxx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Build Description : lt023gxx-user 4.1.2 JZO54K T211XXAML1 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/M8G1WA_18_07_2017_15_23_55.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.9; FW: 1.19. P00: GPT (00000000, 00002000) P01: MRD (00002000, 00000800) P02: MRD_BK (00002800, 00000800) P03: BOTA0 (00003000, 00002000) P04: SBL2 (00005000, 00002000) P05: SBL (00007000, 00002000) P06: EFS (00009000, 00006000) P07: PARAM (0000F000, 00004000) P08: MODEM (00013000, 00006000) P09: KERNEL (00019000, 00006000) P10: RECOVERY (0001F000, 00006000) P11: MISC (00025000, 00005000) P12: NVM (0002A000, 00008000) P13: MEP (00032000, 00002000) P14: SYSTEM (00034000, 002CF000) P15: CACHE (00303000, 00064000) P16: HIDDEN (00367000, 00064000) P17: USER (003CB000, 00AC2000) Selected pit file: C:/TEMP/T211XXBNI1/LT02.pit Open file "C:/TEMP/T211XXBNI1/BL_T211XXBNI1_2667930_REV00_user_low_ship.tar.md5". Open file "C:/TEMP/T211XXBNI1/AP_T211XXBNI1_2667930_REV00_user_low_ship.tar.md5". Open file "C:/TEMP/T211XXBNI1/CP_T211XXBNI1_2667930_REV00_user_low_ship.tar.md5". Open file "C:/TEMP/T211XXBNI1/CSC_OXE_T211OXEBNI1_2667930_REV00_user_low_ship.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition PBL... Done. Switched to user area. Writing partition SBL2... Done. Writing partition SBL... Done. Writing partition PARAM... Done. Writing partition MODEM... Done. Writing partition KERNEL... Done. Writing partition RECOVERY... Done. Writing partition NVM... Done. Writing partition CACHE... Done. Writing partition HIDDEN... Done. Writing is finished. SW: 1.3.9; FW: 1.19. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 Bus speed : 10 Connecting... Device : Samsung eMMC M8G1WA Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 1501004D3847315741006DE797A5A021 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : M8G1WA Product revision : 0.0 Product serial number : (hex) 6DE797A5 Manufacturing date : 10/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFE18E404029 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 2544640 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 212992 Number of sectors : 2945024 Device Manufacturer : samsung Device Platform : mrvl Build ID : JZO54K Display Build ID : JZO54K.T211XXAML1 Release ID : 4.1.2 Device Model : SM-T211 Device Name : lt023gxx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Build Description : lt023gxx-user 4.1.2 JZO54K T211XXAML1 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/M8G1WA_18_07_2017_15_59_43.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.9; FW: 1.19. P00: GPT (00000000, 00002000) P01: mrd (00002000, 00000800) P02: mrd_bk (00002800, 00000800) P03: bota0 (00003000, 00002000) P04: sbl2 (00005000, 00002000) P05: sbl (00007000, 00002000) P06: efs (00009000, 00006000) P07: param (0000F000, 00004000) P08: modem (00013000, 00006000) P09: kernel (00019000, 00006000) P10: recovery (0001F000, 00006000) P11: misc (00025000, 00005000) P12: nvm (0002A000, 00008000) P13: mep (00032000, 00002000) P14: system (00034000, 002CF000) P15: cache (00303000, 00064000) P16: hidden (00367000, 00064000) P17: user (003CB000, 00AC3000) Disconnected. Last edited by Octopus box; 07-19-2017 at 06:27. |
The Following 2 Users Say Thank You to ddilshod93 For This Useful Post: |
07-18-2017, 14:31 | #827 (permalink) |
Freak Poster Join Date: Jun 2010 Location: Dubai
Member: 1334781 Status: Offline Sonork: 0010 Thanks Meter: 80 | SM-G530H Repair Done Welcome to Medusa Pro Software version 1.3.8. Started. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G530H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G530H_EMMC_P1J95K.srf Voltage : 2.0V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC QNW00M Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 150100514E5730304D000348EE49A14D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QNW00M Product revision : 0.0 Product serial number : (hex) 348EE49 Manufacturing date : 10/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 376832 Number of sectors : 3063808 Device Manufacturer : samsung Device Platform : msm8916 Build ID : LRX22G Display Build ID : LRX22G.G530HXXU2BPG1 Release ID : 5.0.2 Device Model : SM-G530H Device Name : fortuna3gxx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : fortuna3gxx-user 5.0.2 LRX22G G530HXXU2BPG1 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QNW00M_18_07_2017_18_22_31.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.8; FW: 1.18. P00: GPT (00000000, 00002000) P01: apnhlos (00002000, 00007800) P02: modem (00009800, 0001CB80) P03: sbl1 (00026380, 00000400) P04: ddr (00026780, 00000040) P05: aboot (000267C0, 00001000) P06: rpm (000277C0, 00000400) P07: qsee (00027BC0, 00000400) P08: qhee (00027FC0, 00000400) P09: fsg (000283C0, 00001800) P10: sec (00029BC0, 00000020) P11: pad (00029BE0, 00005420) P12: param (0002F000, 00005000) P13: efs (00034000, 00007000) P14: modemst1 (0003B000, 00001800) P15: modemst2 (0003C800, 00001800) P16: boot (0003E000, 00006800) P17: recovery (00044800, 00007800) P18: fota (0004C000, 00002802) P19: backup (0004E802, 000037EE) P20: fsc (00051FF0, 00001800) P21: ssd (000537F0, 00000010) P22: persist (00053800, 00004000) P23: persdata (00057800, 00004800) P24: system (0005C000, 002EC000) P25: cache (00348000, 00096000) P26: hidden (003DE000, 00005000) P27: userdata (003E3000, 00AACFD8) Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G530H_EMMC_P1J95K.srf". Write data verification is enabled. Writing GPT partition... Done. Writing apnhlos partition... Done. Writing modem partition... Done. Writing sbl1 partition... Done. Writing ddr partition... Done. Writing aboot partition... Done. Writing rpm partition... Done. Writing qsee partition... Done. Writing qhee partition... Done. Writing fsg partition... Done. Writing sec partition... Done. Writing pad partition... Done. Writing param partition... Done. Writing efs partition... Done. Writing modemst1 partition... Done. Writing modemst2 partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing fota partition... Done. Writing backup partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing persist partition... Done. Writing persdata partition... Done. Smart Repair is successfully complete. SW: 1.3.8; FW: 1.18. Disconnected. thankss Medusa team.......solved dead phone Last edited by Octopus box; 07-19-2017 at 06:26. |
The Following 2 Users Say Thank You to ilya_5665 For This Useful Post: |
07-27-2017, 06:29 | #828 (permalink) |
No Life Poster Join Date: Sep 2012 Location: ISLD Age: 36
Member: 1814771 Status: Offline Sonork: 100.1621347 Thanks Meter: 350 | LG F600L Successfully Repaired with Medusa Box LG F600L USB dead boot repair DONE (NO NEED TO OPEN ) W.O Battery connect usb cable http://s.pictub.club/2017/07/27/7GS1nx.jpg best regard Afridi gsm Last edited by Medusa Box; 07-27-2017 at 16:13. |
The Following User Says Thank You to Afridi gsm For This Useful Post: |
07-27-2017, 16:10 | #829 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Samsung G532g dead boot repair done Welcome to Medusa Pro Software version 1.3.8. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Hynix eMMC H8G4u Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 90014A4838473475920105D7F44044F7 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4u Product revision : 0.1 Product serial number : (hex) 5D7F440 Manufacturing date : 04/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 393216 Number of sectors : 6307840 Device Manufacturer : samsung Device Platform : mt6737t Build ID : MMB29T Display Build ID : MMB29T.G532GDXU1APJ5 Release ID : 6.0.1 Device Model : SM-G532G Device Name : grandppltedx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : grandppltedx-user 6.0.1 MMB29T G532GDXU1APJ5 release-keys Backup EXT_CSD saved to file C:/Program Files/GsmServer/Medusa/Medusa Pro Software/EXT_CSD Backups/H8G4u_27_07_2017_17_38_41.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.8; FW: 1.18. P00: GPT (00000000, 00002000) P01: BOTA0 (00002000, 00002000) P02: nvram (00004000, 00004000) P03: lk (00008000, 00001000) P04: BOTA1 (00009000, 00001000) P05: secro (0000A000, 00003800) P06: seccfg (0000D800, 00000400) P07: efuse (0000DC00, 00000400) P08: tee1 (0000E000, 00003000) P09: BOTA2 (00011000, 00003000) P10: EFS (00014000, 00004000) P11: nvdata (00018000, 00010000) P12: PARAM (00028000, 00004000) P13: recovery (0002C000, 00008000) P14: boot (00034000, 00008000) P15: md1img (0003C000, 00010000) P16: md1dsp (0004C000, 00002000) P17: keystore (0004E000, 00004000) P18: omekeystore (00052000, 00001C00) P19: proinfo (00053C00, 00001400) P20: para (00055000, 00000400) P21: PERSISTENT (00055400, 00000400) P22: STEADY (00055800, 00000800) P23: protect1 (00056000, 00004000) P24: protect2 (0005A000, 00004000) P25: RESERVE2 (0005E000, 00002000) P26: system (00060000, 00604000) P27: cache (00664000, 000C8000) P28: hidden (0072C000, 00032000) P29: userdata (0075E000, 00730000) Selected pit file: C:/Users/maanarman/Desktop/G532G/PIT-SM-G532G-15-03-2017_09-07-10.pit Open file "C:/Users/maanarman/Desktop/SM-G532G_1_20170103190726_cl2wlkyv46_fac/BL_G532GDXU1APL5_CL10197708_QB12005532_REV00_user_ low_ship_MULTI_CERT.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOTLOADER... Done. Switched to user area. Writing partition lk... Done. Writing partition efuse... Done. Writing partition tee1... Done. Writing partition PARAM... Done. Writing is finished. SW: 1.3.8; FW: 1.18. |
The Following 2 Users Say Thank You to maanarman For This Useful Post: |
07-30-2017, 13:23 | #830 (permalink) |
Freak Poster Join Date: Dec 2010 Location: Uzbekistan/Jizzakh
Member: 1470188 Status: Offline Sonork: 100.1638921 Thanks Meter: 88 | HighScreen Omega S after change eMMC boot repair done via usb HighScreen Omega S after change emmc boot repair done via usb, THANKS MEDUSA TEAM Model Settings: Interface : USB Core : Qualcomm MSM8x10 Loader : QLoader_v1 Connecting... Sending loader...OK. Loader successfully initialized. Device : CoreID_008140E1 Core : Qualcomm MSM8x10 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB Connect successful. --------------------------------------------------------------- SW: 1.3.9; FW: 1.19. P00: PART_EE (00000001, FFFFFFFF) Selected rawprogram XML file: H:/PROSHIVKA/Highscreen/version/rawprogram_unsparse.xml. Selected patch file: H:/PROSHIVKA/Highscreen/version/patch0.xml. Backuping. Please wait... Reading partition modemst1... Done. Reading partition modemst2... Done. Backuping finished. Writing. Please wait... Writing partition sbl1... Done. Writing partition sdi... Done. Writing partition aboot... Done. Writing partition rpm... Done. Writing partition tz... Done. Writing partition splash... Done. Writing partition modem... Done. Writing partition boot... Done. Writing partition persist... Done. Writing partition cache... Done. Writing partition recovery... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition PrimaryGPT... Done. Writing partition BackupGPT... Done. Writing finished. SW: 1.3.9; FW: 1.19. Disconnected. Last edited by Medusa Box; 07-31-2017 at 06:28. |
The Following User Says Thank You to mastersgsm For This Useful Post: |
07-30-2017, 13:37 | #831 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Motorola xt1080 replace and repair emmc done Code: Welcome to Medusa Pro Software version 1.4.0. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Toshiba eMMC 032G96 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB --------------------------------------------------------------- CID Info CID : 110100303332473936115988489870BD Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 032G96 Product revision : 1.1 Product serial number : (hex) 59884898 Manufacturing date : 07/2013 --------------------------------------------------------------- CSD Info CSD : D00E00320F5903FFFFFFFFFF92400025 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 1 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15269888 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 2457600 Number of sectors : 3145728 Device Manufacturer : motorola Device Platform : msm8960 Build ID : KXA21.12-L1.26 Display Build ID : KXA21.12-L1.26 Release ID : 4.4.4 Device Model : XT1058 Device Name : ghost_att Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Build Description : ghost_att-user 4.4.4 KXA21.12-L1.26 26 bldacfg,release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/032G96_30_07_2017_14_11_37.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.0; FW: 1.20. P00: GPT (00000000, 00000100) P01: modem (00000100, 00032000) P02: sbl1 (00032100, 00000BB8) P03: sbl2 (00032CB8, 00000BB8) P04: sbl3 (00033870, 00000404) P05: aboot (00034870, 00000400) P06: rpm (00035428, 0000011C) P07: tz (00035810, 000001A4) P08: utags (00035BF8, 00000400) P09: logs (00035FF8, 00000800) P10: padA (000367F8, 00001808) P11: sbl2Backup (00038000, 00000BB8) P12: sbl3Backup (00038BB8, 00001000) P13: abootBackup (00039BB8, 00000BB8) P14: rpmBackup (0003A770, 000003E8) P15: tzBackup (0003AB58, 000003E8) P16: utagsBackup (0003AF40, 00000400) P17: padB (0003B340, 00000CC0) P18: modemst1 (0003C000, 00001800) P19: modemst2 (0003D800, 00001800) P20: mbl (0003F000, 00001000) P21: hob (00040000, 00000500) P22: dhob (00040500, 00000010) P23: persist (00040600, 00004000) P24: ssd (00044600, 00000010) P25: fsg (00044610, 00001800) P26: sp (00045E10, 00000800) P27: misc (00046610, 00000400) P28: pds (00046A10, 00001800) P29: cid (00048210, 00000100) P30: logo (00048310, 00002000) P31: clogo (0004A310, 00002000) P32: devtree (0004C310, 00000800) P33: boot (0004CC00, 00005000) P34: recovery (00051C00, 00005000) P35: kpan (00056C00, 00004000) P36: cache (0005AC00, 001FCC00) P37: padC (00257800, 00000800) P38: system (00258000, 00300000) P39: customize (00558000, 00036000) P40: userdata (0058E000, 034A7F00) Erasing partition GPT... Done. Erasing partition modem... Done. Erasing partition sbl1... Done. Erasing partition sbl2... Done. Erasing partition sbl3... Done. Erasing partition aboot... Done. Erasing partition rpm... Done. Erasing partition tz... Done. Erasing partition utags... Done. Erasing partition logs... Done. Erasing partition padA... Done. Erasing partition sbl2Backup... Done. Erasing partition sbl3Backup... Done. Erasing partition abootBackup... Done. Erasing partition rpmBackup... Done. Erasing partition tzBackup... Done. Erasing partition utagsBackup... Done. Erasing partition padB... Done. Erasing partition modemst1... Done. Erasing partition modemst2... Done. Erasing partition mbl... Done. Erasing partition hob... Done. Erasing partition dhob... Done. Erasing partition persist... Done. Erasing partition ssd... Done. Erasing partition fsg... Done. Erasing partition sp... Done. Erasing partition misc... Done. Erasing partition pds... Done. Erasing partition cid... Done. Erasing partition logo... Done. Erasing partition clogo... Done. Erasing partition devtree... Done. Erasing partition boot... Done. Erasing partition recovery... Done. Erasing partition kpan... Done. Erasing partition cache... Done. Erasing partition padC... Done. Erasing partition system... Done. Erasing partition customize... Done. Erasing partition userdata... Done. Erasing is finished. SW: 1.4.0; FW: 1.20. Write data verification is enabled. Write partitions from C:/Users/maanarman/Desktop/NEW/Sandisk eMMC SEM16G_Sun Jul 30 2017_13_57_14.mpt file... Writing partition GPT... Done. Writing partition modem... Done. Writing partition sbl1... Done. Writing partition sbl2... Done. Writing partition sbl3... Done. Writing partition aboot... Done. Writing partition rpm... Done. Writing partition tz... Done. Writing partition utags... Done. Writing partition logs... Done. Writing partition padA... Done. Writing partition sbl2Backup... Done. Writing partition sbl3Backup... Done. Writing partition abootBackup... Done. Writing partition rpmBackup... Done. Writing partition tzBackup... Done. Writing partition utagsBackup... Done. Writing partition padB... Done. Writing partition modemst1... Done. Writing partition modemst2... Done. Writing partition mbl... Done. Writing partition hob... Done. Writing partition dhob... Done. Writing partition persist... Done. Writing partition ssd... Done. Writing partition fsg... Done. Writing partition sp... Done. Writing partition misc... Done. Writing partition pds... Done. Writing partition cid... Done. Writing partition logo... Done. Writing partition clogo... Done. Writing partition devtree... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition kpan... Done. Writing partition cache... Done. Writing partition padC... Done. Writing partition customize... Done. SW: 1.4.0; FW: 1.20. |
The Following User Says Thank You to maanarman For This Useful Post: |
07-30-2017, 14:30 | #832 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | One more motorola xt1080 replace and repair emmc done Code: Welcome to Medusa Pro Software version 1.4.0. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Sandisk eMMC SEM16G Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB --------------------------------------------------------------- CID Info CID : 45010053454D313647072120D5DB3111 Manufacturer ID : 0X45 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : SEM16G Product revision : 0.7 Product serial number : (hex) 2120D5DB Manufacturing date : 03/2014 --------------------------------------------------------------- CSD Info CSD : D00F00320F5903FFFFFFFFFF8A40407F CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 10 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Max enhanced data size: 7684096 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 3244032 Number of sectors : 4325376 Device Manufacturer : motorola Device Platform : msm8960 Build ID : SU5-24 Display Build ID : SU5-24 Release ID : 4.4.4 Device Model : XT1080 Device Name : obake_verizon Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Build Description : obake_verizon-user 4.4.4 SU5-24 24 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/SEM16G_30_07_2017_18_00_49.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.0; FW: 1.20. P00: GPT (00000000, 00000100) P01: modem (00000100, 00032000) P02: sbl1 (00032100, 00000BB8) P03: sbl2 (00032CB8, 00000BB8) P04: sbl3 (00033870, 00000404) P05: aboot (00034870, 00000400) P06: rpm (00035428, 0000011C) P07: tz (00035810, 000001A4) P08: utags (00035BF8, 00000400) P09: logs (00035FF8, 00000800) P10: padA (000367F8, 00001808) P11: sbl2Backup (00038000, 00000BB8) P12: sbl3Backup (00038BB8, 00001000) P13: abootBackup (00039BB8, 00000BB8) P14: rpmBackup (0003A770, 000003E8) P15: tzBackup (0003AB58, 000003E8) P16: utagsBackup (0003AF40, 00000400) P17: padB (0003B340, 00000CC0) P18: modemst1 (0003C000, 00001800) P19: modemst2 (0003D800, 00001800) P20: mbl (0003F000, 00001000) P21: hob (00040000, 00000500) P22: dhob (00040500, 00000010) P23: persist (00040600, 00004000) P24: ssd (00044600, 00000010) P25: fsg (00044610, 00001800) P26: sp (00045E10, 00000800) P27: misc (00046610, 00000400) P28: pds (00046A10, 00001800) P29: cid (00048210, 00000100) P30: logo (00048310, 00002000) P31: clogo (0004A310, 00002000) P32: devtree (0004C310, 00000800) P33: boot (0004CC00, 00005000) P34: recovery (00051C00, 00005000) P35: kpan (00056C00, 00004000) P36: cache (0005AC00, 002BCC00) P37: padC (00317800, 00000800) P38: system (00318000, 00420000) P39: customize (00738000, 00008000) P40: userdata (00740000, 01611F00) Erasing partition GPT... Done. Erasing partition modem... Done. Erasing partition sbl1... Done. Erasing partition sbl2... Done. Erasing partition sbl3... Done. Erasing partition aboot... Done. Erasing partition rpm... Done. Erasing partition tz... Done. Erasing partition utags... Done. Erasing partition logs... Done. Erasing partition padA... Done. Erasing partition sbl2Backup... Done. Erasing partition sbl3Backup... Done. Erasing partition abootBackup... Done. Erasing partition rpmBackup... Done. Erasing partition tzBackup... Done. Erasing partition utagsBackup... Done. Erasing partition padB... Done. Erasing partition modemst1... Done. Erasing partition modemst2... Done. Erasing partition mbl... Done. Erasing partition hob... Done. Erasing partition dhob... Done. Erasing partition persist... Done. Erasing partition ssd... Done. Erasing partition fsg... Done. Erasing partition sp... Done. Erasing partition misc... Done. Erasing partition pds... Done. Erasing partition cid... Done. Erasing partition logo... Done. Erasing partition clogo... Done. Erasing partition devtree... Done. Erasing partition boot... Done. Erasing partition recovery... Done. Erasing partition kpan... Done. Erasing partition cache... Done. Erasing partition padC... Done. Erasing partition system... Done. Erasing partition customize... Done. Erasing partition userdata... Done. Erasing is finished. SW: 1.4.0; FW: 1.20. Write data verification is enabled. Write partitions from C:/Users/maanarman/Desktop/NEW/2ND/Sandisk eMMC SEM16G_Sun Jul 30 2017_17_47_04.mpt file... Writing partition GPT... Done. Writing partition modem... Done. Writing partition sbl1... Done. Writing partition sbl2... Done. Writing partition sbl3... Done. Writing partition aboot... Done. Writing partition rpm... Done. Writing partition tz... Done. Writing partition utags... Done. Writing partition logs... Done. Writing partition padA... Done. Writing partition sbl2Backup... Done. Writing partition sbl3Backup... Done. Writing partition abootBackup... Done. Writing partition rpmBackup... Done. Writing partition tzBackup... Done. Writing partition utagsBackup... Done. Writing partition padB... Done. Writing partition modemst1... Done. Writing partition modemst2... Done. Writing partition mbl... Done. Writing partition hob... Done. Writing partition dhob... Done. Writing partition persist... Done. Writing partition ssd... Done. Writing partition fsg... Done. Writing partition sp... Done. Writing partition misc... Done. Writing partition pds... Done. Writing partition cid... Done. Writing partition logo... Done. Writing partition clogo... Done. Writing partition devtree... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition kpan... Done. Writing partition cache... Done. Writing partition padC... Done. Writing partition customize... Done. SW: 1.4.0; FW: 1.20. |
08-01-2017, 13:12 | #833 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Huawei y530-u00 boot repair done Welcome to Medusa Pro Software version 1.4.1. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Huawei Model : Y530-U00 SRF : D:/JTAG/medusa + pro/medusa pro/Y530-U00/Huawei_Y530-U00_EMMC_H4G1D.srf Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Hynix eMMC H4G1d Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A4834473164040300A5AE48219B Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G1d Product revision : 0.3 Product serial number : (hex) A5AE48 Manufacturing date : 02/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : e9000000 bytes Device sector size : 512 bytes Partition offset : 1589248 Number of sectors : 2097152 Device Manufacturer : Huawei Device Platform : msm8610 Build ID : HuaweiY530-U00 Display Build ID : Y530-U00V100R001C900B172 Release ID : 4.3 Device Model : HUAWEI Y530-U00 Device Name : Y530-U00 Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Build Description : msm7627a-eng 2.3.5 GRJ90 eng.hongtao.20111013.064550 test-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G1d_01_08_2017_16_41_08.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.1; FW: 1.20. P00: GPT (00000000, 00000022) P01: sbl1 (00000022, 00000400) P02: sdi (00000422, 00000040) P03: DDR (00002000, 00000040) P04: rpm (00004000, 000003E8) P05: tz (000043E8, 000003E8) P06: aboot (000047D0, 00002BB0) P07: pad (00007380, 00000800) P08: oeminfo (00007B80, 00020000) P09: modemst1 (00027B80, 00002000) P10: modemst2 (00029B80, 00002000) P11: modem (0002C000, 00030000) P12: fsg (0005C000, 00002000) P13: fsc (0005E000, 00000002) P14: ssd (0005E002, 00000010) P15: log (0005E012, 00010000) P16: bkbootup (00070000, 00020000) P17: persist (00090000, 00004000) P18: boot (00094000, 00006000) P19: recovery (0009A000, 00008000) P20: cust (000A2000, 00080000) P21: cache (00122000, 00060000) P22: misc (00182000, 00002000) P23: system (00184000, 00200000) P24: userdata (00384000, 00200000) P25: grow (00584000, 001C3FDF) Repairing from file "D:/JTAG/medusa + pro/medusa pro/Y530-U00/Huawei_Y530-U00_EMMC_H4G1D.srf". Write data verification is enabled. Writing GPT partition... Done. Writing sbl1 partition... Done. Writing sdi partition... Done. Writing DDR partition... Done. Writing rpm partition... Done. Writing tz partition... Done. Writing aboot partition... Done. Writing pad partition... Done. Writing oeminfo partition... Done. Writing modemst1 partition... Done. Writing modemst2 partition... Done. Writing modem partition... Done. Writing fsg partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing log partition... Done. Writing bkbootup partition... Done. Writing persist partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing cust partition... Done. Writing cache partition... Done. Writing misc partition... Done. Writing system partition... Done. Writing userdata partition... Done. Writing grow partition... Done. Smart Repair is successfully complete. SW: 1.4.1; FW: 1.20. Disconnected. |
08-01-2017, 14:14 | #834 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Motorola xt1080 replace and repair emmc done Code: Welcome to Medusa Pro Software version 1.4.1. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Toshiba eMMC 032G96 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB --------------------------------------------------------------- CID Info CID : 11010030333247393611D914610E70B5 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 032G96 Product revision : 1.1 Product serial number : (hex) D914610E Manufacturing date : 07/2013 --------------------------------------------------------------- CSD Info CSD : D00E00320F5903FFFFFFFFFF92400025 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 1 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15269888 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 3244032 Number of sectors : 4325376 Device Manufacturer : motorola Device Platform : msm8960 Build ID : SU6-7.7 Display Build ID : SU6-7.7 Release ID : 4.4.4 Device Model : XT1080 Device Name : obake_verizon Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Build Description : obake_verizon-user 4.4.4 SU6-7.7 5 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/032G96_01_08_2017_14_21_18.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.1; FW: 1.20. P00: GPT (00000000, 00000100) P01: modem (00000100, 00032000) P02: sbl1 (00032100, 00000BB8) P03: sbl2 (00032CB8, 00000BB8) P04: sbl3 (00033870, 00000404) P05: aboot (00034870, 00000400) P06: rpm (00035428, 0000011C) P07: tz (00035810, 000001A4) P08: utags (00035BF8, 00000400) P09: logs (00035FF8, 00000800) P10: padA (000367F8, 00001808) P11: sbl2Backup (00038000, 00000BB8) P12: sbl3Backup (00038BB8, 00001000) P13: abootBackup (00039BB8, 00000BB8) P14: rpmBackup (0003A770, 000003E8) P15: tzBackup (0003AB58, 000003E8) P16: utagsBackup (0003AF40, 00000400) P17: padB (0003B340, 00000CC0) P18: modemst1 (0003C000, 00001800) P19: modemst2 (0003D800, 00001800) P20: mbl (0003F000, 00001000) P21: hob (00040000, 00000500) P22: dhob (00040500, 00000010) P23: persist (00040600, 00004000) P24: ssd (00044600, 00000010) P25: fsg (00044610, 00001800) P26: sp (00045E10, 00000800) P27: misc (00046610, 00000400) P28: pds (00046A10, 00001800) P29: cid (00048210, 00000100) P30: logo (00048310, 00002000) P31: clogo (0004A310, 00002000) P32: devtree (0004C310, 00000800) P33: boot (0004CC00, 00005000) P34: recovery (00051C00, 00005000) P35: kpan (00056C00, 00004000) P36: cache (0005AC00, 002BCC00) P37: padC (00317800, 00000800) P38: system (00318000, 00420000) P39: customize (00738000, 00008000) P40: userdata (00740000, 032F5F00) Erasing partition GPT... Done. Erasing partition modem... Done. Erasing partition sbl1... Done. Erasing partition sbl2... Done. Erasing partition sbl3... Done. Erasing partition aboot... Done. Erasing partition rpm... Done. Erasing partition tz... Done. Erasing partition utags... Done. Erasing partition logs... Done. Erasing partition padA... Done. Erasing partition sbl2Backup... Done. Erasing partition sbl3Backup... Done. Erasing partition abootBackup... Done. Erasing partition rpmBackup... Done. Erasing partition tzBackup... Done. Erasing partition utagsBackup... Done. Erasing partition padB... Done. Erasing partition modemst1... Done. Erasing partition modemst2... Done. Erasing partition mbl... Done. Erasing partition hob... Done. Erasing partition dhob... Done. Erasing partition persist... Done. Erasing partition ssd... Done. Erasing partition fsg... Done. Erasing partition sp... Done. Erasing partition misc... Done. Erasing partition pds... Done. Erasing partition cid... Done. Erasing partition logo... Done. Erasing partition clogo... Done. Erasing partition devtree... Done. Erasing partition boot... Done. Erasing partition recovery... Done. Erasing partition kpan... Done. Erasing partition cache... Done. Erasing partition padC... Done. Erasing partition system... Done. Erasing partition customize... Done. Erasing partition userdata... Done. Erasing is finished. SW: 1.4.1; FW: 1.20. Write data verification is enabled. Write partitions from C:/Users/maanarman/Desktop/1 aug 1080/Sandisk eMMC SEM16G_Tue Aug 1 2017_14_07_26.mpt file... Writing partition GPT... Done. Writing partition modem... Done. Writing partition sbl1... Done. Writing partition sbl2... Done. Writing partition sbl3... Done. Writing partition aboot... Done. Writing partition rpm... Done. Writing partition tz... Done. Writing partition utags... Done. Writing partition logs... Done. Writing partition padA... Done. Writing partition sbl2Backup... Done. Writing partition sbl3Backup... Done. Writing partition abootBackup... Done. Writing partition rpmBackup... Done. Writing partition tzBackup... Done. Writing partition utagsBackup... Done. Writing partition padB... Done. Writing partition modemst1... Done. Writing partition modemst2... Done. Writing partition mbl... Done. Writing partition hob... Done. Writing partition dhob... Done. Writing partition persist... Done. Writing partition ssd... Done. Writing partition fsg... Done. Writing partition sp... Done. Writing partition misc... Done. Writing partition pds... Done. Writing partition cid... Done. Writing partition logo... Done. Writing partition clogo... Done. Writing partition devtree... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition kpan... Done. Writing partition cache... Done. Writing partition padC... Done. Writing partition customize... Done. SW: 1.4.1; FW: 1.20. |
08-02-2017, 10:40 | #835 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Kathmandu, Nepal
Member: 260236 Status: Offline Sonork: 100.1641081 Thanks Meter: 135 | LG AS330 | USB Boot Repair | Success ! Medusa Pro Model Settings: Interface : USB Brand : LG Model : AS330 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_AS330_USB.srf Core : Qualcomm MSM8909 Loader : QLoader_v2 Model Settings: Interface : USB Brand : LG Model : AS330 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_AS330_USB.srf Core : Qualcomm MSM8909 Loader : QLoader_v2 Connecting... Sending loader...OK. Loader successfully initialized. Device : CoreID_009600E1 Core : Qualcomm MSM8909 Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB Connect successful. --------------------------------------------------------------- SW: 1.3.3; FW: 1.1.0. Reapairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/LG_AS330_USB.srf". Write data verification is enabled. Writing GPT partition... Done. Writing modem partition... Done. Writing sbl1 partition... Done. Writing tz partition... Done. Writing rpm partition... Done. Writing aboot partition... Done. Writing sbl1bak partition... Done. Writing tzbak partition... Done. Writing rpmbak partition... Done. Writing abootbak partition... Done. Writing modemst1 partition... Done. Writing modemst2 partition... Done. Writing ssd partition... Done. Writing DDR partition... Done. Writing fsg partition... Done. Writing fsc partition... Done. Writing sec partition... Done. Writing keystore partition... Done. Writing encrypt partition... Done. Writing eksst partition... Done. Writing devinfo partition... Done. Writing config partition... Done. Writing spare1 partition... Done. Writing fota partition... Done. Writing rct partition... Done. Writing spare2 partition... Done. Writing raw_resources partition... Done. Writing raw_resourcesbak partition... Done. Writing drm partition... Done. Writing sns partition... Done. Writing misc partition... Done. Writing persist partition... Done. Writing laf partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing factory partition... Done. Writing mpt partition... Done. Writing grow partition... Done. Smart Repair is successfully complete. SW: 1.3.3; FW: 1.1.0. Disconnected. |
The Following User Says Thank You to ace_venturia For This Useful Post: |
08-04-2017, 13:50 | #836 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Motorola xt1060 replace and repair emmc done Code: Welcome to Medusa Pro Software version 1.4.1. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Toshiba eMMC 016G92 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB --------------------------------------------------------------- CID Info CID : 110100303136473932009B95B6818F05 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 016G92 Product revision : 0.0 Product serial number : (hex) 9B95B681 Manufacturing date : 08/2012 --------------------------------------------------------------- CSD Info CSD : D00E00320F5903FFFFFFFFEF92400045 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 1 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7700480 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 2457600 Number of sectors : 3145728 Device Manufacturer : motorola Device Platform : msm8960 Build ID : LPA23.12-21.7 Display Build ID : LPA23.12-21.7 Release ID : 5.1 Device Model : XT1058 Device Name : ghost_att Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : ghost_att-user 5.1 LPA23.12-21.7 6 bldacfg,release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/016G92_03_08_2017_20_11_00.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.1; FW: 1.20. P00: GPT (00000000, 00000100) P01: modem (00000100, 00032000) P02: sbl1 (00032100, 00000BB8) P03: sbl2 (00032CB8, 00000BB8) P04: sbl3 (00033870, 00000404) P05: aboot (00034870, 00000400) P06: rpm (00035428, 0000011C) P07: tz (00035810, 000001A4) P08: utags (00035BF8, 00000400) P09: logs (00035FF8, 00000800) P10: padA (000367F8, 00001808) P11: sbl2Backup (00038000, 00000BB8) P12: sbl3Backup (00038BB8, 00001000) P13: abootBackup (00039BB8, 00000BB8) P14: rpmBackup (0003A770, 000003E8) P15: tzBackup (0003AB58, 000003E8) P16: utagsBackup (0003AF40, 00000400) P17: padB (0003B340, 00000CC0) P18: modemst1 (0003C000, 00001800) P19: modemst2 (0003D800, 00001800) P20: mbl (0003F000, 00001000) P21: hob (00040000, 00000500) P22: dhob (00040500, 00000010) P23: persist (00040600, 00004000) P24: ssd (00044600, 00000010) P25: fsg (00044610, 00001800) P26: sp (00045E10, 00000800) P27: misc (00046610, 00000400) P28: pds (00046A10, 00001800) P29: cid (00048210, 00000100) P30: logo (00048310, 00002000) P31: clogo (0004A310, 00002000) P32: devtree (0004C310, 00000800) P33: boot (0004CC00, 00005000) P34: recovery (00051C00, 00005000) P35: kpan (00056C00, 00004000) P36: cache (0005AC00, 001FCC00) P37: padC (00257800, 00000800) P38: system (00258000, 00300000) P39: customize (00558000, 00036000) P40: userdata (0058E000, 017C3F00) Erasing partition GPT... Done. Erasing partition modem... Done. Erasing partition sbl1... Done. Erasing partition sbl2... Done. Erasing partition sbl3... Done. Erasing partition aboot... Done. Erasing partition rpm... Done. Erasing partition tz... Done. Erasing partition utags... Done. Erasing partition logs... Done. Erasing partition padA... Done. Erasing partition sbl2Backup... Done. Erasing partition sbl3Backup... Done. Erasing partition abootBackup... Done. Erasing partition rpmBackup... Done. Erasing partition tzBackup... Done. Erasing partition utagsBackup... Done. Erasing partition padB... Done. Erasing partition modemst1... Done. Erasing partition modemst2... Done. Erasing partition mbl... Done. Erasing partition hob... Done. Erasing partition dhob... Done. Erasing partition persist... Done. Erasing partition ssd... Done. Erasing partition fsg... Done. Erasing partition sp... Done. Erasing partition misc... Done. Erasing partition pds... Done. Erasing partition cid... Done. Erasing partition logo... Done. Erasing partition clogo... Done. Erasing partition devtree... Done. Erasing partition boot... Done. Erasing partition recovery... Done. Erasing partition kpan... Done. Erasing partition cache... Done. Erasing partition padC... Done. Erasing partition system... Done. Erasing partition customize... Done. Erasing partition userdata... Done. Erasing is finished. SW: 1.4.1; FW: 1.20. Write data verification is enabled. Write partitions from C:/Users/maanarman/Desktop/MOTO X DEAD/Sandisk eMMC SEM32G_Thu Aug 3 2017_19_59_59.mpt file... Writing partition GPT... Done. Writing partition modem... Done. Writing partition sbl1... Done. Writing partition sbl2... Done. Writing partition sbl3... Done. Writing partition aboot... Done. Writing partition rpm... Done. Writing partition tz... Done. Writing partition utags... Done. Writing partition logs... Done. Writing partition padA... Done. Writing partition sbl2Backup... Done. Writing partition sbl3Backup... Done. Writing partition abootBackup... Done. Writing partition rpmBackup... Done. Writing partition tzBackup... Done. Writing partition utagsBackup... Done. Writing partition padB... Done. Writing partition modemst1... Done. Writing partition modemst2... Done. Writing partition mbl... Done. Writing partition hob... Done. Writing partition dhob... Done. Writing partition persist... Done. Writing partition ssd... Done. Writing partition fsg... Done. Writing partition sp... Done. Writing partition misc... Done. Writing partition pds... Done. Writing partition cid... Done. Writing partition logo... Done. Writing partition clogo... Done. Writing partition devtree... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition kpan... Done. Writing partition cache... Done. Writing partition padC... Done. Writing partition customize... Done. SW: 1.4.1; FW: 1.20. |
08-04-2017, 14:10 | #837 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Motorola xt1080 dead boot repair done Code: Welcome to Medusa Pro Software version 1.3.9. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Toshiba eMMC 016G92 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB --------------------------------------------------------------- CID Info CID : 11010030313647393201D14D785E60C7 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 016G92 Product revision : 0.1 Product serial number : (hex) D14D785E Manufacturing date : 06/2013 --------------------------------------------------------------- CSD Info CSD : D00E00320F5903FFFFFFFFEF92400045 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 1 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7700480 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software MOTO TEST/EXT_CSD Backups/016G92_03_08_2017_19_54_26.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.9; FW: 1.18. P00: GPT (00000000, 00000100) P01: modem (00000100, 00032000) P02: sbl1 (00032100, 00000BB8) P03: sbl2 (00032CB8, 00000BB8) P04: sbl3 (00033870, 00000404) P05: aboot (00034870, 00000400) P06: rpm (00035428, 0000011C) P07: tz (00035810, 000001A4) P08: utags (00035BF8, 00000400) P09: logs (00035FF8, 00000800) P10: padA (000367F8, 00001808) P11: sbl2Backup (00038000, 00000BB8) P12: sbl3Backup (00038BB8, 00001000) P13: abootBackup (00039BB8, 00000BB8) P14: rpmBackup (0003A770, 000003E8) P15: tzBackup (0003AB58, 000003E8) P16: utagsBackup (0003AF40, 00000400) P17: padB (0003B340, 00000CC0) P18: modemst1 (0003C000, 00001800) P19: modemst2 (0003D800, 00001800) P20: mbl (0003F000, 00001000) P21: hob (00040000, 00000500) P22: dhob (00040500, 00000010) P23: persist (00040600, 00004000) P24: ssd (00044600, 00000010) P25: fsg (00044610, 00001800) P26: sp (00045E10, 00000800) P27: misc (00046610, 00000400) P28: pds (00046A10, 00001800) P29: cid (00048210, 00000100) P30: logo (00048310, 00002000) P31: clogo (0004A310, 00002000) P32: devtree (0004C310, 00000800) P33: boot (0004CC00, 00005000) P34: recovery (00051C00, 00005000) P35: kpan (00056C00, 00004000) P36: cache (0005AC00, 002BCC00) P37: padC (00317800, 00000800) P38: system (00318000, 00420000) P39: customize (00738000, 00008000) P40: userdata (00740000, 032F5F00) Selected file: D:/China New/BEST/MOTO/XT1080 CFC_obake_verizon-user-4.4.4-SU6-7.7-release-keys.xml/CFC_obake_verizon-user-4.4.4-SU6-7.7-release-keys.xml. File parsing finished. Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Write data verification is enabled. Writing. Please wait... Writing partition modem... Done. Writing partition sbl1... Done. Writing partition sbl2... Done. Writing partition sbl3... Done. Writing partition aboot... Done. Writing partition rpm... Done. Writing partition tz... Done. Erasing partition modemst1... Done. Erasing partition modemst2... Done. Writing partition fsg... Done. Writing partition logo... Done. Erasing partition clogo... Done. Writing partition boot... Done. Writing partition recovery... Done. Erasing partition cache... Done. Erasing partition customize... Done. Writing is finished. SW: 1.3.9; FW: 1.18. |
08-09-2017, 14:09 | #838 (permalink) |
No Life Poster Join Date: Dec 2009 Location: INDIA Age: 36
Member: 1195083 Status: Offline Sonork: QQ:3208821449 Thanks Meter: 1,348 | SM-J200H Fully Bricked Alive With Medusa Pro SM-J200H Fully Bricked Alive With Medusa Pro Last edited by Medusa Box; 08-09-2017 at 14:24. |
The Following 2 Users Say Thank You to mr.luckytarun For This Useful Post: |
08-23-2017, 13:33 | #839 (permalink) |
Freak Poster Join Date: Jun 2013 Location: india tirupur tamilnadu
Member: 1962832 Status: Offline Thanks Meter: 199 | Samsung GT-I9300i dead boot repair done! Best Regards a1mobiletirupur * Always Follow Forum RulesHere * Use Only Thanks Button * Use Search Button Before make a Thread Report Post Last edited by Medusa Box; 08-25-2017 at 04:49. |
The Following 2 Users Say Thank You to a1mobiletirupur For This Useful Post: |
08-23-2017, 14:42 | #840 (permalink) |
No Life Poster Join Date: Jan 2014 Location: india
Member: 2097870 Status: Offline Sonork: FINDING.... Thanks Meter: 65 | GT-I9060i dead boot repair done by Medusa Pro I9060I DEAD BOOT REAPIR DONE FOR MEDUSA..... Model Settings: Interface : eMMC Brand : Samsung Model : GT-I9060I SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-I9060I_EMMC_QNW00M.srf Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC QNW00M Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 150100514E5730304D0044A4D6B822C3 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QNW00M Product revision : 0.0 Product serial number : (hex) 44A4D6B8 Manufacturing date : 02/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 616448 Number of sectors : 2457600 Device Manufacturer : samsung Device Platform : sc8830 Build ID : KTU84P Display Build ID : KTU84P.I9060IXXS0AQD3 Release ID : 4.4.4 Device Model : GT-I9060I Device Name : grandneove3gxx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Build Description : grandneove3gxx-user 4.4.4 KTU84P I9060IXXS0AQD3 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QNW00M_23_08_2017_19_06_38.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.2; FW: 1.20. P00: GPT (00000000, 00002000) P01: SBOOT (00002000, 00001000) P02: SBOOT2 (00003000, 00001000) P03: wfixnv1 (00004000, 00000800) P04: wfixnv2 (00004800, 00000800) P05: tdfixnv1 (00005000, 00000800) P06: tdfixnv2 (00005800, 00000800) P07: WDSP (00006000, 00002000) P08: MODEM (00008000, 00004000) P09: MODEM2 (0000C000, 00004000) P10: TDDSP (00010000, 00002000) P11: FOTA_SIG (00012000, 00000800) P12: wruntimenv1 (00012800, 00000800) P13: wruntimenv2 (00013000, 00000800) P14: tdruntimenv1 (00013800, 00000800) P15: tdruntimenv2 (00014000, 00000800) P16: PARAM (00014800, 00001000) P17: efs (00015800, 0000A000) P18: prodnv (0001F800, 00002800) P19: RESERVED2 (00022000, 00000800) P20: KERNEL (00022800, 00008000) P21: RECOVERY (0002A800, 00008000) P22: CSC (00032800, 00064000) P23: system (00096800, 00258000) P24: HIDDEN (002EE800, 00040000) P25: userdata (0032E800, 00B5A000) Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-I9060I_EMMC_QNW00M.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to user area. Writing GPT partition... Done. Writing SBOOT partition... Done. Writing SBOOT2 partition... Done. Writing wfixnv1 partition... Done. Writing wfixnv2 partition... Done. Writing tdfixnv1 partition... Done. Writing tdfixnv2 partition... Done. Writing WDSP partition... Done. Writing MODEM partition... Done. Writing MODEM2 partition... Done. Writing TDDSP partition... Done. Writing FOTA_SIG partition... Done. Writing wruntimenv1 partition... Done. Writing wruntimenv2 partition... Done. Writing tdruntimenv1 partition... Done. Writing tdruntimenv2 partition... Done. Writing PARAM partition... Done. Writing efs partition... Done. Writing prodnv partition... Done. Writing RESERVED2 partition... Done. Writing KERNEL partition... Done. Writing RECOVERY partition... Done. Smart Repair is successfully complete. SW: 1.4.2; FW: 1.20. Disconnected. Last edited by Medusa Box; 08-25-2017 at 04:47. |
The Following User Says Thank You to rohit.sharma73 For This Useful Post: |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
