01-21-2017, 04:34 | #781 (permalink) |
No Life Poster Join Date: Dec 2012 Location: india mumbai
Member: 1847344 Status: Offline Thanks Meter: 300 | n7100 many error fix 1rst do factory formate 2nd update firmware 3rd write ext csd file in backup 4rth do smart repaire Model Settings: Interface : eMMC Brand : Samsung Model : GT-N7100 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-N7100_EMMC_VTU00M.srf Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC VTU00M Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB --------------------------------------------------------------- CID Info CID : 15010056545530304DF1F0772E7F8F99 Manufacturer ID : 0X15 Device/BGA : BGA(Discrete embeded) OEM/Application ID : 0X00 Product name : VTU00M Product revision : 15.1 Product serial number : (hex)F0772E7F Manufacturing date : 08/2012 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8E406009 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Boot partition enable : Boot partition 1 Partition config : 01001000 Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/VTU00M_21_01_2017_08_25_17.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.0; FW: 1.15. Factory Format will erase all eMMC data! Do you want to continue? Yes. Formating...Done. SW: 1.3.0; FW: 1.15. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : GT-N7100 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-N7100_EMMC_VTU00M.srf Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC VTU00M Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB --------------------------------------------------------------- CID Info CID : 15010056545530304DF1F0772E7F8F99 Manufacturer ID : 0X15 Device/BGA : BGA(Discrete embeded) OEM/Application ID : 0X00 Product name : VTU00M Product revision : 15.1 Product serial number : (hex)F0772E7F Manufacturing date : 08/2012 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8E406009 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Boot partition enable : Device not boot enabled (default) Partition config : 00000000 Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/VTU00M_21_01_2017_08_25_44.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.0; FW: 1.15. Writting eMMC firmware from file: C:/Program Files/Medusa Pro Software/EMMC_firmwares/KMVTU000LM-B503/KMVTU000LM-B503_FW.bin...Done. Finalizing...Done. Chaging CID to 15010056545530304DF780F6213A2123. Write CID succesfully completed. Disconnected. EMMC writing firmware done. SW: 1.3.0; FW: 1.15. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : GT-N7100 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-N7100_EMMC_VTU00M.srf Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC VTU00M Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB --------------------------------------------------------------- CID Info CID : 15010056545530304DF780F6213A2123 Manufacturer ID : 0X15 Device/BGA : BGA(Discrete embeded) OEM/Application ID : 0X00 Product name : VTU00M Product revision : 15.7 Product serial number : (hex)80F6213A Manufacturing date : 02/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8E40406D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Boot partition enable : Boot partition 1 Partition config : 01001000 Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/VTU00M_21_01_2017_08_30_17.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.0; FW: 1.15. Writing EXT_CSD succesfully complete! Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : GT-N7100 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-N7100_EMMC_VTU00M.srf Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC VTU00M Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB --------------------------------------------------------------- CID Info CID : 15010056545530304DF780F6213A2123 Manufacturer ID : 0X15 Device/BGA : BGA(Discrete embeded) OEM/Application ID : 0X00 Product name : VTU00M Product revision : 15.7 Product serial number : (hex)80F6213A Manufacturing date : 02/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8E40406D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Boot partition enable : Boot partition 1 Partition config : 01001000 Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/VTU00M_21_01_2017_08_30_47.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.0; FW: 1.15. Reapairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-N7100_EMMC_VTU00M.srf". Write data verification is enabled. Switched to boot area partition 1. Writting BOOT1 partition... Done. Switched to user area. Writting GPT partition... Done. Writting BOTA0 partition... Done. Writting BOTA1 partition... Done. Writting EFS partition... Done. Writting m9kefs1 partition... Done. Writting m9kefs2 partition... Done. Writting m9kefs3 partition... Done. Writting PARAM partition... Done. Writting BOOT partition... Done. Writting RECOVERY partition... Done. Smart Repair is successfully complete. SW: 1.3.0; FW: 1.15. Disconnected. |
The Following 3 Users Say Thank You to shamsulhaq For This Useful Post: |
01-21-2017, 05:26 | #783 (permalink) |
Member: 1847344 Status: Offline Thanks Meter: 300 | s5282 fully dead done Welcome to Medusa Pro Software version 1.3.0. Started. Reader #0: FT SCR2000 0 Reader #1: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 Bus speed : 15 Connecting... Device : Samsung eMMC S5U00M Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 15010053355530304D026B077265603F Manufacturer ID : 0X15 Device/BGA : BGA(Discrete embeded) OEM/Application ID : 0X00 Product name : S5U00M Product revision : 0.2 Product serial number : (hex)6B077265 Manufacturing date : 06/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFE18E404029 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Boot partition enable : Boot partition 1 Partition config : 00001000 Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/S5U00M_21_01_2017_09_39_58.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.0; FW: 1.15. Selected pit file: H:/samsung/FLASH FILE/S SERIES/S5282/mint.pit Open file "H:/samsung/FLASH FILE/S SERIES/S5282/S5282XXAMDD_OXEAMDD/BOOTSPL_S5282XXAMDD_1149380_REV03_user_low_ship.ta r.md5". Open file "H:/samsung/FLASH FILE/S SERIES/S5282/S5282XXAMDD_OXEAMDD/CODE_S5282XXAMDD_1149380_REV03_user_low_ship.tar.m d5". Open file "H:/samsung/FLASH FILE/S SERIES/S5282/S5282XXAMDD_OXEAMDD/MODEM_S5282XXAMD7_REV03.tar.md5". Open file "H:/samsung/FLASH FILE/S SERIES/S5282/S5282XXAMDD_OXEAMDD/CSC_OXE_S5282OXEAMDD_1149380_REV03_user_low_ship.t ar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writting. Please wait... Switched to boot area partition 1. Writting partition BOOT... Done. Switched to user area. Writting partition DSP... Done. Writting partition KERNEL... Done. Writting partition RECOVERY... Done. Writting partition modem... Done. Writting partition SBL1... Done. Writting partition PARAM... Done. Writting partition FIXNV2... Done. Writting partition CSC... Done. Writting partition system... Done. Writting partition HIDDEN... ERROR[012]: Write error. At sector 3087872 Disconnected. dont wory this error fone goes download mode flash it |
The Following User Says Thank You to shamsulhaq For This Useful Post: |
01-21-2017, 05:48 | #784 (permalink) |
Junior Member Join Date: Jun 2012
Member: 1771433 Status: Offline Thanks Meter: 8 | Lenovo S920 repair device based on MTK CPU using scatter done Model Settings: Lenovo S920 Interface : eMMC Voltage : 1.8V Bus Mode : 4 Bus speed : Auto Connecting... Device : Samsung eMMC KJS00M Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 1501004B4A5330304D000000000000D7 Manufacturer ID : 0X15 Device/BGA : BGA(Discrete embeded) OEM/Application ID : 0X00 Product name : KJS00M Product revision : 0.0 Product serial number : (hex)0 Manufacturing date : 00/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 2048 Kbytes Boot partition enable : Boot partition 1 Partition config : 00001000 Backup EXT_CSD saved to file D:/WORK/mobiles/GsmServer/Medusa Pro Software/EXT_CSD Backups/KJS00M_20_01_2017_16_24_29.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.0; FW: 1.15. --------------------------------------------------------------- Selected scatter file: E:/WORK/Devices/_mobile/lenovo/S920_ROW_S221_150119/S920_ROW_S221_150119/target_bin/MT6589_Android_scatter_emmc.txt. Scatter file type 1. Opened input file: E:/WORK/Devices/_mobile/lenovo/S920_ROW_S221_150119/S920_ROW_S221_150119/target_bin/preloader_seine_row.bin Found 3 eMMC supported CID: eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : KJS00M eMMC CID : 1501004B4A5330304D eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : K7U00M eMMC CID : 1501004B375530304D eMMC Vendor ID : 90 (Hynix eMMC) eMMC Model ID : 4A01 eMMC Name : H4G1d eMMC CID : 90014A483447316404 Writting. Please wait... Writting partition PRELOADER... Write data verification is enabled. Write data verification is enabled. Done. Writting partition MBR... Write data verification is disabled. Done. Writting partition EBR1... Write data verification is disabled. Done. Writting partition UBOOT... Write data verification is disabled. Done. Writting partition BOOTIMG... Write data verification is disabled. Done. Writting partition RECOVERY... Write data verification is disabled. Done. Writting partition SEC_RO... Write data verification is disabled. Done. Writting partition PRELOAD... Done. Writting partition LOGO... Write data verification is disabled. Done. Writting partition EBR2... Write data verification is disabled. Done. Writting partition ANDROID... Done. Writting partition CACHE... Done. Writting partition USRDATA... Done. Writting checksums...Done. Writing finished. SW: 1.3.0; FW: 1.15. Disconnected. |
The Following User Says Thank You to aGAinIT For This Useful Post: |
02-18-2017, 20:29 | #785 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | SM-G530H Repair done Success repair Samsung SM-G530H: Code: Welcome to Medusa Pro Software version 1.3.2. Started. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G530H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G530H_EMMC_P1J95K.srf Voltage : 2.0V Bus Mode : 1 Bus speed : Auto Connecting... Device : Micron eMMC P1J95K Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : FE014E50314A39354B131454E53632B3 Manufacturer ID : 0XFE Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4E Product name : P1J95K Product revision : 1.3 Product serial number : (hex) 1454E536 Manufacturing date : 03/2015 --------------------------------------------------------------- CSD Info CSD : D06E01320F5913FFFFFFFFEF92400071 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 6 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 8192 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 2048 Kbytes Boot partition enable : Device not boot enabled (default) Partition config : 00000000 Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/P1J95K_18_02_2017_21_14_50.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.2; FW: 1.15. Erasing. Please wait... Done. SW: 1.3.2; FW: 1.15. Reapairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G530H_EMMC_P1J95K.srf". Write data verification is enabled. Writing GPT partition... Done. Writing apnhlos partition... Done. Writing modem partition... Done. Writing sbl1 partition... Done. Writing ddr partition... Done. Writing aboot partition... Done. Writing rpm partition... Done. Writing qsee partition... Done. Writing qhee partition... Done. Writing fsg partition... Done. Writing sec partition... Done. Writing pad partition... Done. Writing param partition... Done. Writing efs partition... Done. Writing modemst1 partition... Done. Writing modemst2 partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing fota partition... Done. Writing backup partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing persist partition... Done. Writing persdata partition... Done. Smart Repair is successfully complete. SW: 1.3.2; FW: 1.15. Disconnected. Last edited by Medusa Box; 03-17-2017 at 08:10. |
The Following 3 Users Say Thank You to Dr_Wolodya For This Useful Post: |
02-18-2017, 21:43 | #786 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Lg LS990 Boot Repair Done Code: Model Settings: Interface : USB Core : Qualcomm MSM8974AC Loader : LG_loader_v1 Connecting... Cancelled. Model Settings: Interface : USB Core : Qualcomm MSM8974AC Loader : LG_loader_v1 Connecting... CPU name : Qualcomm MSM8974AC Flash Id : 110001 Device : Toshiba THGBMBG7D2KBAIL 032GE4 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB Connect successful. --------------------------------------------------------------- SW: 1.3.1; FW: 1.15. Opening D:/LS990 ZV5 VER OK/ls990/LS990ZV8_00/LS990ZV8_00.tot file... Signature OK. Signature 2 OK. Open file "D:/LS990 ZV5 VER OK/ls990/LS990ZV8_00/LS990ZV8_00.tot". Write data verification is disabled. Writting. Please wait... Writting partition PrimaryGPT... Done. Writting partition modem... Done. Writting partition sbl1... Done. Writting partition dbi... Done. Writting partition aboot... Done. Writting partition rpm... Done. Writting partition tz... Done. Writting partition boot... Done. Writting partition persist... Done. Writting partition recovery... Done. Writting partition rct... Done. Writting partition misc... Done. Writting partition laf... Done. Writting partition factory... Done. Writting partition cache... Done. Writting partition cache... Done. Writting partition cache... Done. Writting partition cache... Done. Writting partition cache... Done. Writting partition cache... Done. Writting partition cache... Done. Writting partition cache... Done. Writting partition BackupGPT... Done. Writting is finished. SW: 1.3.1; FW: 1.15. |
The Following 3 Users Say Thank You to maanarman For This Useful Post: |
02-18-2017, 21:48 | #787 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Lumia 520 Remove eMMC Write Protection Code: Welcome to Medusa Pro Software version 1.3.1. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.2V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC M8G2YC Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 1501004D384732594300343E64A3704D Manufacturer ID : 0X15 Device/BGA : BGA(Discrete embeded) OEM/Application ID : 0X00 Product name : M8G2YC Product revision : 0.0 Product serial number : (hex)343E64A3 Manufacturing date : 07/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF96406007 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Boot partition enable : User area Partition config : 00111000 Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 2539520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/M8G2YC_17_02_2017_03_50_53.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.1; FW: 1.15. Remove write protect successfully completed. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.2V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC M8G2YC Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 1501004D384732594300343E64A3704D Manufacturer ID : 0X15 Device/BGA : BGA(Discrete embeded) OEM/Application ID : 0X00 Product name : M8G2YC Product revision : 0.0 Product serial number : (hex)343E64A3 Manufacturing date : 07/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF96404063 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Boot partition enable : User area Partition config : 00111000 Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 2539520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/M8G2YC_17_02_2017_03_51_18.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.1; FW: 1.15. |
02-18-2017, 21:56 | #788 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Lg VS985 Boot Repair Done Code: Welcome to Medusa Pro Software version 1.3.2. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: FT SCR2000 0 Reader #3: FT SCR2000 1 Model Settings: Interface : USB Core : Qualcomm MSM8974AC Loader : LG_loader_v1 Connecting... CPU name : Qualcomm MSM8974AC Flash Id : 110001 Device : Toshiba THGBMBG7D2KBAIL 032GE4 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB Connect successful. --------------------------------------------------------------- SW: 1.3.2; FW: 1.15. Opening E:/LG/VS985 4.4.2/LG G3 VS985 10B_03 Stock TOT 442/LG G3 VS985 10B_03 Stock TOT 442/VS98510B_03.tot file... Signature OK. Signature 2 OK. Open file "E:/LG/VS985 4.4.2/LG G3 VS985 10B_03 Stock TOT 442/LG G3 VS985 10B_03 Stock TOT 442/VS98510B_03.tot". Write data verification is disabled. Writing. Please wait... Writing partition PrimaryGPT... Done. Writing partition modem... Done. Writing partition sbl1... Done. Writing partition dbi... Done. Writing partition aboot... Done. Writing partition rpm... Done. Writing partition tz... Done. Writing partition boot... Done. Writing partition persist... Done. Writing partition recovery... Done. Writing partition rct... Done. Writing partition misc... Done. Writing partition laf... Done. Writing partition factory... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition BackupGPT... Done. Writing is finished. SW: 1.3.2; FW: 1.15. |
03-02-2017, 12:04 | #789 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Lumia 520 Remove Protection Done....... Code: Welcome to Medusa Pro Software version 1.3.2. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Reader #3: Generic EMV Smartcard Reader 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.0V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC M8G2YC Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 1501004D384732594300DA62495731B1 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : M8G2YC Product revision : 0.0 Product serial number : (hex) DA624957 Manufacturing date : 03/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF96406007 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Boot partition enable : User area Partition config : 00111000 Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 2539520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/M8G2YC_01_03_2017_19_36_42.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.2; FW: 1.15. Remove write protect successfully completed. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.0V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC M8G2YC Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 1501004D384732594300DA62495731B1 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : M8G2YC Product revision : 0.0 Product serial number : (hex) DA624957 Manufacturing date : 03/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF96404063 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Boot partition enable : User area Partition config : 00111000 Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 2539520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/M8G2YC_01_03_2017_19_37_01.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.2; FW: 1.15. |
03-09-2017, 15:13 | #790 (permalink) |
No Life Poster Join Date: Sep 2012 Location: ISLD Age: 36
Member: 1814771 Status: Offline Sonork: 100.1621347 Thanks Meter: 350 | lg ls980 lg ls980 usb dead boot repair done Code: Model Settings: Interface : USB Brand : LG Model : LS980 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_LS980_USB.srf Core : Qualcomm MSM8974 Loader : LG_loader_v1 Connecting... CPU name : Qualcomm MSM8974 Flash Id : 110001 Device : Toshiba THGBMBG7D2KBAIL 032G96 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB Connect successful. --------------------------------------------------------------- SW: 1.3.3; FW: 1.1.0. Reapairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/LG_LS980_USB.srf". Write data verification is enabled. Writing GPT partition... Done. Writing sbl1 partition... Done. Writing dbi partition... Done. Writing DDR partition... Done. Writing aboot partition... Done. Writing rpm partition... Done. Writing boot partition... Done. Writing tz partition... Done. Writing pad partition... Done. Writing misc partition... Done. Writing persist partition... Done. Writing laf partition... Done. Writing BackupGPT partition... Done. Smart Repair is successfully complete. SW: 1.3.3; FW: 1.1.0. Disconnected. Regard Afridi gsm |
The Following 2 Users Say Thank You to Afridi gsm For This Useful Post: |
03-13-2017, 18:03 | #791 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Android developers
Member: 904753 Status: Offline Sonork: 100.1583681 Thanks Meter: 2,677 | Samsung G532F Repair Done by Medusa Pro Welcome to Medusa Pro Software version 1.3.3. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G532F SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532F_EMMC_QN16BB.srf Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC QN16BB Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 150100514E313642420001D8EEA9B3CF Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QN16BB Product revision : 0.0 Product serial number : (hex) 1D8EEA9 Manufacturing date : 11/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 01001000 Boot partition enable : Boot partition 1 Boot ACK : Boot acknowledge sent during boot operation Bit Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QN16BB_13_03_2017_21_48_29.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.3; FW: 1.15. Erasing. Please wait... error! ERROR[013]: Erase error. Attempting to erase... Done. SW: 1.3.3; FW: 1.15. Reapairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532F_EMMC_QN16BB.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to user area. Writing GPT partition... Done. Writing BOTA0 partition... Done. Writing nvram partition... Done. Writing lk partition... Done. Writing BOTA1 partition... Done. Writing secro partition... Done. Writing seccfg partition... Done. Writing efuse partition... Done. Writing tee1 partition... Done. Writing BOTA2 partition... Done. Writing EFS partition... Done. Writing nvdata partition... Done. Writing PARAM partition... Done. Writing recovery partition... Done. Writing boot partition... Done. Writing md1img partition... Done. Writing md1dsp partition... Done. Writing keystore partition... Done. Writing omekeystore partition... Done. Writing proinfo partition... Done. Writing para partition... Done. Writing PERSISTENT partition... Done. Writing STEADY partition... Done. Writing protect1 partition... Done. Writing protect2 partition... Done. Writing RESERVE2 partition... Done. Smart Repair is successfully complete. SW: 1.3.3; FW: 1.15. Disconnected. |
The Following User Says Thank You to ..::Waqar::.. For This Useful Post: |
03-16-2017, 13:35 | #792 (permalink) |
Freak Poster Join Date: Sep 2007 Location: algeria Age: 35
Member: 580077 Status: Offline Sonork: 100.1591941 Thanks Meter: 207 | GT-I9300 Repair done Code: Welcome to Medusa Pro Software version 1.3.3. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : GT-I9300 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-I9300_EMMC.srf Voltage : 1.8V Bus Mode : 1 Bus speed : 15 Connecting... Device : Samsung eMMC VTU00M Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB --------------------------------------------------------------- CID Info CID : 15010056545530304DFC46643895508B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : VTU00M Product revision : 15.12 Product serial number : (hex) 46643895 Manufacturing date : 05/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8E40406D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : 01001000 Boot partition enable : Boot partition 1 Boot ACK : Boot acknowledge sent during boot operation Bit Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7659520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/VTU00M_16_03_2017_13_09_08.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.3; FW: 1.16. Selected pit file: D:/flash/Phones/samsung/UFS/i9300/GT-I9300_mx_20120329.pit Open file "D:/flash/Phones/samsung/UFS/i9300/I9300XXUGNA7_I9300OJVGNA1_I9300XXUGMK6_HOME.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOTLOADER... Done. Writing partition TZSW... Done. Switched to user area. Writing partition BOOT... Done. Writing partition RECOVERY... Done. Writing partition RADIO... Done. Writing partition CACHE... Done. Writing partition SYSTEM... Done. Writing partition HIDDEN... Done. Writing is finished. SW: 1.3.3; FW: 1.16. Last edited by Medusa Box; 03-17-2017 at 08:10. |
The Following User Says Thank You to nori2007 For This Useful Post: |
03-16-2017, 19:13 | #793 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | lg d850 boot repair done Code: Welcome to Medusa Pro Software version 1.3.2. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Model Settings: Interface : USB Core : Qualcomm MSM8974AC Loader : LG_loader_v1 Connecting... CPU name : Qualcomm MSM8974AC Flash Id : 110001 Device : Toshiba THGBMBG7D2KBAIL 032GE4 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB Connect successful. --------------------------------------------------------------- SW: 1.3.2; FW: 1.15. Opening E:/LG/D850/LGD850AT-01-V10d-310-410-JUN-19-2014+0.tot file... Signature OK. Signature 2 OK. Open file "E:/LG/D850/LGD850AT-01-V10d-310-410-JUN-19-2014+0.tot". Write data verification is enabled. Writing. Please wait... Writing partition PrimaryGPT... Read verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. Model Settings: Interface : USB Core : Qualcomm MSM8974AC Loader : LG_loader_v1 Connecting... CPU name : Qualcomm MSM8974AC Flash Id : 110001 Device : Toshiba THGBMBG7D2KBAIL 032GE4 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB Connect successful. --------------------------------------------------------------- SW: 1.3.2; FW: 1.15. Opening E:/LG/D850/LGD850AT-01-V10d-310-410-JUN-19-2014+0.tot file... Signature OK. Signature 2 OK. Open file "E:/LG/D850/LGD850AT-01-V10d-310-410-JUN-19-2014+0.tot". Write data verification is disabled. Writing. Please wait... Writing partition PrimaryGPT... Done. Writing partition modem... Done. Writing partition sbl1... Done. Writing partition dbi... Done. Writing partition aboot... Done. Writing partition rpm... Done. Writing partition tz... Done. Writing partition boot... Done. Writing partition persist... Done. Writing partition recovery... Done. Writing partition rct... Done. Writing partition misc... Done. Writing partition laf... Done. Writing partition factory... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition BackupGPT... Done. Writing is finished. SW: 1.3.2; FW: 1.15. |
The Following User Says Thank You to maanarman For This Useful Post: |
03-18-2017, 11:58 | #794 (permalink) |
Freak Poster Join Date: Oct 2013 Location: Bangladesh
Member: 2049143 Status: Offline Sonork: not use Thanks Meter: 270 | Successfully Repaired with Medusa Box HTC Rio 8S (PM59100) repair done medusa Operating Mode: EasyRepair Mode Selected device model: HTC Rio 8S (PM59100) Connecting. Please wait... Checking data... MI: RTCK reaction time 126 ns, average speed 7936 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 207D00E1, IR Length = 11. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 1.79 V CPU : Qualcomm MSM8227 Core ID : 207D00E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000191. MI: Detailed server caps: FLASH, WDOG, A64, IOCTL MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xE0904A01. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000191 Storage Device: Hynix eMMC H4G1d Device ID : 00904A01 Block size : 512 bytes Blocks : 7569408 Storage size : 3696 Mb MBR: partition, type 0x000000EE (0x00000001, 0x00708000) MBR: partition (0x00000800, 0x0001D800) pg1fs MBR: partition (0x0001E000, 0x00001800) MODEM_FSG MBR: partition (0x0001F800, 0x00000800) board_info MBR: partition (0x00020000, 0x00004000) DPP MBR: partition (0x00024000, 0x00001000) SSD MBR: partition (0x00025000, 0x00000800) SBL1 MBR: partition (0x00025800, 0x00000800) SBL2 MBR: partition (0x00026000, 0x00001000) SBL3 MBR: partition (0x00027000, 0x00001000) UEFI MBR: partition (0x00028000, 0x00000800) RPM MBR: partition (0x00028800, 0x00000800) TZ MBR: partition (0x00029000, 0x00000800) WINSECAPP MBR: partition (0x00029800, 0x00000800) BACKUP_SBL1 MBR: partition (0x0002A000, 0x00000800) BACKUP_SBL2 MBR: partition (0x0002A800, 0x00001000) BACKUP_SBL3 MBR: partition (0x0002B800, 0x00001000) BACKUP_UEFI MBR: partition (0x0002C800, 0x00000800) BACKUP_RPM MBR: partition (0x0002D000, 0x00000800) BACKUP_TZ MBR: partition (0x0002D800, 0x00000800) BACKUP_WINSECAPP MBR: partition (0x0002E000, 0x00014000) RADIO MBR: partition (0x00042000, 0x00000200) UEFI_BS_NV MBR: partition (0x00042800, 0x00000200) UEFI_NV MBR: partition (0x00043000, 0x00004000) PLAT MBR: partition (0x00047000, 0x00014800) EFIESP MBR: partition (0x0005B800, 0x00000800) pg2fs MBR: partition (0x0005C000, 0x00000800) RFG_0 MBR: partition (0x0005C800, 0x00000800) RFG_1 MBR: partition (0x0005D000, 0x00000800) RFG_2 MBR: partition (0x0005D800, 0x00000800) RFG_3 MBR: partition (0x0005E000, 0x00000800) RFG_4 MBR: partition (0x0005E800, 0x00000800) RFG_5 MBR: partition (0x0005F000, 0x00000800) RFG_6 MBR: partition (0x0005F800, 0x00000800) RFG_7 MBR: partition (0x00060000, 0x00000800) RFG_8 MBR: partition (0x00060800, 0x00002000) MODEM_FS1 MBR: partition (0x00062800, 0x00002000) MODEM_FS2 MBR: partition (0x00064800, 0x00000200) UEFI_RT_NV MBR: partition (0x00065000, 0x00000100) UEFI_RT_NV_RPMB MBR: partition (0x00065800, 0x00000800) MFG MBR: partition (0x00066000, 0x00000800) MISC MBR: partition (0x00066800, 0x00006650) MMOS MBR: partition (0x00070000, 0x003A4F5F) MainOS MBR: partition (0x00418000, 0x0031FFDF) Data HTC: CID HTC__001. HTC: IMEI 353760-05-xxxxxxx HTC CID : HTC__001 IMEI : 353760-05-xxxxxxx Opening "C:\Users\Apple\Downloads\Compressed\HTC_8S_Repair .mf\HTC_8S_Repair.mf" file... Writing BOOT section. Please wait... Done Repairing CID and IMEI... HTC: CID HTC__203. HTC: IMEI 353760-05-xxxxxxx HTC: Setting new CID. HTC: Setting new IMEI. Done Disconnected |
The Following User Says Thank You to khorsed_pabna For This Useful Post: |
03-31-2017, 17:28 | #795 (permalink) |
Member: 580077 Status: Offline Sonork: 100.1591941 Thanks Meter: 207 | i9100 repair boot Code: Welcome to Medusa Pro Software version 1.3.4. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: FT SCR2000 0 Reader #3: FT SCR2000 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : GT-I9100 SRF : C:/Program Files/test/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-I9100_EMMC_VYL00M.srf Voltage : 2.8V Bus Mode : 1 Bus speed : 20 Connecting... Device : Samsung eMMC VYL00M Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB --------------------------------------------------------------- CID Info CID : 15010056594C30304D19DC2174187EDB Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : VYL00M Product revision : 1.9 Product serial number : (hex) DC217418 Manufacturing date : 07/2011 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8A404067 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 512 Kbytes Boot2 size : 512 Kbytes RPMB size : 128 Kbytes Partition config : 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7340032 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/VYL00M_31_03_2017_17_16_04.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.4; FW: 1.16. P00: BOOTLOADER (00000000, 000006C6) P01: PIT (00000022, 00000010) P02: MD5HDR (00000032, 00000800) P03: TZSW (000006C6, 00000138) P04: BOTA1 (00004000, 00002000) P05: EFS (00006000, 0000A000) P06: PARAM (00010000, 00004000) P07: BOOT (00014000, 00004000) P08: RECOVERY (00018000, 00004000) P09: RADIO (0001C000, 00010000) P10: CACHE (0002C000, 00200000) P11: SYSTEM (0022C000, 00300000) P12: HIDDEN (0052C000, 00118000) P13: OTA (00644000, 00004000) P14: USERDATA (00648000, 00000000) Factory Format will erase all eMMC data! Do you want to continue? Yes. Formating...Done. SW: 1.3.4; FW: 1.16. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : GT-I9100 SRF : C:/Program Files/test/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-I9100_EMMC_VYL00M.srf Voltage : 2.8V Bus Mode : 1 Bus speed : 20 Connecting... Device : Samsung eMMC VYL00M Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB --------------------------------------------------------------- CID Info CID : 15010056594C30304D19DC2174187EDB Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : VYL00M Product revision : 1.9 Product serial number : (hex) DC217418 Manufacturing date : 07/2011 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8A404067 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7340032 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/VYL00M_31_03_2017_17_18_55.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.4; FW: 1.16. Erasing. Please wait... Done. SW: 1.3.4; FW: 1.16. Reapairing from file "C:/Program Files/test/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-I9100_EMMC_VYL00M.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to user area. Writing GPT partition... Done. Writing EFS partition... Done. Writing SBL1 partition... Done. Writing SBL2 partition... Done. Writing PARAM partition... Done. Writing KERNEL partition... Done. Writing RECOVERY partition... Done. Writing CACHE partition... Done. Writing MODEM partition... Done. Smart Repair is successfully complete. SW: 1.3.4; FW: 1.16. Disconnected. |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
