SL-Box Samsung & LG Box |
10-17-2012, 00:52 | #1 (permalink) |
Junior Member Join Date: Apr 2005 Age: 37
Member: 138506 Status: Offline Thanks Meter: 1 | Few questions about how to use SL-Box I tried looking on the manufacturers website where they give access to the software. But there is no support section that actually gives you clear-cut instructions on how to use the software or any sorry of tutorials. On the box there are two USB ports, and 1 LAN type port. I am totally oblivious to the fact which USB port or LAN port I need to use in order to unlock a phone. Any help would be greatly appreciated. Thanks guys! |
10-17-2012, 13:00 | #2 (permalink) |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | I answered you about rooting on your other post. If you need help make one thread for each problem, with clear title. About ports on box, never use usb to connect any phone, connect them direct to your pc. The rj45 port is usefull to unlock some phones with particular cables. |
10-20-2012, 20:27 | #3 (permalink) |
Member: 138506 Status: Offline Thanks Meter: 1 | Im trying to unlock the Samsung Galaxy S2 i727, but it says IMEI 00000000000 when i click on phone info, and when i press the unlock button it starts to do its thing, and then it just says restart phone and try again. And when i click on read codes, it says IMEI number not detected. I am using the provided red Micro USB cable with this phone. Am i using the wrong cable? |
10-20-2012, 20:29 | #4 (permalink) |
Member: 138506 Status: Offline Thanks Meter: 1 | > SL-BOX SAMSUNG V1.60 > START TIME: 15:25:20 > SAMSUNG GALAXY S2 UNLOCK: BEGIN! > SEARCHING FOR PHONE: OK! > READING INFO: OK! MODEL: SGH-I727R / SGH-I727R IMEI: 00000000000 VERSION: 4.0.4 / IMM76D FIRMWARE: SGH-I727R-user / I727RUXLF3 KERNEL: 3.0.8-perf-I727RUXLF3-CL611724 (gcc 4.4.3) CPU TYPE: MSM8660 / ARMv7 > CHECKING ROOT: NOT ROOTED! > PLEASE WAIT, RUNNING TEMP ROOT: OK! > SEARCHING FOR PHONE: OK! > CHECKING ROOT: NOT ROOTED! > PLEASE RESTART PHONE AND TRY AGAIN! > SAMSUNG GALAXY S2 UNLOCK: END! > END TIME: 15:26:26 |
10-20-2012, 23:01 | #5 (permalink) | |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | Quote:
you've got your answer in your log. | |
10-21-2012, 01:20 | #6 (permalink) |
Member: 138506 Status: Offline Thanks Meter: 1 | And if you read right underneath that it says "running temp root: ok". Which means that because there is no root, and the SL-Box is temporarily rooting it to continue the unlocking procedure and it says okay right after meaning that it was done successfully. |
10-21-2012, 08:53 | #7 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | and then again under it's written not rooted try to root manually, follow this link for more info : xda-developers - View Single Post - [HOWTO] < THE ULTIMATE NEWB GUIDE > INSTALL CWM/TWRP | ROOT | UNROOT the SKYROCKET |
10-22-2012, 23:21 | #8 (permalink) | |
Member: 138506 Status: Offline Thanks Meter: 1 | Quote:
10-26-2012, 05:59 | #11 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | Ok it's not that big a deal so if soft doesn't read it correctly. Anyway, did you root it the correct way with link I gave you ? In your log, when soft says ok after temp root, that just mean root file were send successfully, not that it work in this android version, that is why soft check root worked and says "not rooted" just after. DOn't stay stuck at this point. Root it manually, retry unlock and post log. You started this thread ten days ago, I think it's time to get a success |
10-27-2012, 16:47 | #12 (permalink) | |
10-27-2012, 17:41 | #13 (permalink) |
Member: 138506 Status: Offline Thanks Meter: 1 | Hi, okay so i tried to unlock a Galaxy S3 which is ALREADY ROOTED. So this time in the SL-Box software it says root is fine and starts, and than gives me error 1005. Now whats the issue with this thing? Here is the log: > START TIME: 12:34:52 > SAMSUNG GALAXY S3 UNLOCK: BEGIN! > SEARCHING FOR PHONE: OK! > READING INFO: OK! MODEL: SGH-T999 / d2tmo BOOT LOADER: T999VVLALH2 VERSION: 4.1.1 / JRO03L FIRMWARE: samsung/d2tmo/d2tmo:4.0.4/IMM76D/T999UVALEM:user/release-keys / T999VVLLH2 KERNEL: 3.0.42-cyanogenmod-g2cbe844 (gcc 4.6.x-google) CPU TYPE: MSM8960 / ARMv7 CARD ID: 2842454C4558415210BD01E17400B6CE > CHECKING ROOT: OK! > READING DATA: ERROR 1005! > SAMSUNG GALAXY S3 UNLOCK: END! > END TIME: 12:35:29 |
10-28-2012, 17:43 | #15 (permalink) | |
Thanks to everyone who spent their time answering my questions and helping me out! | |
