12-29-2020, 13:11 | #1 (permalink) |
Freak Poster Join Date: Mar 2009 Location: KRJ
Member: 993718 Status: Offline Thanks Meter: 91 | Can't init EMMC, Reason: DATA RCV Timeout Error other brand oppo vivo mi working good please tell me some solution Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: 8C30F9F3F3B1121F, ,FW Ver.: 02.53 CMD Pullup Level:1804 mV CMD Active Level:1826 mV Box IO Level:1800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 15010051333133424200B5FBB8842497 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2017 Rev.0x0 eMMC NAME: Q313BB , S/N: 3053172868 eMMC NAME (HEX): 513331334242 Can't init EMMC, Reason: DATA RCV Timeout Error Check Data Line! Done. Can't init device, Reason: Initialization failed Done. Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 8C30F9F3F3B1121F, ,FW Ver.: 02.53 CMD Pullup Level:1818 mV CMD Active Level:2119 mV Box IO Level:2800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Thank You |
12-29-2020, 17:41 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
Try to use pull-up resistors | |
The Following User Says Thank You to layder For This Useful Post: |
01-02-2021, 14:43 | #6 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Try to use didderent VIO. If ISP not work correctly - desolder chips and use sockets https://forum.gsmhosting.com/vbb/f67.../#post14298347 |
