Old 07-29-2020, 13:31   #1 (permalink)
jamohaki's Avatar
Member: 83397
Thanks Meter: 204
Help oppo a3s cph1803 after android frp clear dead
AFTER USE "ANDROID FRP CLEAR" PHONE DEAD HOW TO REVIVE PLEASE?
Z3X EasyJtag Software ver. 3.7.0.11
Loading eMMC GEN1 Firmware... IO: 1800 mV
Box S/N: , ,FW Ver.: 01.63
CMD Pullup Level:1887 mV
CMD Active Level:2093 mV
Box IO Level:1800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 90014A484147346132A5C1E25D7BC5D2
eMMC CSD : D02701328F5903FFFFFFFFE78A400016
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 12/2018 Rev.0xA5
eMMC NAME: HAG4a2 , S/N: 3252837755
eMMC NAME (HEX): 484147346132
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 34316 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: HAG4a2_3252837755_20200729_1513.extcsd
Warning! Main and backup partition tables differ!
Warning! One or more CRCs don't match. You should repair the disk!
Caution: Found protective or hybrid MBR and corrupt GPT.
Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB
Soft (Partitioned) Disk/Image size: 1D59FDA sectors 14.7 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200 bytes ,First/Last usable sector: 19,30777325
Partition info successfully found
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 216432
Short Android info:
Build ID: OPM1.171019.026
Release Base ID: 8.1.0
Security Path: 2020-07-05
Architecture ABI: arm64-v8a
Device manufacturer: OPPO
Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20200710.012336 release-keys
Backup saved: BuildProp_20200729_1513.txt
Detected USERDATA USERDATA : 0x0158000000 (9.299GB)
Unable to mount USERDATA , code : 95
Userdata Superblock contents::
2C42C615 EDC8FD7A 6C983A1C 1E762C2B 2D4347A9 14029F34 B785440D FEF30F11 ,BÆ.íÈýzl.:..v,+-CG©..Ÿ4·…D.þó..;
DC06F051 33975A3F 1B04E235 0BAA21E8 7FDD81ED D273AD9E 702439D4 224EEC07 Ü.ðQ3—Z?..â5.ª!è.Ý.íÒs*žp$9Ô"Nì.;
308CC041 DA648873 5046742F 9DE3BD80 61C9EFB4 21BBBCFE 5F3FF7D2 A8E652FB 0ŒÀAÚd.sPFt/.ã½.aÉï´!»¼þ_?÷Ò¨æRû;
AAE9B79C 3245F956 4E57E987 674AAC9B 62359532 1D8C393E 72FF34C4 AFE434D3 ªé·œ2EùVNWé‡gJ¬›b5•2.Œ9>rÿ4įä4Ó;
E9A2738C 4A09B8F1 5FC9EFAD 5EEA7D4B 16397FF0 CA7A11DB 2F9023B7 85448F4E é¢sŒJ ¸ñ_Éï*^ê}K.9.ðÊz.Û/.#·…D.N;
4054E9FF F8D2E47B 79DA201C 0C4A8B43 16D67170 7FB2CF5A A96FE0B7 37E302B5 @TéÿøÒä{yÚ ..J‹C.Öqp.²ÏZ©oà·7ã.µ;
817AB5D9 2BB28451 E3227860 ABD906A2 4467F6CA 8F0A2147 4C38DA5D B7485CB1 .zµÙ+²„Qã"x`«Ù.¢DgöÊ..!GL8Ú]·H\±;
82A28366 07E36C80 32D05780 BB1B1ED5 BC68B2BD 127F1E69 74CA949D 9985D390 ‚¢ƒf.ãl.2ÐW.»..Õ¼h²½...itÊ”..…Ó.;
Done.
Running:Format FRP Partition...
Box S/N: 1616120653F9FBE6, ,FW Ver.: 01.63
CMD Pullup Level:1804 mV
CMD Active Level:2052 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
EMMC ROM1 (Main User Data) Capacity: 15028 MB , 0x1D5A000 pages , 0x3AB400000 bytes
Formatting FRP...
Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) CONFIG : 0x002FC80000 (32.0KB) formatting...
Done.
Detected LINUX(Android) USERDATA : 0x0158000000 (9.299GB) , formatting...
Done.
Done.
Done.
Old 07-29-2020, 20:27   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
check you hadrware, etc
many people do this and all work fine
Old 07-31-2020, 06:36   #3 (permalink)
jamohaki's Avatar
Member: 83397
Thanks Meter: 204
everything is ok in hardware this problem started after finishing the above procidure.now phone is detected as edl.please help with step by step procedure on how to revive this phone
Old 07-31-2020, 07:48   #4 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
try to recover as where:
https://forum.gsmhosting.com/vbb/f67...ammad-2813504/
Page generated in 0.12614 seconds with 8 queries
