08-01-2017, 12:29 | #1 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Help samsung N7000 boot repair problem Loading eMMC Addon Firmware... IO: 1850 mV Warning: CMD Pullup Level (247 mV) too low , check cables etc.! CMD Active Level:1577 mV Box IO Level:1850 mV CLK Rate:14000 khz HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. |
08-01-2017, 14:47 | #3 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: E a r T h
Member: 216094 Status: Offline Thanks Meter: 321 | Quote:
08-02-2017, 05:37 | #6 (permalink) |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | ompression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 1850 mV Box S/N: xxxxxxxxxxx, ,FW Ver.: 01.60 CMD Pullup Level:350 mV CMD Active Level:1557 mV Box IO Level:1850 mV CLK Rate:14000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. |
08-02-2017, 06:47 | #8 (permalink) | |
No Life Poster Join Date: May 2009 Location: mumbai wadala
Member: 1037372 Status: Offline Thanks Meter: 557 | Quote:
Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 1850 mV Warning: CMD Pullup Level (247 mV) too low , check cables etc.! CMD Active Level:1577 mV Box IO Level:1850 mV CLK Rate:14000 khz HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. | |
08-02-2017, 08:53 | #12 (permalink) | |
Yes its Dead. N7000 Emmc After Tp Dected 0000 But Fimware Update always Failed Need To Replace it. | |
The Following User Says Thank You to naushad09 For This Useful Post: |
