07-29-2020, 13:31 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Location: coast Age: 53
Member: 83397 Status: Offline Thanks Meter: 204 | Help oppo a3s cph1803 after android frp clear dead Z3X EasyJtag Software ver. 3.7.0.11 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: , ,FW Ver.: 01.63 CMD Pullup Level:1887 mV CMD Active Level:2093 mV Box IO Level:1800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A484147346132A5C1E25D7BC5D2 eMMC CSD : D02701328F5903FFFFFFFFE78A400016 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 12/2018 Rev.0xA5 eMMC NAME: HAG4a2 , S/N: 3252837755 eMMC NAME (HEX): 484147346132 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 34316 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HAG4a2_3252837755_20200729_1513.extcsd Warning! Main and backup partition tables differ! Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB Soft (Partitioned) Disk/Image size: 1D59FDA sectors 14.7 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 19,30777325 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB) Short EXT fs info: Size: 3.298GB Block size: 4.0KB Inode size: 256 Inodes: 216432 Short Android info: Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Security Path: 2020-07-05 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20200710.012336 release-keys Backup saved: BuildProp_20200729_1513.txt --------------------------------------------- Detected USERDATA USERDATA : 0x0158000000 (9.299GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 2C42C615 EDC8FD7A 6C983A1C 1E762C2B 2D4347A9 14029F34 B785440D FEF30F11 ,BÆ.íÈýzl.:..v,+-CG©..Ÿ4·…D.þó..; DC06F051 33975A3F 1B04E235 0BAA21E8 7FDD81ED D273AD9E 702439D4 224EEC07 Ü.ðQ3—Z?..â5.ª!è.Ý.íÒs*žp$9Ô"Nì.; 308CC041 DA648873 5046742F 9DE3BD80 61C9EFB4 21BBBCFE 5F3FF7D2 A8E652FB 0ŒÀAÚd.sPFt/.ã½.aÉï´!»¼þ_?÷Ò¨æRû; AAE9B79C 3245F956 4E57E987 674AAC9B 62359532 1D8C393E 72FF34C4 AFE434D3 ªé·œ2EùVNWé‡gJ¬›b5•2.Œ9>rÿ4įä4Ó; E9A2738C 4A09B8F1 5FC9EFAD 5EEA7D4B 16397FF0 CA7A11DB 2F9023B7 85448F4E é¢sŒJ ¸ñ_Éï*^ê}K.9.ðÊz.Û/.#·…D.N; 4054E9FF F8D2E47B 79DA201C 0C4A8B43 16D67170 7FB2CF5A A96FE0B7 37E302B5 @TéÿøÒä{yÚ ..J‹C.Öqp.²ÏZ©oà·7ã.µ; 817AB5D9 2BB28451 E3227860 ABD906A2 4467F6CA 8F0A2147 4C38DA5D B7485CB1 .zµÙ+²„Qã"x`«Ù.¢DgöÊ..!GL8Ú]·H\±; 82A28366 07E36C80 32D05780 BB1B1ED5 BC68B2BD 127F1E69 74CA949D 9985D390 ‚¢ƒf.ãl.2ÐW.»..Õ¼h²½...itÊ”..…Ó.; Done. Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.7.0.11 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: 1616120653F9FBE6, ,FW Ver.: 01.63 CMD Pullup Level:1804 mV CMD Active Level:2052 mV Box IO Level:1800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A484147346132A5C1E25D7BC5D2 eMMC CSD : D02701328F5903FFFFFFFFE78A400016 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 12/2018 Rev.0xA5 eMMC NAME: HAG4a2 , S/N: 3252837755 eMMC NAME (HEX): 484147346132 EMMC ROM1 (Main User Data) Capacity: 15028 MB , 0x1D5A000 pages , 0x3AB400000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 34316 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Warning! Main and backup partition tables differ! Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB Soft (Partitioned) Disk/Image size: 1D59FDA sectors 14.7 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 19,30777325 Partition info successfully found Formatting FRP... Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) , formatting... Done. Detected LINUX(Android) CONFIG : 0x002FC80000 (32.0KB) formatting... Done. Detected LINUX(Android) USERDATA : 0x0158000000 (9.299GB) , formatting... Done. Done. Done. |
07-31-2020, 06:36 | #3 (permalink) |
Member: 83397 Status: Offline Thanks Meter: 204 | everything is ok in hardware this problem started after finishing the above procidure.now phone is detected as edl.please help with step by step procedure on how to revive this phone |
