05-07-2020, 10:48 | #32 (permalink) |
No Life Poster Join Date: Nov 2014
Member: 2289628 Status: Offline Thanks Meter: 226 | What about this RPMB ????? It can repair dead boot or replace with new eMMC ? Code: EasyJtag Suite Classic ver.: 3.6.2.3 / wxWidgets 3.1.3-W-U started. OS ver.: Windows 10 (build 18363), 64-bit edition. Admin rights FAIL Android Explorer ver:1.0.0.13 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.0.6 QUALCOMM Direct ver:1.0.6936.8894 EasyJTAG SPI Plugin ver:1.1.1.11 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 10.0.18362.1 Z3X Card Serial : AA79-A19D , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : ACTIVATED Z3X Card Activation [SAMS] : ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 1 serial devices COM13 USB\VID_1781&PID_AAAC&REV_0100&MI_00 USB Serial Device (COM13) Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN2 Firmware... IO: 2800 mV Initial pull results: clock: 1373mV pin connected ok command: 1534mV pin connected ok data0: 1542mV pin connected ok data1: 1539mV pin connected ok data2: 1555mV pin connected ok data3: 1545mV pin connected ok data4: 1533mV pin connected ok data5: 1541mV pin connected ok data6: 1534mV pin connected ok data7: 1553mV pin connected ok Box S/N: 06942E3DA29E480D, ,FW Ver.: 02.50 Box IO Level:2800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN2 Firmware... IO: 1800 mV Initial pull results: clock: 731mV pin connected ok command: 913mV pin connected ok data0: 911mV pin connected ok data1: 905mV pin connected ok data2: 910mV pin connected ok data3: 909mV pin connected ok data4: 909mV pin connected ok data5: 909mV pin connected ok data6: 914mV pin connected ok data7: 909mV pin connected ok Box S/N: 06942E3DA29E480D, ,FW Ver.: 02.50 Box IO Level:1800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A68433861503E01671665D72601 eMMC CSD : D02700328F5903FFFFFFFFEF8E400043 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 02/2019 Rev.0x1 eMMC NAME: hC8aP> , S/N: 1729521111 eMMC NAME (HEX): 68433861503E EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 5733 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: hC8aP>_1729521111_20200507_1433.extcsd Caution: invalid backup GPT header, but valid main header! EFI Table CRC Check FAIL. Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFDD sectors 58.2 GiB Disk identifier (GUID): F9F21FFF-A8D4-5F0E-9746-594869AEC34E Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142719 Partition info successfully found Done. |
05-07-2020, 11:34 | #33 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
Can I repair car engine or need replace it? | |
The Following 3 Users Say Thank You to layder For This Useful Post: |
05-10-2020, 11:52 | #36 (permalink) |
Major Poster Join Date: Nov 2012 Location: thane
Member: 1835157 Status: Offline Thanks Meter: 0 | I also have issue in samsung j810f emmc was gone and i made backup and write in same name emcp... But phone dosent respond... Rpmb counter was not clean...... But emcp name was same.... So i want to know that emcp will work or not |
06-14-2020, 07:57 | #41 (permalink) |
Member: 2289628 Status: Offline Thanks Meter: 226 | Right now same mobile I dont have to test with 4/8 bit mode. Could you explain in easy way with yes or no. If Counter = 0, status = not clean Counter = 0, Status = may be not clean Then mobile would be boot up or no after change the eMMC ??? |
06-14-2020, 19:58 | #42 (permalink) |
Member: 2289628 Status: Offline Thanks Meter: 226 | Now!! I have in my hand Nokia 3 (TA-1032) with Samsung eMMC KMQE10013M. And its showing that Counter :0, Respose: Not Clean with MLC/SLC life 80-90% consumed. If I want to rechange emmc with new one then mobile will work properly or no ??? Or both CPU+eMMC changed will be help .... And other thing is that I cant get eMMC firmware update file from Easy Jtag Menu to clear MLC/SLC life. |
06-15-2020, 00:22 | #43 (permalink) | |
how you return phisycally lfetime condition to eMMC cells? via new emmc firmware? how you repair HDD with bad surface? via update HDD firmware or install new Windows? how you return youthfulness to old people? via new words? =============== if you want to change eMMC you need use new eMMC with clean RPMB Last edited by layder; 06-15-2020 at 00:33. | |
The Following User Says Thank You to layder For This Useful Post: |
06-15-2020, 00:46 | #45 (permalink) | |
Member: 2289628 Status: Offline Thanks Meter: 226 | Quote:
