10-13-2021, 13:51 | #1 (permalink) |
Product Supporter Join Date: Sep 2017 Location: MH Unlocker Pro
Member: 2753718 Status: Offline Sonork: FB : MH Unlocker Pro Thanks Meter: 811 | SAMSUNG SM-A127F Fully Connected And R&W&FRP All Jobs Done By Easy Jtag Plus Bellow is some task's logs and screenshots The GT Road Jtager's Team BR. SeharH |
The Following User Says Thank You to SeharH For This Useful Post: |
03-10-2022, 09:48 | #4 (permalink) |
Freak Poster Join Date: May 2017 Location: Africa, Uganda
Member: 2721034 Status: Offline Thanks Meter: 50 | I have proper soldering but im still getting error cmd time error crc error Cmd pull up levels help me sir Here* Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 2200 mV Box S/N: 41CA0C8A0DD5451C, ,FW Ver.: 02.53 Warning: CMD Pullup Level (190 mV) too low , check cables etc.! CMD Active Level:213 mV Box IO Level:2200 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done.Setting* EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 36 MHz CMD Pullup Level: 784 mV CMD Active Level: 1020 mV Can't init device. Reason: CMD CRC Error |
