Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 04-19-2014, 20:42   #1 (permalink)
Member: 2153654
HELP - Samsung Galaxy Note 3 N900A IMEI REPAIR
Sorry if this may seem like a stupid questions. I'm pretty new to the whole IMEI repair scene. I've been able to repair the IMEI on S3 and S4. But not the Note 3.
I have a Galaxy Note 3 N900A - Rooted Already.
I am able to set the USB Settings to DM+MODEM+ADB through *#0808#
When I press *#9090# - the phone says
DIAG CONFIG
Not Support
I'm not able to change the "Diag config" to "USB" value ...
PLEASE advise on what I need to do so that I can put the phone into Diagnostic Mode.
Thank you in advance.
Old 04-19-2014, 23:10   #2 (permalink)
Member: 737720
Thanks Meter: 1,421
DIAG CONFIG
Not Support
U don't need to dial *#9090# just connect the USB cable and select the imei and clk repair imei and fellow the instructions
Old 04-19-2014, 23:44   #3 (permalink)
Member: 2153654
I tried that but I get this error
Platform: Samsung Android
Selected port: COM8
Selected model: SM-N900A
Mode: Normal
Phone model: SM-N900A
Firmware compiled date: Oct 17 2013
Firmware compiled time: 16:59:54
Firmware released date: Oct 17 2013
Firmware released time: 16:59:54
SW version: SET_BY_CM
Old IMEI: 357572-05-366937-7
New IMEI: 357507-05-000028-3
Creating NVM backup
Reading NVM done!
Connecting to ADB, please waite...
Proper android device not found. Make shure that "USB debug" option on the device is turned on.
Write IMEI failed
USB debug is definitely turned on in Developers Options. Anything else I'm missing here?
Old 04-20-2014, 00:28   #4 (permalink)
mrdnice88347's Avatar
Member: 2157134
Thanks Meter: 8
make sure you fellow all the steps 1 by 1 and keep touching the screen on while its going thor the processes dont let the screen shut off keep it on ok.. I just did my N900T.. Repaired it.. all this steps worked for me..
Old 04-20-2014, 00:34   #5 (permalink)
ElBerryKM13's Avatar
Member: 1414809
Thanks Meter: 155
Install adb drivers on your pc. After that make sure you accept a prompt on your phone saying that you trust your computer. If you don't do that then octopus won't recognize the phone and you will get an adb error.
Old 04-20-2014, 00:45   #6 (permalink)
Member: 2153654
ADB Access is already granted in SuperSU. I already granted access and it keeps failing. This is so frustrating. I kno wI have all ADB drivers installed because I was able to repair IMEI on S3 and S4 with the same computer.
Old 04-20-2014, 07:19   #7 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,413
Hello.
USB Debugging Mode is not turned on in your device:
Please, re-start the phone, turn on USB Debugging Mode and try again.
Old 04-20-2014, 07:21   #8 (permalink)
Member: 2157134
Thanks Meter: 8
Team when I add my own imei and unlock the n900t..
Sent from my SGH-M919 using Tapatalk
Old 04-20-2014, 07:27   #9 (permalink)
Member: 1146942
Sonork: 100.1587278
After perform Unlock operation for SM-N900T, IMEI will be set to service value "35750705000001/0".
By performing Repair IMEI operation for SM-N900T, it is possible to repair IMEI to one of the service IMEIs from the list. Currently no solution, how to repair IMEI to original value.
Old 04-20-2014, 07:41   #10 (permalink)
Member: 2157134
Thanks Meter: 8
So only on the listing I can repair the imei, but I can type my own imei.. Can I or I can't.
Old 04-20-2014, 07:54   #11 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 370
not for unlock need change you original to any super imei of list cant write oroginal imei
Old 04-20-2014, 10:43   #12 (permalink)
Member: 1146942
Sonork: 100.1587278
Yes, You can write any IMEI, but after of repairing IMEI, network will be not available (not active). Network will be active only if You write IMEI from the list (service IMEI).
Old 04-20-2014, 14:53   #13 (permalink)
Member: 2157134
Thanks Meter: 8
I get a error message saying I will to use the drop down imei..
Old 04-20-2014, 15:05   #14 (permalink)
Member: 1146942
Sonork: 100.1587278
What is the error exactly? Post here full Software log with Repair IMEI procedure and error.
Old 04-20-2014, 15:07   #15 (permalink)
Member: 2157134
Thanks Meter: 8
Sent from my iPhone using Tapatalk
Page generated in 0.22890 seconds with 8 queries
