Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 04-20-2014, 15:09   #16 (permalink)
mrdnice88347's Avatar
Member: 2157134
Thanks Meter: 8
It's not letting change it.. It's repaired already..
Sent from my iPhone using Tapatalk
Old 04-21-2014, 02:14   #17 (permalink)
Member: 1179274
same proble here I cant get my Samsung m900t *#9090# diag not support
I have original cable and I tried nspro cable nothing help please my phone now is 0/00
Old 04-21-2014, 11:48   #18 (permalink)
Member: 2157134
Thanks Meter: 8
Ok I got it unlocked the N900T,, Now How can I add a new imei without using the service imei drop down selection.. Plus if I change the imei will the unlock go away..
Old 04-21-2014, 16:10   #19 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,413
As I have said above, by performing Repair IMEI operation for SM-N900T, it is possible to repair IMEI to one of the service IMEIs from the list. Currently no solution, how to repair IMEI to original value.
Old 04-21-2014, 16:15   #20 (permalink)
Member: 2157134
Thanks Meter: 8
OK
Sent from my SGH-M919 using Tapatalk
Old 04-21-2014, 16:16   #21 (permalink)
Member: 2157134
Thanks Meter: 8
But you guys are going to fix that right..
Old 04-21-2014, 16:50   #22 (permalink)
Member: 1146942
Sonork: 100.1587278
Yes, we still work on solution.
Old 04-21-2014, 16:52   #23 (permalink)
Member: 2157134
Thanks Meter: 8
Great.. Again great job guys
Old 04-22-2014, 04:04   #24 (permalink)
Member: 1179274
but my problem is I cant get n900t on 2 notes *#9090# diag notsuport any thing on that now 2 notes 00 imei ...
Old 04-22-2014, 07:05   #25 (permalink)
Member: 1146942
Sonork: 100.1587278
@ ernietech
To connect SM-N900T, do the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Press Home button.
10. Restart phone.
11. Press "Read Info" in software and post here Software log with this info.
Old 04-22-2014, 15:31   #26 (permalink)
Member: 1179274
fallow instructions that's I I hear listen the question is on the not 3 n900t how to put
diag option on thas what the instruction say but on tmobile n900t 4.3 *#9090# its not supported any options to change that ..... so I did the steps now I have 2 notes /00
imei...
Old 04-22-2014, 15:43   #27 (permalink)
Member: 1146942
Sonork: 100.1587278
Carefully and attentively perform all the steps 1-10 to connect the phone. Then write here, what device appears in PC Device Manager, when You perform these steps and connect the phone to PC. Look, whether You have installed driver for this device.
Also look here: Samsung SM-N900T Unlock with Octoplus Box - YouTube.
Old 04-24-2014, 19:51   #28 (permalink)
Member: 2153654
Originally Posted by Octopus box View Post
Hello.
USB Debugging Mode is not turned on in your device:
Please, re-start the phone, turn on USB Debugging Mode and try again.
USB Debugging is definitely ON.
But Octopus box still not recognizing the phone.
Please advise what to do.
Old 05-02-2014, 17:52   #29 (permalink)
Member: 2157134
Thanks Meter: 8
I'm unlocked a N900T Note 3 now I was wondering if I can use service imei fix, will the phone still be unlocked..
Old 05-03-2014, 07:35   #30 (permalink)
Member: 1146942
Sonork: 100.1587278
@ mrdnice88347
Yes, You can write any service IMEI from the list for this device and the phone will remains unlocked.
Page generated in 0.20030 seconds with 8 queries
