04-19-2014, 20:42 | #1 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2153654 Status: Offline Thanks Meter: 1 | HELP - Samsung Galaxy Note 3 N900A IMEI REPAIR I have a Galaxy Note 3 N900A - Rooted Already. I am able to set the USB Settings to DM+MODEM+ADB through *#0808# When I press *#9090# - the phone says DIAG CONFIG Not Support I'm not able to change the "Diag config" to "USB" value ... PLEASE advise on what I need to do so that I can put the phone into Diagnostic Mode. Thank you in advance. |
04-19-2014, 23:10 | #2 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: Kanada
Member: 737720 Status: Offline Thanks Meter: 1,421 | Quote:
04-19-2014, 23:44 | #3 (permalink) | |
Member: 2153654 Status: Offline Thanks Meter: 1 | Quote:
Platform: Samsung Android Selected port: COM8 Selected model: SM-N900A Mode: Normal Phone model: SM-N900A Firmware compiled date: Oct 17 2013 Firmware compiled time: 16:59:54 Firmware released date: Oct 17 2013 Firmware released time: 16:59:54 SW version: SET_BY_CM Old IMEI: 357572-05-366937-7 New IMEI: 357507-05-000028-3 Creating NVM backup Reading NVM done! Connecting to ADB, please waite... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed USB debug is definitely turned on in Developers Options. Anything else I'm missing here? | |
04-20-2014, 00:28 | #4 (permalink) |
Freak Poster Join Date: Mar 2014
Member: 2157134 Status: Offline Thanks Meter: 8 | make sure you fellow all the steps 1 by 1 and keep touching the screen on while its going thor the processes dont let the screen shut off keep it on ok.. I just did my N900T.. Repaired it.. all this steps worked for me.. |
04-20-2014, 00:34 | #5 (permalink) |
Freak Poster Join Date: Oct 2010
Member: 1414809 Status: Offline Thanks Meter: 155 | Install adb drivers on your pc. After that make sure you accept a prompt on your phone saying that you trust your computer. If you don't do that then octopus won't recognize the phone and you will get an adb error. |
04-20-2014, 00:45 | #6 (permalink) |
Member: 2153654 Status: Offline Thanks Meter: 1 | ADB Access is already granted in SuperSU. I already granted access and it keeps failing. This is so frustrating. I kno wI have all ADB drivers installed because I was able to repair IMEI on S3 and S4 with the same computer. |
04-20-2014, 07:19 | #7 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,435 | Hello. USB Debugging Mode is not turned on in your device: Quote:
04-20-2014, 07:27 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,435 | After perform Unlock operation for SM-N900T, IMEI will be set to service value "35750705000001/0". By performing Repair IMEI operation for SM-N900T, it is possible to repair IMEI to one of the service IMEIs from the list. Currently no solution, how to repair IMEI to original value. |
04-20-2014, 10:43 | #12 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,435 | Quote:
04-20-2014, 15:05 | #14 (permalink) | |
