03-03-2016, 06:34 | #18 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Am In Wealth Always!
Member: 576282 Status: Offline Thanks Meter: 145 | Quote:
Sir do u have rooting solution for 5.0.1 let me try "direct unlock" not "fast unlock" because I tried it and it ask for root and I believe that "direct unlock" might work it? Logs; Welcome to Octoplus/Octopus Box Samsung software version 2.2.1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-N910V Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM24 Mode: Normal Phone model: SM-N910V Firmware compiled date: May 29 2015 Firmware compiled time: 17:00:00 Firmware released date: Jul 30 2015 Firmware released time: 14:26:02 Phone IMEI: 990004-82-052224-5 SW version: MPSS.DI.3.0.c5-00352-M9625TAARANSZM-1.12401.1.19811.1.20883.1.21300.1 Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM24 Selected model: SM-N910V Reading info... Mode: Normal Firmware compiled date: May 29 2015 Firmware compiled time: 17:00:00 Firmware released date: Jul 30 2015 Firmware released time: 14:26:02 SW Version: MPSS.DI.3.0.c5-00352-M9625TAARANSZM-1.12401.1.19811.1.20883.1.21300.1 ADB server killed. Detected phone model: SM-N910V Firmware compiled date: Fri Jul 31 15:49:35 KST 2015 PDA version: N910VVRU2BOG5 CSC version: N910VVZW2BOG5 SW version: N910VVRU2BOG5 Phone SN: 00000000000 Android version: 5.0.1 (LRX22C) Checking Root: Phone is not Rooted. Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.2.1 software version | |
03-03-2016, 11:23 | #19 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to use different SIM cards. Check whether phone's IMEI is not in "black" list of Network provider. As suggested mr.jsolisdc, check whether phone has correctly configured APN. |
03-03-2016, 14:59 | #20 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Quote:
and yesterday 4.4.4 also Network not come. actually Octopus Software can Unlock properly this Mobile? ( Even NV can't Repair in rooted Mobile.) | |
03-03-2016, 17:11 | #23 (permalink) | |
Anyway, I post result again with more deep details bellow... 01. This is my own Working 3G SIM which one I am going to test with N910V 4.4.4 02. Here is I am put SIM Card and IMEI also show from device Sticker. 03. After Powering ON Mobile Network Show Searching.... 04. My Mobile SIM App showing on inside Mobile Menu. 05. Mobile Software Information. 06. Mobile IMEI from Settings>About>Information Status>IMEI 07. Network Searching Error. even select Global later from popup option. 08. POPUP option for Global selecting. 09. I did also APN Setting but No Network Still. 10. I Hope this is quite enough for you Questions Support. | |
03-04-2016, 14:28 | #25 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to reflash the phone with "N910VVRU2BOG5_N910VVZW2BOG5_VZW_Android_5.0.1 " firmware from the Support Area, then try to perform an "Unlock" operation again. Post here the result. |
03-05-2016, 12:21 | #26 (permalink) | |
Code: Welcome to Octoplus/Octopus Box Samsung software version 2.2.1 ---------------------------------------------------------------------------------- Selected firmware file: N910V VRU2BOG5_N910VVZW2BOG5_VZW_Android_5.0.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-N910V into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing DBI section... DBI section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Firmware writing successfully completed. Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM35 Selected model: SM-N910V Reading info... Mode: Normal Firmware compiled date: May 29 2015 Firmware compiled time: 17:00:00 Firmware released date: Jul 30 2015 Firmware released time: 14:26:02 SW Version: MPSS.DI.3.0.c5-00352-M9625TAARANSZM-1.12401.1.19811.1.20883.1.21300.1 Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-N910V Firmware compiled date: Fri Jul 31 15:49:35 KST 2015 PDA version: N910VVRU2BOG5 CSC version: N910VVZW2BOG5 SW version: N910VVRU2BOG5 Phone SN: 00000000000 Android version: 5.0.1 (LRX22C) Checking Root: Phone is not Rooted. Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.2.1 software version ---------------------------------------------------------------------------------- Code: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM35 Selected model: SM-N910V Reading info... Mode: Normal Firmware compiled date: May 29 2015 Firmware compiled time: 17:00:00 Firmware released date: Jul 30 2015 Firmware released time: 14:26:02 SW Version: MPSS.DI.3.0.c5-00352-M9625TAARANSZM-1.12401.1.19811.1.20883.1.21300.1 Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-N910V Firmware compiled date: Fri Jul 31 15:49:35 KST 2015 PDA version: N910VVRU2BOG5 CSC version: N910VVZW2BOG5 SW version: N910VVRU2BOG5 Phone SN: 00000000000 Android version: 5.0.1 (LRX22C) Checking Root: Phone is not Rooted. Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.2.1 software version | |
03-05-2016, 12:43 | #27 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please upload *.log and *.logx files of performed operations to any file-sharing service and post here download link. *.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. |
03-05-2016, 13:38 | #28 (permalink) | |
same as me, below are logs; Flashing log; Welcome to Octoplus/Octopus Box Samsung software version 2.2.1 Selected firmware file: N910VVRU2BOG5_N910VVZW2BOG5 _N910VVRU2BOG5_HOME.oct Please put the phone into Download Mode and connect USB cable. To put SM-N910V into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing DBI section... DBI section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Firmware writing successfully completed. Performed by 2.2.1 software version Unlocking log after flashing; Welcome to Octoplus/Octopus Box Samsung software version 2.2.1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-N910V Mode: Normal Phone model: SM-N910V Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM24 Selected model: SM-N910V Mode: Normal Phone model: SM-N910V Firmware compiled date: May 29 2015 Firmware compiled time: 17:00:00 Firmware released date: Jul 30 2015 Firmware released time: 14:26:02 Phone IMEI: 990004-82-052224-5 SW version: MPSS.DI.3.0.c5-00352-M9625TAARANSZM- 1.12401.1.19811.1.20883.1.21300.1 Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM24 Selected model: SM-N910V Reading info... Mode: Normal Firmware compiled date: May 29 2015 Firmware compiled time: 17:00:00 Firmware released date: Jul 30 2015 Firmware released time: 14:26:02 SW Version: MPSS.DI.3.0.c5-00352-M9625TAARANSZM- 1.12401.1.19811.1.20883.1.21300.1 Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.2.1 software version But the phone is still not unlocked, please how will I get it done? | |
03-05-2016, 13:39 | #29 (permalink) | |
