Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 03-06-2012, 14:13   #1 (permalink)
Member: 558339
Thanks Meter: 10
vocano scan pinput mtk very slow (read post number 62)
Volcano Updated: 2012-03-02
Connecting...
Connection successful,connected state!
Version: V3.8
SN:001-619-535
Port:COM11
Detecting rx and tx...
Vcc: null
Gnd: null
Detection initiated, connect the phone and power on it...
Individual phone must have VCC or GND pins set in order to detect pinouts. Detection requires a longer period of time, please be patient...
Failed to detect.
Vcc: 18
Gnd: 19 21
User stop
Vcc: null
Gnd: 4 5
User stop
Vcc: 18
Gnd: 21 23
MT6235, RX: 20, TX: 24, Pull down: 22
Detection completed with 138.77 seconds!
Connecting...
Version: V3.8
SN:001-619-535
Port:COM11
Vcc: 18
Gnd: 21 23 24
Analyzing Rx and Tx...
User stop
Pinouts are not fonud!
Vcc: null
Gnd: 4 5
User stop
Vcc: 18
Gnd: 21 23 24
Failed to detect.
Vcc: 18
Gnd: 21 23
Failed to detect.
Available Ports:COM1 COM11 COM63 COM64
Waiting for phone's response,please press Power on/off button
IF Software stop here.you see Stop(red) button become Run(Green) please press and hold power button till boot downloading not start,then release power button,when you releaes power button if boot downloading stop this mean you have HARDWARE fault in your mobile
Vcc: 18
Gnd: 21 23
User stop
Clearing pinouts...
>>Clearing pinouts complete!
[IMG]http://*************************/clear.gif[/IMG] Reply With Quote
Old 03-06-2012, 15:08   #2 (permalink)
Member: 1716315
Thanks Meter: 4,634
its not actually slow as you shown
just connect cable in correct way and press and hold power button
Old 03-06-2012, 15:54   #3 (permalink)
Member: 558339
Thanks Meter: 10
I have tried many times and only once the connection is
MT6235, RX: 20 TX: 24, Pull down: 22
Detection
remaining failed
Old 03-06-2012, 16:09   #4 (permalink)
Member: 1716315
Thanks Meter: 4,634
sure mobile connector not good.....
Old 03-06-2012, 16:42   #5 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,070
Try this method after pin out set just disconnect power cable and -ve reconnect again press power on .
Old 03-06-2012, 18:51   #6 (permalink)
way2unlock's Avatar
Member: 582682
Sonork: 100.1607124
Thanks Meter: 136
Dear sir really slow identify pinout. I chek with speadtrum CPU
Format done instant but pinout slow please give proper way or solve this thanx
The Following User Says Thank You to way2unlock For This Useful Post:
Old 03-06-2012, 19:08   #7 (permalink)
ferhel's Avatar
Member: 504865
Thanks Meter: 213
is that true Slow identify pinout..????
waiting For Fixing Slow identify pinout First
Old 03-07-2012, 01:13   #8 (permalink)
Member: 558339
Thanks Meter: 10
flash cpu infinion
Waiting for response, please press the power button
User termination!
Program termination!
Vcc: 4
Gnd: 2
Detection process abnormal.
Old 03-07-2012, 01:14   #9 (permalink)
Member: 558339
Thanks Meter: 10
Vcc: 4
Gnd: 2
Infineon7880 RX: 9, TX: 7
Setting...
Pinouts setting complete!
User termination!
Old 03-07-2012, 01:15   #10 (permalink)
Member: 558339
Thanks Meter: 10
hardware your box proleam ?
Old 03-07-2012, 01:18   #11 (permalink)
Member: 558339
Thanks Meter: 10
Old 03-07-2012, 02:54   #12 (permalink)
Member: 558339
Thanks Meter: 10
MTK chip volcano can not flash with box
Old 03-07-2012, 03:01   #13 (permalink)
Member: 1716315
Thanks Meter: 4,634
Connecting...
Version: V3.8
SN:001-619-535
Port:COM11
Vcc: null
Gnd: null
Failed to detect.
Vcc: 18
Gnd: 19 21
User stop
Vcc: null
Gnd: 4 5
User stop
Vcc: 18
Gnd: 21 23
Connecting...
Version: V3.8
SN:001-619-535
Port:COM11
Vcc: 18
Gnd: 21 23 24
User stop
Vcc: null
Gnd: 4 5
User stop
Vcc: 18
Gnd: 21 23 24
Failed to detect.
Vcc: 18
Gnd: 21 23
Failed to detect.
Vcc: 18
Gnd: 21 23
User stop
Clearing pinouts...
There is surely some problem somewhere.... Could you try this please?
1.please connect a 9V adaptor, press volcano box power-on button
2.detect again,to check whether it's pc usb-port power supply is not enough or stable
Also for kindly tips, detecting mtk program is NP for sure,if it still takes long time,check hardware problem or
1.main cable and connector whether connected hardly?
2.volcano box self-test is normal?
3.pc power supply is stable?
4.do you clip VCC/GND correctly and connected well?
The Following User Says Thank You to Volcano Box For This Useful Post:
Old 03-07-2012, 03:18   #14 (permalink)
Member: 558339
Thanks Meter: 10
after hooking 9v adpater situation has not improved, still does not scan the battery out while MTK flash is ok gpg MTK box, all china phone power tests are normal
Old 03-07-2012, 03:26   #15 (permalink)
Member: 558339
Thanks Meter: 10
gpg ok all
SMSC number Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 08-17-2019 05:35
Eeprom reading KLImax Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-22-2011 15:55
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? MyKe Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-26-1999 14:31
Page generated in 0.26389 seconds with 9 queries
