Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
10-26-2018, 11:16 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: London, UK
Member: 178513 Status: Offline Thanks Meter: 109 | Samsung S8 G950F FRP Binary 4 Combination I got this S8 G950F it's have OREO binary 4 DO you have any solution for binary 4 combination file to bypass FPR? I got a link as well in YouTube but the phone is blacklisted so the solution will not work for me. It might be helpful to someone else: Regards, Carmelo. Last edited by ...:::::NP™:::::...; 10-26-2018 at 19:00. Reason: YouTube view on the forums. |
The Following User Says Thank You to Albelektronik For This Useful Post: |
10-26-2018, 11:46 | #2 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
COMBINATION_FA70_G950FXXU4ARI1_CL12792727_QB198416 86_REV00_user_mid_noship.tar.md5.rar Download: COMBINATION_FA70_G950FXXU4ARI1_CL12792727_QB198416 86_REV00_user_mid_noship.tar.md5 | |
The Following 2 Users Say Thank You to amleto90 For This Useful Post: |
10-26-2018, 18:11 | #5 (permalink) | |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 53198 Status: Offline Sonork: 100.1589499 Thanks Meter: 819 | Quote:
The Following User Says Thank You to Star75 For This Useful Post: |
10-26-2018, 18:42 | #6 (permalink) | |
http://forum.gsmhosting.com/vbb/f684...40/index2.html | |
10-26-2018, 18:53 | #8 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | [QUOTE=Albelektronik;13384376]Thanks guys for your prompt help. Read the link of the post that I wrote above, without using the method the hush sms method, using the combination and what you have to do if you use the first method install the combination via box via adb reset the frp do the hard reset of the phone then from active developer options the voices unlock and usb debugging do another factory reset and then flash the firmware of 3 single files ap, bl, and home_csc do not use csc but home _csc in case it does not succeed the reset operation frp pass to the second method as written in the link of the post above |
10-29-2018, 13:02 | #9 (permalink) | |
Member: 178513 Status: Offline Thanks Meter: 109 | [QUOTE=amleto90;13384383] Quote:
Can it be done with odin and chimera something? | |
10-29-2018, 13:47 | #10 (permalink) | |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | [QUOTE=Albelektronik;13388074] Quote:
with chimera you can flash the firmware, but you do not have the frp reset option via adb for g950f, but you can try to select another model like g925f or g935f that supports the frp reset operation via adb once the combination is installed, before what operation did you perform to reset the frp when you installed the combination as you flashed the stock firmware in 4 files or in 3 files? | |
10-29-2018, 17:27 | #11 (permalink) |
Member: 178513 Status: Offline Thanks Meter: 109 | Good idea i will try to chose a different model on chimera. Yes basically i have a stock firmware with 4 files, i tried the home on csc but it's terminated with error regarding the hidden file. I'm trying Chimera FRP Reset. Thanks for the patience and help. Regards, Carmelo. |
10-29-2018, 17:36 | #12 (permalink) | |
Member: 178513 Status: Offline Thanks Meter: 109 | [QUOTE=amleto90;13388150] Quote:
Even it's not was supported up to binary 2 | |
10-29-2018, 17:38 | #13 (permalink) | |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | [QUOTE=Albelektronik;13388563] Quote:
In case you have not tried make the flash of the firmware files in 3 files use, ap, bl and csc_home do not use csc f you have z3x try to select another model like g935f and reset frp via adb with the installed combination | |
10-29-2018, 17:40 | #14 (permalink) | |
Member: 178513 Status: Offline Thanks Meter: 109 | [QUOTE=amleto90;13388567] Quote:
I'm trying. | |
