Dashboard Servicing all digital dashboards |
06-08-2009, 03:59 | #1 (permalink) |
Junior Member Join Date: Jun 2009 Location: Louisville KY USA
Member: 1048166 Status: Offline Thanks Meter: 0 | toyota dash dump help please if you can FFFF4774FFFFFF44FF47FF44FF43FF40 FF43FF40FF43FF40FF43FF40FF43FF40 FF43FF40FF43FF40FF43FF40FF43FF40 FF43FF40FF43FF40FF43FF40FF43FF40 FF43FF40FF43FF40FF43FF40FF43FF40 FF43FF40FF43FF40FF43FF40FF43FF40 FF43FF40FF43FF40FF43FF40FF43FF40 FF43FF40FF43FF40FF43FF40FF43FF40 Thanks, carlford |
06-08-2009, 04:33 | #2 (permalink) |
Major Poster Join Date: Jan 2009 Location: Ahmedabad,India Age: 44
Member: 937462 Status: Offline Sonork: ideas Thanks Meter: 1 | Try to read rules governing forum here http://forum.gsmhosting.com/vbb/showthread.php?t=502650 Peace |
06-08-2009, 04:38 | #4 (permalink) | |
Member: 937462 Status: Offline Sonork: ideas Thanks Meter: 1 | Quote:
The mileage is stored in the next lines: 0000: xx xx xx xx xx xx xx xx A9 CB ED xx A9 CB ED xx 0010: A9 CB ED xx xx xx xx xx xx xx xx xx xx xx xx xx where the next bytes: A9 CB ED - is a mileage,for 85000 miles, you have to change the hex-85000km = FFAFF7 | |
06-08-2009, 05:53 | #5 (permalink) |
Member: 1048166 Status: Offline Thanks Meter: 0 | Thanks huzzen27 for your reply. I get what you got a camry but I did not have a calculator for a celica. Looking at the dump I posted it is no where near right. I guess I corrupted it. If any one has a known good dump for a 00 celica in miles please let me know. Carl PS I did put in a city state country in my cp. |
06-09-2009, 04:25 | #6 (permalink) | |
Member: 937462 Status: Offline Sonork: ideas Thanks Meter: 1 | regarding cellica 00 dash Quote:
06-09-2009, 14:28 | #7 (permalink) |
Member: 1048166 Status: Offline Thanks Meter: 0 | huzzen27 thanks again and those dumps are like what i am used to. I am going to write one of those to the chip which i did take off and now get a stable reading on 2 different programmers. I must corrupted it reading it in-circuit before i jumped the crystal. I will let you know the outcome. Carl |
06-15-2009, 01:06 | #8 (permalink) |
Junior Member Join Date: Jan 2009
Member: 936313 Status: Offline Thanks Meter: 0 | Celica Dash Dump I'm assuming that the 93c46 IC is a SMD type chip. If that is the case remove the chip and run enameled magnet wire to each pin and then solder it to an 8 pin dip socket for reading and writing. Wire another 8 pin dip socket to the board and you can replace it when finished. If that is too much work, then look up the pin out of the 93c46 on icmaster and cut the VCC and I/O wire that supplies the EEprom. You can then read it without corruption. You can solder the cut lines when your finished. Good luck Last edited by mykewl; 06-15-2009 at 01:09. Reason: Grammer |
pls help me if you can | med26 | Samsung Hardware Repair | 0 | 02-17-2010 16:49 |
Please Help me If you can and thank's | mahimed | Nokia Base Band 5 ( BB-5 ) | 3 | 08-26-2009 00:43 |
Careful of "helper_ufs" and help me if you can | to_deal_with | The Market Feed Back | 8 | 02-27-2007 23:22 |
Please Help Me If You Can!!!!! | wimzieee | Samsung Flashers, Software, Firmware. | 4 | 08-24-2004 10:11 |
Give Me A Helping Hand If You Can | sunrise gsm | Infineon C16X M51 & ARM7 M52 BASED | 7 | 03-02-2004 21:09 |
