HTC Hardware Repair HTC Hardware repair, tutorials, help, solutions |
11-23-2013, 01:28 | #91 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2062440 Status: Offline Thanks Meter: 0 | |
11-26-2013, 21:59 | #93 (permalink) |
Member: 2068635 Status: Offline Thanks Meter: 0 | Damn! I had the problem, first time i replaced screen, the HTC logo flashed on first boot and it went dim. Then I replaced the 220 coil to a new one, hoping it would work. And it did for a second, after which the screen went dim again! Anyone know what might be causing this? At least now I'm sure what the consequence of this problem is: the 220 coil... but i just don't know the cause |
11-30-2013, 07:09 | #95 (permalink) | |
Junior Member Join Date: Oct 2013
Member: 2047619 Status: Offline Thanks Meter: 0 | Quote:
12-09-2013, 00:50 | #96 (permalink) |
Major Poster Join Date: Oct 2010
Member: 1411356 Status: Offline Thanks Meter: 4 | Repaired several units with this problem and I can conclude the following: permanent way to fix is to check and replace both coils and ****reball/replace IC****. If the problem is internal to the IC, replacing the coil will be only a temporary fix. Even if someone doesn't have proper tools to check the inductance - just unsolder coils and check resistance: 220 has to be 760mOhm and 2r2 190mOhm. If the inductance and resistance are in range - replace IC or at least try reballing it. In many units even after replacing both coils, phone fails again after hours, sometimes few days. Sometimes IC is re-flowed while replacing coil and the effect seems be positive, but again, it might not be permanent. Replacing 220 coil with the one from iPhone 3gs is a suicide mission. 220 is 22uH, 330mA and 2r2 is 2.2uH, current rating above 1A - after that IC will fail together with the replaced coil. |
The Following User Says Thank You to fonexp For This Useful Post: |
12-09-2013, 12:38 | #97 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: romania Age: 40
Member: 631660 Status: Offline Thanks Meter: 139 | Quote:
hello ..i`ve changed lcd and noticed that lcd light is flichering and dim...can you help me with real solution? all parts from led driver 220 seems ok...above battery connector is a coil which is cracked...can it be from that? where to get one ? br cristi | |
12-14-2013, 15:07 | #99 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1978377 Status: Offline Thanks Meter: 1 | Hi Hi Cristmobiles, I'm sorry for you but that is the solution (change Coil). If that is the problem, that is the solution. I don't think there is a better way to fix this or to make more stable. This is it , I'm sorry for you. Change coil again and be sure (by measuring) that it is a good coil ! Good luck |
01-05-2014, 23:31 | #101 (permalink) |
Major Poster Join Date: Apr 2005 Age: 47
Member: 134709 Status: Offline Thanks Meter: 5 | The problem is bad quality LCD, there are hundreds of copy LCD on the market that are bad quality, some times this fault will only show after a few weeks, best solution is to buy an original LCD ........ D |
