05-16-2014, 18:02 | #1 (permalink) |
Junior Member Join Date: Oct 2007
Member: 610846 Status: Offline Thanks Meter: 3 | Nexus 5 3g issue after imei repair [Solved] Last edited by Octopus box; 11-09-2014 at 08:51. |
05-16-2014, 20:14 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,415 | Simply make Reapair IMEI following step-by-step instructions in phone's manual ("Cable & Manual" button in software). |
07-15-2014, 14:08 | #8 (permalink) |
Freak Poster Join Date: May 2014 Location: Montreal
Member: 2195006 Status: Offline Thanks Meter: 19 | So you guys put up a fake video on YouTube showing it works. That's pretty messed up. I just paid 100 usd to activate it so I can fix a phone for someone and you guys make fake videos. Lol. Good job. |
07-15-2014, 20:52 | #10 (permalink) |
Junior Member Join Date: May 2014
Member: 2193198 Status: Offline Thanks Meter: 0 | i provided them with a fresh nexus 5 NVM - hopefully a fix can come out soon as i too purchased the octopus LG activation only to use on Nexus 5. now iam stuck with 4 NExus5 devices and LG activation |
07-16-2014, 06:50 | #12 (permalink) |
No Life Poster Join Date: Aug 2011 Location: all device sell hear
Member: 1627323 Status: Offline Sonork: WhatsApp+8801763009154 Thanks Meter: 481 | sg 4g succes Welcome to Octoplus/Octopus Box LG Software version 1.6.0 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM3 Selected model: D821 Reading info...Canceled! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM59 Selected model: D821 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gd59db4e Android version: 4.4.4 Hardware: ARMv7 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM59 Selected model: D821 Reading info... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gd59db4e Android version: 4.4.4 Hardware: ARMv7 Initializing ADB...OK Waiting for phone...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ:ÿh°? at port COM63 Reading info...OK Mode: Normal Model ID: AAAAANAZ:ÿh°? Firmware compiled date: Mar 12 2014 Firmware compiled time: 20:00:00 Firmware released date: Jun 4 2014 Firmware released time: 17:04:20 SW Version: M8974A-2.0.50.1.16 IMEI: 3oooo Repairing 3G / 4G...OK Please, reboot the phone manually. |
07-28-2014, 12:51 | #14 (permalink) |
Crazy Poster Join Date: Apr 2014
Member: 2167043 Status: Offline Sonork: johnpagal Thanks Meter: 12 | nexus 5 no service solution after imei fix or unlock here is the solution to fix the nexus 5 imei or unlock load the nexus 5 qcn file with the zero imei through qpst software it will say error or mismatch the qcn file but dont worry just hit ok then restart the phone manually once its done then go back to octopus box and hit just repair nvm thats it after 3 to 5 minutes ur phone will be working perfectly fine with out having issues this has been tested by me works like a charm |
07-31-2014, 16:10 | #15 (permalink) |
Member: 2193198 Status: Offline Thanks Meter: 0 | did you download a specific QCN file or its from your own backup? (can you share link to the file?) - interested in trying your method to try and fix 3g/4G issue with D820 after imei repair. |
