GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
02-13-2013, 10:10 | #196 (permalink) |
Junior Member Join Date: Feb 2013
Member: 1883136 Status: Offline Thanks Meter: 3 | What was wrong that did not work? He wanted me to have the knowledge of the Lord... |
The Following User Says Thank You to raferti For This Useful Post: |
02-13-2013, 12:18 | #197 (permalink) |
Member: 1883136 Status: Offline Thanks Meter: 3 | I'll ask the occasion even if it is for the Macbook dashboard to upload them to the modem. Installera Huawei |
02-13-2013, 12:59 | #199 (permalink) | |
Freak Poster Join Date: Mar 2002 Location: Moscow, Russia Age: 53
Member: 10397 Status: Offline Thanks Meter: 45 | Quote:
02-20-2013, 13:57 | #206 (permalink) |
Major Poster Join Date: Jan 2013 Location: Belgium
Member: 1875869 Status: Offline Thanks Meter: 2 | Huawei modem @vve @ fr3nsis By any chance do know what the AT command AT^DISLOG=255 is doing ? That command is being used in conjunction with AT$QCDMG. During a firmware update AT^DISLOG=255 is issued immediately after AT$QCDMG. Thanks Yves |
02-20-2013, 18:03 | #207 (permalink) |
Member: 10397 Status: Offline Thanks Meter: 45 | YLG80 Literally, ^DISLOG is intended to set NV_FORBID_DIAG item value to one supplied in command parameter. Looking at this name and name of command itself, I think it can be used to disable diag mode (DM) connections to any other ports except selected - the one you sent this command to. BTW, handler of this command in firmware code is located in module with "dsat_huawei_Japan_cust" name. But...in real life it's totally useless: just after you switch your device's PC UI to DM (with AT$QCDMG), there's no reason anymore to send any AT command to this port - simply because its binary representetion (41 54...) forms a "Send SPC" DM command with invalid parameter - SPC must contain ASCII representations of digits only (30...39). There's no even need in discussion of required checksum and final 7E marker - command will be invalid in every case. So simply forget about it. |
The Following User Says Thank You to vve For This Useful Post: |
02-28-2013, 00:01 | #209 (permalink) |
Member: 1891340 Status: Offline Thanks Meter: 0 | @ fr3nsis , My modem is completely dead because i tried to install Huawei E5832S firmware on my E5832.I tried using your Flasher but don't work. The FW version i am using named is :- E5832_Update_676.11.00.20.112sp05.exe Since the modem is dead , the normal upgrade application doesn't work.I can see a " HUAWEI Mobile Connect - 3G PC UI Interface " in my Com ports. I am posting here some requested details.Please help me resurrect it. _________________________________ My RevSkills Log _________________________________ 0D 14 37 36 32 35 41 2D 31 33 35 35 33 30 30 38 2D 53 4E 43 41 41 7625A-13553008 -SNCAA _________________________________ And this is the problem.Even though i have downloaded & using the correct firmware , your flasher still says that it's not compatible.Can you PLEASE give me a download link of the firmware which i will need for my E5832 so that i can use your flasher to resurrect the modem ? Please help me. Anxiously waiting for your reply.Please help.Thank You very much. |
02-28-2013, 09:38 | #210 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: Rome , Italy
Member: 190882 Status: Offline Sonork: BB PIN: 7C83D9CE Thanks Meter: 1,282 | Quote:
NU2000a - All Nokia Flasher & Unlocker! | VictorGSM | Main Sales Section | 0 | 12-14-2000 19:58 |
6150 + NCDS3.0 + Win2000 + IBM600X + Xyrcom GSM modem (realport)? | bibi2k | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-21-2000 17:33 |
Universal SP Unlocker 4.0 - home page !!! | bp.bonus | GSM Mobile Links | 0 | 01-22-2000 22:31 |
